Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 02-01-2021, 06:23 PM   #11301
whitrzac
Member#: 229105
Originally Posted by jsmaze View Post
I wasn't and upsold myself twice before ending up with a backlit Sony 940D. Maybe it's not as noticable on smaller screens, but at 60" it's bad.
Next step is oled, which is what I wanted in the first place, but thought 'how bad can a $700 tv be'
whitrzac is offline   Reply With Quote
Old 02-12-2021, 01:26 PM   #11302
Salvation27
Member#: 292403
2012 Legacy
Graphite
Salvation27 is offline   Reply With Quote
Old 02-12-2021, 01:29 PM   #11303
Reflex-Arc
Lord of the Gif
Member#: 1703
2020 Giulia TI Sport
your linky no worky
Reflex-Arc is online now   Reply With Quote
Old 02-12-2021, 01:33 PM   #11304
Salvation27
Member#: 292403
2012 Legacy
Graphite
https://www.facebook.com/groups/1687...97938393794662
Would it not work if the group is private?
It's these:
Vandersteen 1C with Sound Anchor Stands. Excellent Condition.
Old 02-12-2021, 01:34 PM   #11305
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
still doesn't work
Private group.
Why not screenshot?
vapore0n is offline   Reply With Quote
Old 02-12-2021, 01:37 PM   #11306
Salvation27
Member#: 292403
2012 Legacy
Graphite
I did
Old 02-12-2021, 01:40 PM   #11307
vapore0n
Member#: 21356
2017 Subaru Corolla
ah, it finally showed up
Old 02-12-2021, 01:49 PM   #11308
Salvation27
Member#: 292403
2012 Legacy
Graphite
Ok, so are they great/ good/ bad?
Old 02-12-2021, 02:24 PM   #11309
Dizmal
Member#: 103474
My other ride is
your mom
Decently regarded speakers, just depends on the price and if you like the sound.
Dizmal is offline   Reply With Quote
Old 02-12-2021, 02:26 PM   #11310
Salvation27
Member#: 292403
2012 Legacy
Graphite
$300 for the pair
Old 02-12-2021, 02:34 PM   #11311
Dizmal
Member#: 103474
My other ride is
your mom
Doesn't seem like a horrible price if condition is good.
Tried searching ebay for comparables sold and I think I found 1 that sold for $400, lost the page and can't seem to find it now. But I'm not an ebay pro by any means, ha.
Old 02-12-2021, 03:04 PM   #11312
aschen
Member#: 30733
2007 tiny car
striped
Vandersteen are good speakers. You can probably get more accurate standmount modern speakers for similar monies. Something well engineered with modern methods but cheaply built.
However for nicely built floor standers made in the USA, 300$ seems reasonable. The socks come off so you can see the driveres. Make sure the surrounds and tweeters are in good shape.
You can find similar vintage klipsch KG series for about the same money if you like something a bit more lively. Hadnt heard any vandersteens in many years but they have a reputation for being a bit laid back (not a bad thing in my mind).
aschen is online now   Reply With Quote
Old 02-14-2021, 03:43 PM   #11313
whitrzac
Member#: 229105
Visio 55in oled was on sale for $1k. Picture quality is decent.
Having issues getting 4k 60hz HDR to work from my 1050ti though
4k 30hz hdr works
Old 02-21-2021, 10:39 AM   #11314
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
Picked up the Starke Sound AD4.320 and got it added to my setup running my fronts in bridged mode. Pretty happy with it, definitely cleaned things up when pursuing higher volumes. Downside is I've now got a ground loop hum where I've ordered a bunch of stuff to resolve.
AVR is "double insulated" so has no actual ground, amplifier has a ground. Even with all inputs removed from the AVR I still get the hum. I've got a jensen isolation transformer on order that I plan to utilize between the AVR and the amplifier which should resolve things but I guess I'll find out.
Akirasoft is offline   Reply With Quote
Old 02-22-2021, 10:54 PM   #11315
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Did you try a different power cord or try an outlet on a different breaker circuit? Are you using a power conditioner?
isotopesope is offline   Reply With Quote
Old 02-23-2021, 08:00 AM   #11316
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
i don't have any extra compatible power cords laying around. I'm not using a power conditioner, just a PDU because most conditioners are smoke and mirrors. I am also not using a surge suppressor because I already have a whole-house suppressor.
