Old 08-13-2020, 09:30 PM   #76
Juan Ma
Member#: 247861
2004 FXT
Gold
Installed a Ball Bearing Arashi 20g. Today during tuning the turbo was overboosting to over 25 plus punds. Not sure why because according to specs, the turbo has a 1.1bar actuator on it, which equates to 15 psi. Is it possible an incorrect spring was used?
Juan Ma is offline   Reply With Quote
Old 09-10-2020, 12:21 AM   #77
splitoris
Member#: 433063
How’s everyone’s holding up?
splitoris is offline   Reply With Quote
Old 09-10-2020, 08:53 AM   #78
kingsalami
Member Sales Rating: (9)
Member#: 206257
2009 WRX 5-door
OP here. Still lovin’ it @ 146K miles.
kingsalami is offline   Reply With Quote
Old 09-12-2020, 12:12 PM   #79
Jchustla
Member Sales Rating: (11)
Member#: 116284
2006 STi
RBP
Been running mines now for 3+ years 30K+ miles with no issues.
Running EWG and meth injection at 24 psi making 415 whp and 380 wtq Dynojet (I have seen 440whp and 390 wtq on road dyno on a much cooler night).
Turbo is about capped out there in terms of efficiency.
Jchustla is offline   Reply With Quote
Old 09-13-2020, 02:46 AM   #80
splitoris
Member#: 433063
Tuner says to go with td05 20g as td06sl2 is laggy for 350whp
But what about the ball bearing td06sl2?
Old 09-14-2020, 04:51 PM   #81
Jedi03
Member#: 491095
2009 STi Blue
i have the journal bearing with 11 blade exhaust and its about as responsive as the stock vf48...when it goes i am going to do the same turbo ball bearing and would expect it to spool a little better!
Jedi03 is offline   Reply With Quote
Old 10-01-2020, 10:30 PM   #82
Deadeye22
Member#: 479539
I had Ball Bearing TD06SL2 20G and now I have TD05H 20G, about 250RPM difference is spool on EL headers
Deadeye22 is offline   Reply With Quote
Old 10-05-2020, 05:33 PM   #83
Timmer24
Member#: 519150
Weird
Timmer24 is offline   Reply With Quote
Old 10-07-2020, 01:57 PM   #84
Jedi03
Member#: 491095
2009 STi Blue
do you prefer the 5 or 6? And on EL i agree the spool is much better!
Old 10-21-2020, 12:06 PM   #85
lowbee
Member#: 254317
2011 STi
Just making sure I am reading this right, so you are saying your current TD05-20G spool 250rpm faster than your previous TD06SL2-20G ?
lowbee is offline   Reply With Quote
Old 11-28-2020, 10:50 AM   #86
saaiello21
Member#: 501997
gray
Been running my td06 sl2 20g now for about 20,000 miles now all in all great turbo for the money. Took me a little to get used to driving it with the lag at first, but once your able to keep it in that sweet spot with your shifts its a beast. I am thinking about switching out the compressor housing to a 3in anti surge style to see if it helps it with lag will update this thread if I do.
saaiello21 is offline   Reply With Quote
Old 11-28-2020, 12:02 PM   #87
lowbee
Member#: 254317
2011 STi
Originally Posted by saaiello21 View Post
.......Took me a little to get used to driving it with the lag at first.....
I see you're running this turbo with a 2.0 engine. How many psi are you boosting ? What is your boost pressure at 3500 rpm? 4000 rpm ? Just trying to get a sense on how boost build with this turbo. Thx.
Have you consider swapping out the journey bearing cartridge with a KBT bolt-on ball bearing to help with spool, I think Arashi offer this as an option.
