Vancouver Impreza Club
Old 06-02-2013, 06:53 AM   #26
DIGGYGV8
Member#: 313558
2011 STi Sedan
Originally Posted by lymphomaniac View Post
Found and confirmed by another user with the MY12 2.0i. Below is the quote from the relevant post in the thread:
I presume the MY13 operates in the same manner (see rationale in my previous post re: a/c disable for defrost vent setting).
Perfect,
Added to compatibility list.
DIGGYGV8 is offline   Reply With Quote
Old 06-02-2013, 03:27 PM   #27
ap3x
Member#: 356238
JDM bunta's car
Great thread idea!
A little off topic but does anyone have a link for a GC chasis?
Thx in advAnce
ap3x is offline   Reply With Quote
Old 06-02-2013, 09:22 PM   #28
DIGGYGV8
Member#: 313558
2011 STi Sedan
Originally Posted by ap3x View Post
Great thread idea!
Thx in advAnce
Sorry, I don't own a GC. If you care to buy me one, I will make a thread for it :P
Old 06-03-2013, 11:26 AM   #29
ap3x
Member#: 356238
JDM bunta's car
Haha lol i was just asking if anybody knew a link that already exist somewhere around the forums.. And yes i already did a search
Old 06-03-2013, 11:42 AM   #30
DIGGYGV8
Member#: 313558
2011 STi Sedan
I've seen them around several of the forums I used to frequent. I think it's an awesome idea, especially since we all share a fairly similar car (thanks Subaru :P)
Feel free to contribute, some tips/tricks are quite cross-generational/cross-platform. I may just make this into a general KB thread.
Old 06-03-2013, 11:43 AM   #31
aawen
Member#: 27167
2015 FXT
FYi I tested on my 09 sti with sport-tech, disable seatbelt chime/detection trick works!,
Sweet trick
aawen is offline   Reply With Quote
Old 06-03-2013, 11:52 AM   #32
DIGGYGV8
Member#: 313558
2011 STi Sedan
Sweet trick
added compatibility to the list. Thanks! :P
Old 06-03-2013, 11:55 AM   #33
DIGGYGV8
Member#: 313558
2011 STi Sedan
Originally Posted by fujiwara_yingyu View Post
This only work for subaru, do not try on mitsu. lol.
Why? do your airbags blow up when you do this?
Old 06-05-2013, 12:08 PM   #34
DIGGYGV8
Member#: 313558
2011 STi Sedan
Default Disable Hill Assist
Old 06-05-2013, 01:05 PM   #35
Neilm
Member#: 345975
2013 wrx STI
white
^ or you could just lift the e-brake for a quick on/off and it automatically disables it..
Neilm is offline   Reply With Quote
Old 06-05-2013, 01:59 PM   #36
DIGGYGV8
Member#: 313558
2011 STi Sedan
Write it up :P
Old 06-05-2013, 03:10 PM   #37
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
I'm having doubts about the a/c disable for MY 12+ 2.0i models. I tried it again today, and could not conclusively determine if the system had disabled itself.
lymphomaniac is offline   Reply With Quote
Old 06-05-2013, 03:19 PM   #38
DIGGYGV8
Member#: 313558
2011 STi Sedan
test it on your car by having A/C enabled, press the button to disable, wait for 10 mins or so, re-enable manually, and listen for the compressor/relay click. Open your window, and park inside a parking lot if you have to.
Old 06-05-2013, 04:24 PM   #39
belaud
Member#: 224449
2012 Kit B STI
Midnight ???
For those that know but are not sure about the problem.
Stumble Fix under acceleration for GR/GV STI
Disclaimer: This is more than clicking your seatbelt or resetting your ECU, it may permanently damage your engine or fueling system if done incorrectly.
Problem:
This is the most prevalent issue with GR/GV STI's, our fueling system creates a water hammer pulsing effect which makes the car run lean and stumble from 2.4k-3.1k RPM (vehicle specific) during a light/WOT acceleration. For those that use OST, you may also notice your check engine light comes on if you cruise between 2.8k-3k RPM in 6th gear more than a few minutes with the code being P0171 of "Lean on Bank 1/2" or P0296 "Post catalyst fuel trim system too lean" . This will also fix that issue.
Solution:
By lengthening our fuel line, it disrupts the pulse in the loop, creating a much smoother fuel delivery to the engine.
This guy will do a much better job at explaining than I ever will, pictures included.
Tested Compatibility
- MY09 STI
- MY10 STI
- MY12 STI w/ SPT Package
Worked for 3 cars, all with the same effect of fixing the stumble.
belaud is offline   Reply With Quote
Old 06-05-2013, 05:08 PM   #40
DIGGYGV8
Member#: 313558
2011 STi Sedan
Problem:
Solution:
Personal Conclusion
Worked for me, I had this problem under WOT as well as light load, difference was night & day, as the guide mentions, be sure to reset your ECU or if an AP is available, retune the two maps as shown. The full benefits will not show unless you retune as opposed to resetting.