Hum persists if I use different outlets and bypass the PDU.
Hum persists if I remove all sources but does quiet from 40db to 30db or so if I remove the cable box.
Hum goes away if I unplug the AVR from power.
Hum goes away if I use a cheater plug on the new amplifier. (this is unsafe, but I'm currently running like this until the rest of the possible fixes are delivered.)
Hum persists if I ground the amp chassis to the receiver chassis with some spare 12awg copper speaker wire.
I have on order:
Old 02-23-2021, 09:20 AM   #11317
docwhorocks
Member#: 13772
16 Frontier
Red
A Humx plug solved my ground loop hum.
https://www.amazon.com/Ebtech-Hum-Pl...s%2C240&sr=8-2
Was $25 cheaper 4 years ago when I got mine. And it's only good for devices up to 6A.
docwhorocks is offline   Reply With Quote
Old 02-23-2021, 09:50 AM   #11318
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
Through my research over the weekend I was reading hundreds of pages of findings by the Audio Engineering Society. Not only does the Hum-x not have sufficient amperage to support my amplifier, it isn't UL listed and is an inherently unsafe design. It really isn't much better than using a cheater plug.
https://centralindianaaes.files.word...notes-v1-0.pdf
Old 02-23-2021, 11:05 AM   #11319
Strider
Visiting NASIOC Timeout
Member#: 2197
an inconvenience,
properly considered.
I don't play this often because it's 2 discs at 45rpm, which means getting up to flip sides or change records every 10 minutes. Worth it though.
Strider is offline   Reply With Quote
Old 02-23-2021, 11:41 AM   #11320
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
still digging the MA's?
Old 02-23-2021, 12:26 PM   #11321
aod
Member#: 7121
For anyone who has a wired whole house audio setup, this is worth checking out:
https://www.kickstarter.com/projects...em/description
I jumped on backing one along with a zone extender because I have 8 zones in my house. This is something I've been looking for since I moved in here. Right now there is just the typical zone switch and its an all or nothing kinda deal as far as audio source. It will be nice to be able to pick a different source per zone or group of zones (up to 4 different sources). Also having a dedicated amp per zone will be nice as well.
aod is offline   Reply With Quote
Old 02-23-2021, 06:11 PM   #11322
Strider
Member#: 2197
an inconvenience,
Love em, they'll last me quite a long time. I'd love a big ass pair of old Tannoy speakers, but that's not realistic for another 10 years or so.
Old 02-25-2021, 09:31 AM   #11323
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
I have on order:
Yeah I’m not sure I “believe” my conditioners are providing better sound, but I do utilize them for power distribution and surge protection, though I too have a whole house surge protector installed as well.
Hopefully your new stuffs will solve it. A buddy of mine runs one of these to solve a hum issue he had:
https://www.psaudio.com/products/noise-harvester/
Old 02-25-2021, 09:32 AM   #11324
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Sweet! New speakers too huh? Foxy!
Old 02-25-2021, 09:59 AM   #11325
Strider
Member#: 2197
an inconvenience,
Picked up those Monitor Audio Silver 500's a few months ago, they're ridiculous. Got a copy of Moby - Play on vinyl the other day and Body Rock has some ass rumbling bass in it. Can't play that one without the neighbors getting pissed.
Gave my old standmount Deftechs and 8" sub to a friend for his basement/office turntable system.
The official Post pics of your Home Audio/Video setup? V2.0 GRUMPY514 Off-Topic 74 07-30-2008 09:50 AM
VA: Home Audio/Video/Game AspenWhite Non-Subaru Stuff 5 03-06-2007 09:43 AM
WRX parts, home Audio/Video stuff, and more... NicFunkadelic NESIC Private Classifieds 6 02-15-2007 10:38 AM
Home audio/video wiring gurus, need a bit of help. trail*of*dead Off-Topic 16 12-23-2006 02:25 AM
Home audio/video goodies for sale! Tivo! Replay! Pronto! BiggSean Private 'For Sale' Classifieds 7 02-26-2006 11:15 PM
