#1 |
Member#: 141043
Vehicle:2011 STI black af |
![]() So as you all know, we released a header a couple months back... The main feedback we got was "how much power does it make compared to ________" , or something along the lines of "looks awesome, but how do I know it will make power ?". I am pleased to announce that question and then some have been answered.
Our friends over at Street Car factory in Arizona got a couple of these headers and did some testing the results... well the results F*****G rock. The first test car we did testing on was a 2008 WRX Hatchback (next test will be on a big turbo car) the mod list is as follows: 2008 WRX Hatchback Built Stage 2 SCF Short Block Stock Heads 04 STi 6 speed Speed Density TurboXS FMIC Stock Inlet Sized, internal Wastegate FP Green Cobb v3 MAP 4-1 Header Agency Power Up Pipe ID1000s DW300 Fuel Pump ![]() ![]() ![]() Here's a side by side comparison with the MAP ELH vs AP ELH (one of the best on the market). We gained about 70whp throughout the powerband and 500rpm in spool time with the MAP ELH vs the Agency Power ELH and a new peak gain of 34whp. This header nets more power than almost any other ELH on the market and has a much more responsive power-band. I'm at a loss for words, I didn't expect that significant of a gain. The mods on the car are simple and this header really makes it come alive!!! first graph with the agency power header: ![]() second run with the headers swapped out to our MAP Ej Series EL Header. ![]() The results speak for themselves here folks! For those who don't know about our header here are some features:
Pick up a set now by shooting us a pm or giving me a call direct 651-348-8811 ext 108 Current early adopter pricing on this header is $900, retail is $999.99, they are built in house and almost always are stocked but if they aren't don't worry our world class welders can crank these out in about a week to a week and a half! ![]() Pick your set up now in time for the upcoming race season! -Leo
#2 |
Member#: 47143
![]() Can you show a pic of the inside of the merge collector?
#3 |
Member#: 452989
![]() I want it tested against Killer B Headers. Convince me to make the switch.
#4 |
Member#: 259184
Vehicle:2008 Subaru WRX Silver |
![]() how does this even compare to killer b then?
#5 |
Member#: 78751
SCIC
Vehicle:2017 Sti ISM |
![]() no tuning at all? just header swap in regards to comparison? same day? same temp?
If so, outstanding results. |
#6 |
Member#: 137405
Vehicle:2011 WRX 6spd GTX3076r |
#7 |
Member#: 271525
Vehicle:7/2 STi/WRX wagon SWP/AW |
![]() So I'm interested in why this header would gain "more power than any other EL header out there" when it is basically a copy of what is already available. Both this design and the Perrin redesign have copied the Killer Bee primaries and have a less efficient collector. I don't buy that this will make more power. Since no one does true independent, back-to-back testing with the exact same car on the same dyno on the same day with the same tuner with competing products, I guess you're free to claim what you like, but by looking at the product it obviously doesn't offer any magical advantages.
#8 |
Member#: 296411
Vehicle:2011 4dr STi SWP |
![]() I have the perrin E4 series newer headers. I don't see why these would make much more power but they do look like a nice option
#9 | ||
Member#: 239335
W. Canada
Vehicle:2011 WRX WRB |
![]() Quote:
#10 |
Member#: 201736
Vehicle:12 IS-F Sold!! :( 07 STi...SOLD :'( |
#11 |
Member#: 78640
Vehicle:19 Tundra 20 Landcruiser | 12 IS-F |
![]() Agency Power is one of the best headers on the market?! LOL! Probably one of the worst EL headers available.
Can you explain the process between the AP testing and MAP testing? It looks like the engine being dropped in already has the MAP header on it, did you swap the AP back on for testing after or was the AP graph on the old engine (what I'm assuming). |
#12 |
Member#: 64908
Vehicle:10.8 [email protected] GR+ 9.1/157mph 2015 STI |
![]() Can you post the graphs in MPH overlayed instead of RPM? Looking at the graphs I am willing to bet that the non MAP header test is done in 3rd gear vs the MAP header in 4th gear which will easily gain 500 RPM of spool up. The next thing I will mention is how bad the spool up is to begin with. A FP Green on E will hit peak TQ around 4-4500rpm, not 5500rpm... I can post up the graph like I did on the FB post.
Either way the testing is very skewed. Jr |
#13 | |
Member#: 239335
W. Canada
![]() Quote:
#14 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
![]() The spool difference is probably what jr said gear wise. The late tq is probably just the tuner being safe or not knowing what's going on.
I could see it making power and tq over a cheap header but it's highly unlikely over a great header that it's picking up any power or tq. If it was a super small primary setup I could see it spool better but make less power. |
#15 | |
Member#: 239335
W. Canada
![]() Quote:
Even then, picking up that much power over any equal length is nuts when KB Header doesn't pick up that much over an OEM UEL. ![]() |
#16 |
Member#: 447549
Vehicle:2015 WRX 6MT Premium CWP |
![]() Sounds like myth busted to me.
#17 |
Member#: 170602
![]() Yeah quite a few variables that could skew results! And yeah thats true about the huge gains
#18 |
Member#: 273868
![]() 70 more hp
gtfoh |
#19 | |
Member#: 141043
![]() I would be happy to send you a free manifold for you to test, so you can create any kind of made up results you want. Good or bad...Let me know!
#20 | |
Member#: 64908
![]() Quote:
Ill go with not knowing OR the car has a problem. |
#21 | |
Member#: 141043
![]() You were offered a free header for testing...So you can decide weather or not to find out the truth...
#22 | |
Member#: 64908
![]() Quote:
IF** You sent one to Prime for testing, and the results where mediocre the underlined portion of your reply tells me how it would work out anyway. I'll ask D if he wants to take you up on the testing though. Nothing wrong with coming to market with a "new" product, its the way you advertise/test it and post up BS that is the issue. I'm all for betterment of the platform, but lets try and be truthful about it. Jr |
#23 | |
Member#: 141043
![]() I would be happy to send one to Prime at no cost. I know you are not fond of us, and that's fine. But the point of this isn't to provide "skew" numbers at all. We would be happy to get third party testing in able to provide positive criticism to our products so we can improve them. Nothing more, nothing less.
#24 |
Member#: 230730
E. Canada
Vehicle:05 FXT 18GXTR black |
![]() Maybe 3 bolt option ?
#25 | |
Member#: 64908
![]() Quote:
ATT: Jrtuned 33 Curie Ave Wallington NJ 07057 |
