03-05-2021, 10:01 PM | #11176 |
Member#: 141952
Vehicle:2023 M340i |
equipment exchange on AR15.com is a good spot, massive amount of buyers there.
03-10-2021, 12:09 AM | #11177 |
Member#: 12733
Vehicle:2022 Kia Forte GT 2009 Suzuki Boulevard M90 |
I had a pic to post, but imgur is giving me fits lately so no go. Long story short, it's nice to see the comforting glow of your night sights after fishing a G19 out of your storage ottoman, after you fell asleep on the couch but were awoken by loudmouth idiots outside.
03-10-2021, 12:06 PM | #11178 |
Member#: 2808
My Polymer80 G17 initial assembly is done. The initial trimming and drilling came out great. The front locking block fits great (which is something I had issues with on the previous G17 I made) and the rear rails line up perfectly so the Brownells slide action is like butter ... when the connector isn't installed.
Not sure what the deal is for sure but at first the P80-branded connector was sprung out from the P80 trigger housing too far and was dragging HARD on the slide and the trigger wouldn't reset. The connector was removed and tweaked ever so slightly in but now the trigger reset is mushy but there's still drag on the slide. A new genuine Glock connector has been ordered so we'll see how that works. Replacing the trigger housing with a Glock part will be next if necessary, but then I'm getting away from any cost savings from using aftermarket parts to begin with. Only other problem is the Brownells guide rod/spring seems to have a slightly larger diameter and drags on everything making it sound like an old rusty screen door, a noise I hate. A Glock part may be needed to fix that too, unfortunately. Beyond that, most of the Polymer80 frame parts and especially the Brownells slide parts are surprisingly fine. They aren't rated very highly on Brownells' site but they are serviceable to complete a project like this. |
03-10-2021, 12:16 PM | #11179 | ||
Member#: 12733
03-10-2021, 12:24 PM | #11180 |
Member#: 37678
SCIC
Anyone got a recommendation for g26 mag/pinkie extensions?
03-10-2021, 12:29 PM | #11181 |
Member#: 12733
The factory 12-round mag with extension or the Magpul 12-round mag should suit you well. I only carry factory mags but people have had mixed results with both, more notably with Magpul mags. I have Magpul mags but have not experienced issues. I don't give them a ton of range time anymore so take my opinion for what it's worth.
03-10-2021, 12:33 PM | #11182 |
Member#: 12733
I will say I definitely think the 26 is one of the best carry guns, ever.
03-10-2021, 12:51 PM | #11183 |
Member#: 141952
no idea how to embed instagram posts, but my new pistol. https://www.instagram.com/p/CMDm8xrJ..._web_copy_link |
03-10-2021, 12:54 PM | #11184 | |
Member#: 12733
03-10-2021, 12:55 PM | #11185 |
Member#: 141952
03-10-2021, 01:04 PM | #11186 | |
Member#: 37678
SCIC
Today is actually my first day carrying it, and I take back everything I said, lol. It's not that much smaller, but it wears way more comfortably. So good. It actually shoots better, but my g19 is from 1998, I'm sure spring technology has progressed a lot. |
03-10-2021, 01:22 PM | #11187 | |
Member#: 189994
03-10-2021, 01:37 PM | #11188 | |
Member#: 12733
03-10-2021, 02:23 PM | #11189 |
Member#: 37678
SCIC
Funny, I'm not a fan of oem glock mags, had too many develop stupid issues. I'll take my chances I think.
03-10-2021, 02:41 PM | #11190 |
Member#: 2808
Agreed. The first one I built was a G19 with Glock guts and it all worked well from the get-go. Second one was a G17 from 80PBuilder with their aftermarket parts and that one, while it worked fine eventually was a bit rough at first and made the same ' old metal screen door' sound. This one is another step worse with the connector issue. But if these things fell together without issues, what fun would that be?
03-11-2021, 07:06 AM | #11191 |
Member#: 2808
And the OEM Glock connector fixed it. It isn't perfect but it's WAY better then it was and it actually functions and resets properly now.
03-11-2021, 11:21 AM | #11192 | |
Member#: 139693
Vehicle:Dura ngo 95 horrorshow |
When I ran 26's for EDC, definitely the Pearce +0 grip extensions. They are fantastic and don't have to worry about reliablity. I'd carry the factory 12 round mag with extension for my backup mag on the belt. |
03-11-2021, 01:53 PM | #11193 | ||
Member#: 12733
Fortunately I have no issue with the short grip of the 26 and wrapping my pinky underneath. I know a lot of people do not care for that. |
03-11-2021, 02:33 PM | #11194 |
Member#: 37678
SCIC
The issues were with high caps. They split, or bowed out, causing misfeeds and not dropping properly.
I'll try the pearce extension, thanks Pre! |
03-30-2021, 03:49 AM | #11195 |
Member#: 23354
BAIC
Vehicle:1998 Toyota Sienna "Olaf" |
LW 17HMR barrel finally arrived for the CZ, yay! About the only manufacturer that was even making anything.
The specs say 20", but measures 19.5 on a table outside of the rifle, from the absolute end to end. I've read that the measurements are actually supposed to be from when it's installed and the bolt is closed. I was just kinda bummed taking the 20.5" out, and noticing it's 1.25" shorter. Also this is 22 vs 17, I don't know if that would affect the official measurement. It's threaded, too, so I need a muzzle device, 1/2-28 (no cans). Found one that came pretty highly recommended and is super cheap vs most others, but not after getting it mounted. https://harrellsprec.com/index.php/p.../muzzle-brakes Is it normal to require machining of these kinda brakes? It ain't cheap after needing an hour or two of shop time. Pics for pics sake (omg what the hell is nasioc hosting doing lol) Last edited by jsmaze; 03-30-2021 at 03:58 AM. |
03-30-2021, 10:18 AM | #11196 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
I believe the ATF measures barrel length from the bolt face to the muzzle.
03-30-2021, 10:41 AM | #11197 |
Member#: 2808
I took my completed Polymer80 to the range on Sunday. 100 rounds without a hiccup. The transplanted Holosun 407A didn't even need to be adjusted. Only real issue is that the trigger pull feels like 7-8 pounds for some reason but is crisp enough to not be a problem. I was actually shooting it better than my M&P which made me fall a bit more out of love with it.
03-30-2021, 10:41 AM | #11198 |
Member#: 512654
Vehicle:2019 wrx red |
thats not a 20" barrel, no matter how it is measured.
03-30-2021, 12:34 PM | #11199 |
Member#: 93830
03-30-2021, 01:07 PM | #11200 |
Member#: 178811
