Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 07-08-2020, 12:22 PM   #1
Emoss704
Member#: 516525
Default Gas wont fill, pours out of filler neck.
Just bought this 08 Impreza last week, needed head gaskets. Replaced headgaskets, not overheating anymore but I tried filling gas up yesterday and the pump stopped, then I noticed there was gas overflowing out of the tube. It's definitely not full because the gas lights on and guage reads E. I can't find much online and this is starting to get irritating. Also yesterday the check engine light came on for P0340 (cam postion sensor), and the battery light comes on intermittently not sure if these are both symptoms to a larger problem (EDIT: also forgot to mention the car is now in limp mode with cruise and traction control lights flashing). The car had no dash warning lights prior to head gasket replacement, don't know if the gas issue was pre-existing. I had it towed for head gasket repair immediately after purchase.
Emoss704 is offline   Reply With Quote
Old 07-08-2020, 12:37 PM   #2
Stretch18
Member#: 239822
2010 WRX
pandiculation
The fuel filler issue has to do with the evap solenoid. It's probably stuck and needs replacement. The cam position issue is separate.
Stretch18 is offline   Reply With Quote
Old 07-08-2020, 01:58 PM   #3
Emoss704
Member#: 516525
Do I have to drop the tank to do that job? I was under the car yesterday and didn't seem like theres too much accessibility to any tubes or lines going to the fuel tank
Old 07-08-2020, 11:43 PM   #4
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
The vent valve may be bad.
08SpecB_DE is offline   Reply With Quote