Please change notation to follow syntax of above KB articles (headings/information syntax), I'll add link to the first post once changed (also, whatever you'd like to title article). All KB articles, should not contain unnecessary information/personal opinion.
WARNING: For anyone thinking about this mod (I personally don't have it, after STGII + protune but some of you may) consider that you may have to be retuned or you will run lean in the higher rev ranges due to the extended length of the fuel line. This is not only to reap the "benefits" but also to protect your car during those higher ranges.
This issue is also not usually noticed w/ stock setups, and and if observed stock, should probably be a warranty item you can take up with your dealership.
Old 06-05-2013, 05:32 PM   #41
belaud
Member#: 224449
2012 Kit B STI
Midnight ???
Fixed syntax
This will not make your car run leaner with the added fuel line, you're adding 3ft, not a mile. Just be sure to prime the lines before starting the car. The car will correct itself with a reset ECU, and run even better with corrected maps.
For those with stock cars with this issue, it is not a warranty item, but a design flaw, you have the option of doing the mod, but is best to bring it to the dealership.
Old 06-05-2013, 05:56 PM   #42
DIGGYGV8
Member#: 313558
2011 STi Sedan
Fixed syntax
Again, "may have to be retuned or you will run lean in the higher rev ranges due to the extended length of the fuel line."
YMMV.
That aside, added to list of KB articles. Credited.
Old 06-13-2013, 01:54 AM   #43
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
Sorry, Bud. Confirmed that MY 13 2.0i will not allow me to disable a/c on defrost mode. I tried it this evening, and there was definitely something bogging down the engine even after I tried to turn the a/c off. Either something else is running in the background (in addition to a/c) while on defrost, or the a/c didn't disengage. I'm thinking it's likely the latter, given the cold air blowing out of the vents.
Since MY 13 2.0i is just a re-badged MY 12 2.0i with minor edits, I suspect the same holds true for MY 12 2.0i.
Old 06-13-2013, 08:28 AM   #44
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
Regarding the hill hold function, i don't understanding what is the issue you are experiencing?
For me, it only holds for 1-2 sec on a hill, then it will roll back. It allows just enough time to take your foot off the brake pedal and move to the throttle and give gas. Then, it usually takes off smoothly. If you are really quick, then you might just end up rev-ing the car a little before taking off, which sounds fine to me. If you use the e-brake method to hold the car, you will end up with the same result (slighting rev-ing it before releasing the e-brake for take off).
I guess I'm just trying to understand what do you mean by the car would still apply the brakes after you take off. Do you see your brake lights on or something?
KIMUTAKU is offline   Reply With Quote
Old 06-13-2013, 08:37 AM   #45
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
Does anyone know a way to get around the A/C automatically turning on at "Auto"?
Most of the time I just want to go from "Fan off" to "Fan on" and I don't want the A/C on. But if you own a GR/GV, you know that the "Auto" function is the first choice on your dial. I find it pretty annoying having to manually turn the A/C off everytime I want to just have the fan blowing.
Thanks!
Old 06-13-2013, 02:42 PM   #46
DIGGYGV8
Member#: 313558
2011 STi Sedan
nope, but anyone's who decently quick to engage, will notice a small braking sensation.
Thanks!
this is only if you have climate control. if it's turning A/C on right away, then you need to change the vent position to something other than front defrost, OR just manually disable A/C as per the KB.
Old 06-13-2013, 02:45 PM   #47
DIGGYGV8
Member#: 313558
2011 STi Sedan
removed compatibility for now.
Old 06-14-2013, 02:27 AM   #48
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
Still showing, Dude. I think you may have accidentally removed the seatbelt chime thingy compatibility by accident.
And, just to show that reading the ****ing manual actually does work from time to time, I present to you the following excerpt from the 2.0i manual:
Originally Posted by The Holy Book, Page 4-11
For type A climate control system, in this state: [that is, the state of being in defrost vent mode with the a/c compressor operating]
-- You cannot stop the air conditioner compressor by pressing the air conditioning button.
-- You cannot select the recirculation mode by pressing the air inlet selection button.
Whodathunk that reading the ****ing manual would be so ****ing logical?
I need new glasses.
Old 06-14-2013, 03:51 AM   #49
DIGGYGV8
Member#: 313558
2011 STi Sedan
I need new glasses.
That's what I get for trying to edit on my phone.
Wow @ that manual tho.
Old 06-26-2013, 08:39 PM   #50
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
For MY07 impreza 2.5i, to disable the seatbelt chime you need to have the car running, in/out the seatbelt 20 times, then turn off the car, remove key and start again.
thesniperz is offline   Reply With Quote
