Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 04-27-2014, 10:26 PM   #126
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
My rear audio panel does not appear to function.
OrbitalEllipses is offline   Reply With Quote
Old 04-28-2014, 12:02 AM   #127
BigWrecKs
Member#: 93830
Originally Posted by XanRules View Post
Yes. None of my temps have ever been above 35C if speedfan is correct.
It literally ONLY ****s up in Chrome.
Do the freezes ever un-freeze? I get random freezes that are tied to the nvidia storage driver being used for my Raid 5. My system board is an 780i from 2008...so its not happy to run windows 7 drivers.
Just wondering because it seems that Chrome also triggers random freezes for me.
BigWrecKs is offline   Reply With Quote
Old 04-28-2014, 12:14 AM   #128
Charge
Member#: 3313
Just to make sure, if Realtek, verify that the Realtek config isn't set to only enable the front panel.
Also, I've had some weird experiences switching between those when I just used the built-in drivers. Installing the Realtek or motherboard approved ones usually fixed it.
Charge is offline   Reply With Quote
Old 04-28-2014, 12:41 AM   #129
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
It could be that, BigWrecks. They routinely un-freeze (though less often recently) and my graphics card drivers **** up A LOT.
XanRules is offline   Reply With Quote
Old 04-28-2014, 02:19 AM   #130
end0
Member#: 224418
What router would you guys recommend? Right now I have a Netgear WNR200 and the WiFi speeds just are not cutting it anymore so I'd like to get a new router, I'm just way out of the loop with routers. I'd like to sped under $150 hopefully.
end0 is offline   Reply With Quote
Old 04-28-2014, 08:59 AM   #131
Charge
Member#: 3313
I'd say some of the Asus 6* series should be in that range.
I just got a Netgear R7000, but that's $200. For me, I needed the processing power. I have a lot of people remote into my NAS to initiate usenet downloads, as well as pulling files off the NAS. So I'm pegging my 100Mb/100Mb connection pretty regularly. My older routers couldn't handle it and if you maxed upload, download would only process at like 10Mb, since the processor couldn't keep up with NAT'ing all the connections. The R7000 is more than fast enough to keep everything running.
I didn't really buy it for the Wifi, because I don't have any AC devices yet. I can say the range might be a smidge more than my 5th generation Airport Extreme N router I was using as a wireless access point before. Not much more though.
Old 04-28-2014, 10:03 AM   #132
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Used the Realtek drivers that came with the mobo install cd, then downloaded the latest ones from Gigabyte. No dice. They seem to detect, but no audio. Made sure the Realtek software was not set to disable rear. Front panel from the case works fine though. I don't care that much, but it's really the principle of the matter.
Old 04-28-2014, 10:23 AM   #133
Rattles
Member#: 16486
2006 Jeep
god damnit!!! my precious awesome Nec monitor has some sort of burn in (i know that LCD don't get burn in but i don't know how else to describe it). it almost looks like bleed from the right side which i am assuming is from the second monitor being right next to it. this sucks as this was NOT a cheap monitor and i don't have any plans on paying another $1500 for a similar one.
edit: so looks like the correct term is image persistence and in some cases it goes away if you shut off your monitor for an extended period of time. i think that i will switch screens for a week and see if it fixes it..
Rattles is offline   Reply With Quote
Old 04-28-2014, 11:07 AM   #134
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
Just bought a used GTX 680 off eBay.
I'm going SLI, bitches. Awwwwwww yeeeeeeeeeeeeeeeee
Kiel is offline   Reply With Quote
Old 04-28-2014, 03:53 PM   #135
end0
Member#: 224418
Yeah I don't do to much file sharing thru my home network. Most would be streaming a movie to my Pi but not much more. I'm actually looking at the Nighthawk right now. So it's either going to be the nighthawk or ASUS RT-AC66U. Still undecided, but going to Micro Center later to pick one up.
That sucks. My 24'' Dell is old as hell now and it's starting to get burn in from my browser, so whenever I leave the house I turn on a burn in video on youtube and just let that run and it seems to work for me.