Old 11-28-2020, 01:26 PM   #88
saaiello21
Member#: 501997
gray
Originally Posted by lowbee View Post
I see you're running this turbo with a 2.0 engine. How many psi are you boosting ? What is your boost pressure at 3500 rpm? 4000 rpm ? Just trying to get a sense on how boost build with this turbo. Thx.<br>
<br>
Have you consider swapping out the journey bearing cartridge with a KBT bolt-on ball bearing to help with spool, I think Arashi offer this as an option.<br>
<br>
<br>
<br>
<br>
This on a 2.5l fully built with FMIC it hits 21psi at 3700 sometimes a little earlier depends on my driving. Will definitely hit higher boost but my trans will definitely not handle what this turbo has potential to do. Holds my 19 psi I have it set at til 7000 rpms no problem and pulls great. I stuck with a journal style turbo for reliability I drive too many miles to have to worry about rebuilding turbo every 20,000 miles
Old 11-28-2020, 02:47 PM   #89
lowbee
Member#: 254317
2011 STi
.....I stuck with a journal style turbo for reliability I drive too many miles to have to worry about rebuilding turbo every 20,000 miles
Is this statement based on personal experiences ? Or is this type of failure specific to Subaru or a particular brand of turbo ? I ask because a quick Google didn't show a lots of hits.
If this is a concern, check out RHB turbo in Canada. They have a patented triple ball bearing design that float on oil film that might just be the best of both worlds.
https://rhbturbochargers.ca/pages/fu...e-ball-bearing
Old 12-06-2020, 09:58 AM   #90
Seangraz
Member#: 518909
For anyone that’s ordered a turbo from arashi how’d it go and how was communication. I’m trying to order one right now but having a lot of problems. Their website is having issues and I’ve gotten a few messages back and forth through Instagram dms, I’ve sent multiple emails but nothing in response. Any tips?
Seangraz is offline   Reply With Quote
Old 12-06-2020, 06:41 PM   #91
Jedi03
Member#: 491095
2009 STi Blue
Just did a little research on the dsm site, td05 spools faster an td06 has more topend
Old 07-13-2021, 11:49 PM   #92
RaneShines
Member#: 467649
Originally Posted by Nightwingthief View Post
Hi there, How is the turbo holding up. I too am considering one of their TD05 G25 660 units.
Did you end up going with the g25 660? I'm curious. I have tried to contact arashi but they can't tell me flow rates. I saw kinugawa had a similar turbo listed as a 61 lb/min but nothing on arashi.
RaneShines is offline   Reply With Quote
Old 07-20-2021, 08:50 PM   #93
Juan Ma
Member#: 247861
2004 FXT
Gold
Default Horrible, Dont Do It If You Like Your Car
I have an Arashi 20G Ball Bearing that has been in the car less than 8 months and it arrived with a bad internal wastegate, which I found out the hard way when the car was strapped in a dyno and was already with the tuner.
Also, both turbine wheels broke the blades and the cartridges went boom, leaving me stranded on the highway with an inmense white smoke cloud when the entire oil of the car spilled into the DP and the exhaust, thankfully at the mercy of a tow truck.
Horrible experience. Stay far away. Btw, my car was properly and professionaly tuned by an experienced engineer at only 16psi.
Thankfully, from what I know the blade fragments have not reached the cylinders.
Old 08-11-2021, 07:35 AM   #94
Mindriddle
Member#: 491668
Im on this thread because I saw someone selling this turbo new on fb. Glad I read this. They are wanting 775 shipped.
Mindriddle is offline   Reply With Quote
Old 09-17-2021, 08:23 AM   #95
Nightwingthief
Member#: 515291
My Arashi TD05 20G has been on the car now for a year running 1.5bar boost and is perfect, we turned it up today to 1.7 bar and the thing is insane!!!! most happy
It replaced the FP green that was on the car.
1 : its better built than an FP
2: Its on par with a Blouch as we had both side by side and opened up.
This is not a "knock off"
https://ibb.co/F3gvTjq
Nightwingthief is offline   Reply With Quote
Old 12-04-2021, 07:15 PM   #96
Tizzy
Member#: 527771
Hey man! Love this forum, hows the turbo holding up? or anyone else that sees this, hows yours holding up? I recently purchased the Arashi spec C td05-20G (Journal bearing for longevity) and noticed no one else has really reviewed the twin scroll variant of this turbo. But it cannot stray far from the experience i have read about up until now. When im able to get it in and have all supporting mods up to par, i will update about spool times and what my tuner is able to push this thing too.
Other Specifics: 52.5/68mm Cold side (GTX 11 Blades) Compressor Wheel
49.2/55.8mm Hot Side (9 Blades) Turbine
Fairly certain those are just the standard specs when ordering but if anyone was to compare that is exactly what is is.
Tizzy is offline   Reply With Quote
