07-10-2020, 02:12 PM | #10776 |
Member#: 182415
Vehicle:1999 RS Aspen White |
Hows the PRI delta handguard? Been looking for the older round ones but these have been growing on me
07-10-2020, 02:29 PM | #10777 |
Member#: 30554
RMIC
Vehicle:2013 GLK250 |
Definitely light, which is nice with the can on the end. The top rail helps a ton with getting everything lined up nice so I would suggest that if you're considering it. Only complaint is the backing threads to screw the pic rails in aren't permanently mounted to the handguard so relocating the rails after mounting the handguard can be tricky. I do like how snugly the back of the top rail fits against the MBUS Pros. The barrel nut is also machined well and easy to align the gas port near the target torque.
07-10-2020, 02:36 PM | #10778 | |
Member#: 2808
07-14-2020, 12:50 AM | #10779 |
Member#: 23354
BAIC
Vehicle:1998 Toyota Sienna "Olaf" |
Success!
So, I hadn't heard back from Savage yet about the chamber burr and then discovered they close their whole operation from July 3-12, which is actually pretty awesome. I think it's like a big paid vacation for them under the guise of a "factory shutdown". Unfortunately, I couldn't even insert a snap cap into the Mark II more than about half way. I did a super cleaning on the chamber and tried it at the range Sunday with 3 different loads. It had gotten so bad (I think I made it worse with the cleaning lol) that even trying to load a round was scarring the bullet. Yikes. I figured it wasn't going to work well anyway so brought other stuff. ~100 rounds through the HD shotgun, oof, got a bruise to show for it, but a lot of practice off and on through the day going from low ready to on target at 20-40 feet. Also, the swap meet was basically just like a car swap meet. A bunch of misc parts (duh). I'm sure I could have found some great deals on optics if I knew what I was looking at, but that's something I'd still rather buy new for the peace of mind. Tons of stocks and vises, empty ammo cans and cases, tripods, and then all of the really rare/weird stuff. There are apparently private sales at that meet, but I didn't see any functioning firearms. Anyway, the gunsmithing! Before: I'd done some research into clearing 22 burrs and ran across some old info about gunsmithing tools that nobody makes anymore. Sounded like some folks had good luck with a punch tool also, but I couldn't remove the barrel. However, I found this and ordered it: Tandemkross "ChamberMade" Chamber Ironing Swage Gunsmith Tool for .22lr, .22long, .22short Pretty cool how it's designed to work from either down the barrel with a cleaning rod, or with a 1/4" socket. Not as great as the old tools that are basically the same swage but with an attached rod and hard to find. The socket I had couldn't get centered while in the chamber, but I could fit a little box wrench! A ratcheting wrench would have been ideal, but didn't have one that small. I connected the barrel side to a cleaning tool to keep the swage in the right spot, and then used another cleaning tool coming from the bolt side to put pressure on it. With the rod tool I'm sure you could get some wicked pressure on it and really clean some pipe. A pretty slow process at only about 15deg a turn, but definitely worked. It's not perfect, but plenty good enough that the practice ammo goes right in easy and the rifle functions properly. Ran some snap caps through from a magazine and it loads and ejects. Do you think it's ok to store the rifle with a practice round loaded, to avoid accidental dry fire? I'm worried it'll seize or something though. I guess I could just try it out and check it occasionally. The hardest part was just committing to potentially fubar'ing the rifle and not getting any warranty help at all. I'd solved that by buying a CZ 457 MTR though...sooo, I had some courage. lol .....and bought a PTR 109 (well the 406 in CA, fin grip bleh) - local shop, good deal. HK91 is my dream gun from Counter-Strike. Next up: DE, P90, and MP5. Sig P228 up there also. ...and bought an M&P 15-22 Sport. I'd already grabbed an Angel Blue Walther P22 for my daughter, who's now decided she wants to do bow and arrow instead. One of the local ranges has a 22 only section with reactive plates at 25 and 50 yards. I've seen it a few times, looks like a blast. It's like a family thing. Bring in a cooler for sodas and sandwiches, a kid or two, a thousand rounds and make a day of it. I may have a problem. EDIT - pretty sure that smithing tool rod thing I'm wrong about. The swage is the tool, the rod is custom? I dunno, but I'm looking for one. Last edited by jsmaze; 07-14-2020 at 12:57 AM. |
07-14-2020, 09:22 AM | #10780 |
Member#: 512654
Vehicle:2019 wrx red |
07-14-2020, 10:48 AM | #10781 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
I just bought Edge. I couldn’t handle the UPS Mail Innovations garbage shipping tier they were charging $5 for, unfortunately I still paid $15-20 in shipping recently...didn’t expect the shipping to be so ****ty.
