Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
12-05-2017, 09:07 PM | #1 |
Member Sales Rating: (42)
Member#: 234907
Vehicle:2002 wrx wagon mbp |
Va: 02 wrx wagon
Listing my 02 wrx wagon. I have decided it's time to move on from it and let someone else finish it up. Body and engine have right at 200,000 on it. ( have to find some papers to get correct mileage. Cluster was swapped.) It does have some rust in the rear quarters on both sides. I will be adding that pic tomorrow. It does have a small oil leak around the turbo area. Stock engine and turbo.
On to the goodies. Engine : css front mount Aps short ram Turboxs bellmouth downpipe Blitz nur spec car back with an additional resonator installed. Cobb v3 accessport Aftermarket radiator Transmission : 04 wrx trans. Mach V swapped in a Lgt 1/2 gearset Southbend stage 2 clutch Comp clutch lightened flywheel Braided stainless clutch line Suspension : Tokico does with prodrive blue springs Strut tower braces Kartboy rear endlinks 02 sedan rear sway(not installed) Lgt front brakes H6 rear brakes Interior: 04 sti front seats, carpet, console, steering wheel, door panels, rear seat bottom. I have an 04 rear top seat cover over the top rear seats. Blue suede headliner to match( starting to come a little unglued) Jpm coachworks shift boot Cobb double adjustable short shifter Anarchy motiv shift knob Kenwood double din dvd/nav Infinity door components Prodrive cluster Defi Bf series oil temp, oil pressure, egt, and boost with controller, clock pod, and subigal pod Exterior Sedan front fenders and bumper Turn in concepts cowl braces Spec c roof vent Jdm window visors Saab roof rail deletes Jdm replica hood scoop Jdm sti wagon grill Con10der8 rear diffuser Edm rear tail with fog light Yellow tinted fogs Depo Jdm replica headlights Sti side skirts Hella sharp tones 18x8.5 ssr gt2 wheels with Yokohama tires with over half tread I have the following parts to go with: 2.5 short block with arp head studs, acl race bearings, sti crank and rods, 100 mm forged mahle pistons, killer b windage tray and oil pickup. All 0 miles assembled by Abacus Racing in VA beach 2.0 heads. Valve job and seals, mild Port, 0 miles also, assembled by Walter's Precision Engines in Roanoke, Va Both sides sedan rear quarter panels, both rear sedan doors. 18g turbo(was told it was a forced performance) deutchworks nodded 740 injectors, New timing set, kartboy lightweight crank pulley, new rear timing covers, beatrush skid plate, grimmspeed radiator and alternator covers, group n engine and trans mounts, used group n front top hats. Prodrive replica front lip, also have a V limited lip, perrin up pipe, gruppe s header, aem wideband I will add more as I go thru everything. Car is located in Buena Vista, Va I am looking to get $7500 as a package deal for everything I have. I just dont have the time or place to finish it up. It does have a few dings and scratches. Please ask any questions, pm me if needed. Thanks for checking it out.
