07-17-2021, 02:32 AM | #1 |
Member#: 291949
PRSIC
Can you safely reverse fan direction?
Can the OEM rad fans from a 2014 STI be run safely in a reverse direction, aka pusher and not puller configuration? I take it the fan blades are not removable based on their appearance... Worried more about how reversing their flow may impact how the ECU controls them and or electrical issues.
07-21-2021, 08:32 AM | #2 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
It may work but the blades won't be nearly as efficient running backwards.
07-21-2021, 08:45 AM | #3 |
Member#: 508105
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
Yeah but dont
07-21-2021, 10:06 AM | #4 | |
Member#: 47143
07-29-2021, 10:33 PM | #5 |
Member#: 291949
PRSIC
This a custom setup. I will be adding a 9" SPAL fan that is reversible. Also can run on stock wiring/relay. Just confirming that reversing polarity wont cause any issues for the ECU or any fan control chips.
I need to mount a second fan on the condenser to push air into the engine bay. The car is running a half sized rad and once the single rad fan turns on, all the air goes to the rad and no air is passing through the intercooler. I confirmed by unplugging rad fan and saw IAT go down. |