07-14-2020, 11:29 AM | #10782 |
Member#: 82883
South East
Vehicle:2006 2.5i Wagon 220k '72 LSx Nova Turns&Stops |
Any opinions on the Sig Sauer Romeo5 Red DOT sight? Looking in getting one for the AR15 Do not need anything fancy, just target practice at the range.
07-14-2020, 11:48 AM | #10783 |
Member#: 512654
they used to be great, then they grew and moved locations a few years ago, and its been a poop show ever since. i only use them when they are the only one's who have what i want at this point. besides the slow shipping in house, and adding to it the super slow mail innovations, even with ffl pricing they are more expensive than just about everybody else on almost everything they sell. its sad to see what were good companies circle down the drain.
07-14-2020, 11:49 AM | #10784 |
Member#: 512654
i have 1, for the $120 i paid for it, its fairly decent. imo way better than the vortex dot that i have collecting dust.
07-14-2020, 12:05 PM | #10785 | |
Member#: 178811
**** Midway. |
07-14-2020, 12:24 PM | #10786 | |
Member#: 512654
07-14-2020, 12:33 PM | #10787 |
Member#: 82883
South East
07-14-2020, 12:40 PM | #10788 |
Member#: 512654
07-14-2020, 12:43 PM | #10789 |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
Suppressor nerds:
What's the easiest/laziest way to clean a suppressor? I've got a Ti baffle stack that's easily removable, but I don't want to scrub the bastard after every trip |
07-14-2020, 12:53 PM | #10790 |
Member#: 512654
just spitballing, as i dont have one, but id think one of those ultrasonic cleaning tanks.
07-14-2020, 01:30 PM | #10791 |
Member#: 30554
RMIC
I just use H#9 and a soft bore brush but make sure whatever solvent you use is compatible with the finish.
07-14-2020, 02:16 PM | #10792 | ||
Member#: 178811
This was what I did last time. Forget which solvent or if it was #9, but the Surefire’s even come with a scrubby brush. |
07-14-2020, 04:25 PM | #10793 | ||
Member#: 79643
NESIC
07-14-2020, 04:40 PM | #10794 |
Member#: 5470
Vehicle:2014 Honda Odyssey Nondescript |
I use m-pro7 in an ultrasonic cleaner and it's magical. never used it on a can but it works really well on just about everything.
07-14-2020, 10:06 PM | #10795 | |
Member#: 141952
Vehicle:2023 M340i |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
07-16-2020, 08:34 AM | #10796 |
Member#: 82883
South East
Anybody with a Springfield Armory Saint AR pistol or a Sig Sauer M400 tread pistol. Any inputs? Going to the range this weekend to try them out before I buy. Looking to get it for 150-200yrd range target practice.
Any other options in the $1000 range? |
07-16-2020, 09:25 AM | #10797 |
Member#: 17975
Vehicle:2023 Macan GTS Python Green |
I have the full size Saint Edge and it's butter - the trigger and muzzle break on it are really fantastic - I'd imagine the pistol/SBR is pretty much the same Would have picked up the pistol but my club banned non-pistol caliber on the short range so seemed kinda pointless for me
07-16-2020, 10:03 AM | #10798 |
Member#: 178811
You can find BCM uppers in the $600-800 range and build a pistol lower.
07-16-2020, 10:44 AM | #10799 | ||
Member#: 82883
South East
Palmetto has the Sig M400 Pistol in stock.....my mouse is all over the "Add To Cart" button. Not sure what to do. |
07-16-2020, 12:36 PM | #10800 |
Member#: 178811
There’s some Mk2 uppers in stock, but you missed the 11.5”: https://bravocompanyusa.com/ar15-upper-receiver-groups/bcm-mk2-upper-receiver-groups/
