05-14-2009, 02:47 PM | #1 |
Member#: 173774
Vehicle:2008 STi Lightning Red |
Newb to E-85, what is needed to run ethanol?
First, the obligatory apology for asking something that may have been covered ad nauseum.
Ok, a quick google maps search reveals quite a few E-85 stations in my area. I'm quite surprised it is this prevalant (Albany, NY region). I know the general pros/cons of running it, and understand the basics. But I'm still a bit unclear what would be required to run say, a stage 2 08 STi on E-85. I know our injectors and pump a slightly uprated from 07 and prior, but enough to support E-85 fueling? Ideally I would have 2 maps at my disposal, a 93 octane and an e-85. And for those who do/have used e-85 to make modest stage 2 type power... is it worth the effort?
05-14-2009, 03:23 PM | #2 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Rescale your injectors by flow*.66, probably need to adjust tip-in as well.
You'll require about 20-30% more fuel, which means 650-700cc or larger for a stage 2 STi, which means no stock injectors. A walbro 255 would be fine for stage 2. |
05-14-2009, 03:28 PM | #3 |
Big Ron
Super Moderator Member#: 18062
http://forums.nasioc.com/forums/showthread.php?t=803341
Please search next time. Is it worth it? We really don't know as that's a personal opinion and those will run the gamut from OMFGBBQ YES!!! to you'll put your eye out. |
05-14-2009, 03:29 PM | #4 |
Member#: 159454
SWIC
Vehicle:2006 WRX CGM 6SPD Cornfed GT30R |
I'll be running a 3076 .82 and plan on e85. I have the bosch 1000cc's. With the fuel pump controller on my car, what options do I have when the walbro can't supply enough fuel?
05-14-2009, 03:32 PM | #5 |
Member#: 51961
RMIC
Look into the Buschur dual pump setup
05-14-2009, 05:25 PM | #6 |
Member#: 90436
SCIC
Vehicle:2005 STI Obsidian black pearl |
man that e85 faq is old, information from 2005 and most recent from mid 2008.
From what I saw in the faq thread you only need larger injectors and a re-tune to run e-85, no other modifications neccessary. |
05-14-2009, 05:54 PM | #7 | |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
The pain in the ass part is wiring up the fuel pump...anyway, go to Built Motor Discussion and read about it. That should answer all questions. http://forums.nasioc.com/forums/show....php?t=1754552 http://forums.nasioc.com/forums/show....php?t=1702099 |
Where to get what is needed to put foglights in 04-05 RS??? | Bamboorex | Electrical & Lighting | 8 | 11-01-2009 07:16 AM |
What is needed to run a Green? | Irishman | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 28 | 05-11-2006 10:52 AM |
What is needed to go from 235whp to 285whp | Twenty36_1 | Proven Power Bragging | 26 | 03-17-2006 12:24 PM |
so what is needed to run 20 psi on a daily driver | turbocolin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 02-04-2005 10:47 PM |
What is needed to build rally car? | SAM_463 | Motorsports | 14 | 03-27-2001 01:37 PM |