I've been thinking of getting another 7970 since the prices are coming down from the miners. What resolution do you play at?
Old 04-28-2014, 08:46 PM   #136
Kiel
Member#: 133439
2003 WRX
Right now, 1920x1080. I know this will be overkill, and I am happy about that. I plan on upgrading this 27" 120Hz Acer to some new 27" 1440p/1600p G-sync monitor once those are out and reasonably priced, but who knows.
Old 04-28-2014, 08:51 PM   #137
96accord
Member#: 145105
2015 Honda Accord
SLI... Meh
96accord is offline   Reply With Quote
Old 04-28-2014, 09:05 PM   #138
Kiel
Member#: 133439
2003 WRX
Originally Posted by 96accord View Post
SLI... Meh
don't be jelly
Old 04-28-2014, 09:15 PM   #139
96accord
Member#: 145105
2015 Honda Accord
don't be jelly
No reason to be jelly. My GTX 770 is perfectly fine
Old 04-28-2014, 09:16 PM   #140
Rattles
Member#: 16486
2006 Jeep
what video on youtube do you use? might as well try it on my second Dell 20" as well since it also has a browser burn in.
Old 04-28-2014, 09:41 PM   #141
Kiel
Member#: 133439
2003 WRX
perfectly fine is not enoughhhh
Old 04-28-2014, 11:44 PM   #142
end0
Member#: 224418
Yea at 1080 that's way over kill. You'll be maxing out every game fps wise.
I use this guys channel - https://www.youtube.com/channel/UCrz...IDewdQBV0P3hSg He has a lot of different aspect ratios/color/no color and they run for like 10hrs.
Also I went to micro center and picked up the Netgear Nighthawk router and man the wifi is 10x faster on my old iphone 3g's and 30x faster on my gf's iphone 5. So amazing.
Old 04-29-2014, 08:06 AM   #143
96accord
Member#: 145105
2015 Honda Accord
That's fine. Waste your money.
Old 04-29-2014, 08:32 AM   #144
ptirmal
Member#: 82243
13' BMW X3 35i
Same could be said for everyone in this thread .
ptirmal is offline   Reply With Quote
Old 04-29-2014, 08:47 AM   #145
NOTinASubaru
Member#: 295494
1996 4runner miata
My Coolermaster Elite 361 case is pretty damn tight, also had no idea the Corsair H55 cpu cooler was going to be so massive. I have the radiator mounted inside the case, the fan mounted outside the case
Ordered more fans, 3 80mm, and one slim 120mm (12mm thickness). Hopefully that's enough to keep everything cool.
NOTinASubaru is offline   Reply With Quote
Old 04-29-2014, 08:50 AM   #146
Jard
Member#: 34935
Dad- Core
OG
For end0:
Crossfire 7970s will be nice and push 1440p well.
BUT if you can get decent money for your 7970, look at going for a single card like a 780 Ti.
I sold Crossfire 7950s for a 780 Ti and could not be happier. I had to pay like $40 extra after selling both my cards. Are the prices still inflated?
Jard is offline   Reply With Quote
Old 04-29-2014, 09:51 AM   #147
96accord
Member#: 145105
2015 Honda Accord
How so? I didn't buy parts I didn't need like Kiel lol
Old 04-29-2014, 10:01 AM   #148
Kiel
Member#: 133439
2003 WRX
Good. That's how it should be. Once a quality 1440p/1600p monitor comes out that isn't 24" or stuck at 60Hz I'll be switching out and taking advantage of it.
You buy pretty rocks to line your garden, I buy things to make my games run even better
Old 04-29-2014, 10:32 AM   #149
NOTinASubaru
Member#: 295494
1996 4runner miata
Originally Posted by Jard View Post
For end0:
I've been watching 760 prices for the last few weeks, those things don't budge in price at all.
Old 04-29-2014, 10:51 AM   #150
Jard
Member#: 34935
Dad- Core
OG
I meant AMD resell prices in particular. You just have to watch Newegg every day for new video card deals.
