Old 01-17-2019, 10:01 PM   #51
Zachsnyder321
Member#: 496621
Default Tune
Originally Posted by toddwilliams View Post
I have a 97 subaru and it will run fine and then it starts to run really rich, now I have a po1104, and a po441 codes. Also I just put 175 miles on 1 tank of gas. Can anyone help
Have you got it tuned or do you have a air to fule gauge and if so what is it reading?
Zachsnyder321 is offline   Reply With Quote
Old 05-10-2019, 04:01 PM   #52
Raqs
Member#: 501402
2012 WRX sedan PremG
Pearl White - GV
Originally Posted by N7Yeti View Post
Agreed!
I agree as well. I'm from South Africa. I have a 2012 GV WRX sedan and would love to learn as much as I can from all of you. Resources and quality parts readily available to all of you is not as cost friendly to us down here at the Tip of Africa. So we always tend to make things work by considering alternatives. I'm hoping your knowledge and experience can assist me in managing and maintaining by baby.
Raqs is offline   Reply With Quote
Old 05-31-2019, 09:07 PM   #53
Anewby100
Member#: 502763
Default 2003 ej20 not starting
I have a 2003 wrx ej20 2.0 that cranks but won’t start. Took motor out to do the head gaskets and replaced some sensors and some other maintenance on it. Put the car all back together and now it’s not starting. Cranks over great but just seems like it’s not getting spark. It’s getting fuel I pulled the plugs and they was soaked. Changed out the coil packs with oem. It try’s to hit but just doesn’t fire up. I have a video of it cranking over
Anewby100 is offline   Reply With Quote
Old 08-14-2019, 01:50 PM   #54
JaviWx
Member#: 505289
Anyone know what causes a louder hissing sound after engine is turned on it lasts for like 10 seconds I hear it from the gas tank.
JaviWx is offline   Reply With Quote
Old 08-22-2019, 12:56 PM   #55
VossMuzik
Member#: 505560
Default Diy
[quote=SubaruGoob;37813381]So i have a 1998 OBS wagon, 5 spd, and it has 168k on it.
If you can loosen the bell housing enough to back the transmission off to see the clutch plate you’ll be able to tell if it’s backwards from the teeth.
VossMuzik is offline   Reply With Quote
Old 09-17-2019, 12:40 AM   #56
Subaru206
Member#: 506425
So does anyone know by chance, why my 2008 impreza (automatic) would be wanting to turn off while I slow down but it dont shut off ? When I step in the gas the bear doesn't go in like normal ?
Subaru206 is offline   Reply With Quote
Old 09-17-2019, 08:36 AM   #57
mmckeown
Member#: 506440
Default 2017 Impreza sport manual oil consumption issues.
We still have our 1997 Subaru-Isuzu Trooper and that is why we bought the 2017 Impreza sports manual vehicle
However 2300 miles after synthetic oil change at dealer for the 2017 Impreza red light came on and there was only 1 1/4 quarts of oil in the engine.
This unfortunately is a reoccurring event.
Need to find the oil consumption form to complete to find out the best course of action.
Thank you for your guidance and help.
mmckeown is offline   Reply With Quote
Old 02-22-2020, 11:32 PM   #58
Cambo rambo
Member#: 511924
Default Will a wrx 06 fuel cradle assembly work with a sti 06 model?
Help someone! ***128556;
Cambo rambo is offline   Reply With Quote
Old 05-11-2020, 01:56 PM   #59
WUbaru79
Member#: 495171
Default off subject
Originally Posted by Nick View Post
We realized the categories in here were seriously lacking for cars since around 2004. So today I created prefixes to be used to identify the model year impreza you are talking about when you post your thread.
I have also moved all the threads that were in the two sub-forums back into this main forum.
Any threads that were in the '93-'01 forum were automatically assigned the proper prefix of ('93-'01). The threads in the other sub-forum could not be automatically assigned so they were just moved.
If one of those threads is you you should be able to edit the thread information and add a prefix, otherwise you can contact a moderator or myself and we'll be happy to add the proper prefix to your thread.
About using prefixes, they are now manadatory in this forum, so if you want to post a new thread in here you MUST chose the proper prefix. They are simply arranged by model year, so pick the right one. We've broken them down by MY/facelift, not just model code, since that wasn't specific enough.
The biggest upside to prefixes is that you can use them when using the search function to make your results significantly more accurate.
Hey ya'll,
Just real quick, will a 2011 impreza sedan motor fit in a 2009 impreza sedan?
WUbaru79 is offline   Reply With Quote
Old 05-22-2020, 11:48 AM   #60
corz_mario
Member#: 514982
Question 2015 Subaru Impreza HATCHBACK
Good day,
I have an issue with my Impreza, whenever I press or shadow the brake the car has this bucking feeling not sure if bucking is the right word but that is how it feels when I press brakes. It drives okay but as soon as I pressing brake it has the bucking/jumping feeling. Please could someone assist
corz_mario is offline   Reply With Quote
Old 06-24-2020, 12:18 AM   #61
subie_flow_69
Member#: 516048
Unhappy needed help 2019 Subaru sit turbo oil leak
so I rebuilt the block with Manley forge internals so I hooked up the turbo and when I cranked up the car a big dial of oil came crashing down remind you bloke and heads and covers are in grate condition. so I took turbo off thinking oil lines I made sure all line was tight and they were except 1 so I tightened it and now there is just a littlest of oil leak now its more like just a steady little stream and I can't seam to figure out what to downy pointers plz help
subie_flow_69 is offline   Reply With Quote
Old 07-27-2020, 09:01 PM   #62
Andersenloaisa
Member#: 517105
Default 2013 Impreza 2.0 non turbo sedan
I was wondering if you guys knew what other bumpers from other Subaru cars fit on my 2013 Impreza sedan premium.... I like the bumper on the 2016 Impreza sport hatchback... but idk if it would fit. Let me know any other bumpers that would fit SUBARU BUMPERS ONLY..please
Andersenloaisa is offline   Reply With Quote
Old 11-17-2020, 09:43 PM   #63
Khill4288
Member#: 520347
Mine does that randomly when I pull out on a hill!
Khill4288 is offline   Reply With Quote
Old 02-10-2021, 02:47 PM   #64
Supersnake
Member#: 522031
Originally Posted by Joshpeachey View Post
Hi guys, I'm new to the forum so I can't start a thread yet. Sorry if I'm kind of hijacking this one. I'm looking at buying a 2002 wrx with 244000 miles, the body and interior are in good condition and according to the owner it runs great. Is it worth 2500?
That a lot of miles you should ask if you can test drive and see how it feels
Supersnake is offline   Reply With Quote
Old 02-10-2021, 09:55 PM   #65
respectedwealth
Member#: 522296
Hello, I need help. I'm currently looking into buying an Impreza. I have found two, one is a 2002 Impreza wrx and the other is a standard 2007 Impreza. I wanted the opinion of those who know more than me about this car. Which one is more reliable, faster, and will be more fun to drive.
2002
https://www.mychoicemotors.com/detai...preza/69953767
2007
https://www.mychoicemotors.com/detai...preza/73116802
respectedwealth is offline   Reply With Quote
Old 02-17-2022, 01:43 PM   #66
Dj243
Member#: 528886
2006 Subaru
Did you buy it??
Dj243 is offline   Reply With Quote
Impreza Forums have been moved... Nick General Community 0 09-16-2003 07:47 PM
Mk1/original Impreza forums? Tyrmeltr General Forum Archive 9 03-24-2001 12:15 AM
