#1 |
Member#: 117749
![]() I got a exedy twin plate clutch at about 15000 miles, got 29000 miles on it now its fn toast. after only 11000 miles on the clutch and it's toast, that's rediculous. tried bleeding the clutch system to see if that was it. no that's not it. tried adjusting the clutch, well im adjusting it every half day now. i can hardly get the car into gear, and when i do a fourth gear pull my rpms skyrocket like a madman on a sugar high at about 4200 grand just when i build full boost, and let's not even talk about 5th gear, it's slipping like a mo fo. the car only has like 350 ft/lbs of torgue and has been taken to the track once. what a piece!!!
#2 |
Member#: 139645
Vehicle:07 WRX UGM |
![]() Im going Carbonetics if i can. They offer better performance all round than the Exedy units.
#3 |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
![]() I had a stage2 burn up in 10k, I switched to clutchmaster and have been happy since, and i had to put in a new flywheel too since the exedy was completely heat soaked.
#4 |
Member#: 39149
![]() Maybe improper install?? I have installed quite a few twin disc's without issues. One customer has 100+ mid to low 11 second passes on his and it is still going strong.
#5 |
Member#: 102140
South East
Vehicle:2016 Single Speed or Death |
![]() Maybe you ride the clutch.
my exedy has lasted 15k miles, and its a 6puck. And its been to the strip. |
#6 |
Member#: 117749
![]() no, i don't ride my clutch at all! I don't understand it. does anyone know the warranty on exedy clutches?
#7 |
👏 Big Ron 👏
Moderator Member#: 18062
![]() Warranty on Exedy?
![]() I know a guy that totally slicked an Exedy hyper single in ONE DAY. He wasn't putting out but 50-60***37; of it's rated torque holding power. The flywheel was the prettiest shade of blue you've ever seen. Warranty???? Not so much. |
#8 | |
Member#: 39149
![]() Quote:
#9 |
Member#: 124938
![]() yea, no **** , break in your clutch properly and it will last forever. I bought an Exedy heavy duty clutch and PP for a previous car adn it lasted about 40 or more track outings, plus regular beatings. kid i sold the car to has driven it for 2 years and put 80,000 KM's on it and its still going strong. maybe you just got a bad one
#10 | |
Member#: 117749
![]() Quote:
#11 | |
Member#: 39149
![]() Quote:
#12 |
Member#: 124938
![]() is triplpe disc like a Tilton or something?
#13 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
![]() do you know if the installer removed the valve in the slave cylinder? if not then theres a very good chance that was the problem. i installed a hyper single in my FXT 6 speed swap and it worked great. installed a hyper twin in a customers car and he is having great results with the superzilla turbo from DB.
whatever you switch to make sure the relief valve is removed. or you will smoke another clutch Tom |
#14 |
Member#: 117749
#15 | |
Member#: 117749
![]() Quote:
#16 |
Member#: 124938
#17 |
Member#: 67
SCIC
![]() the valve is in there to keep you from completely dropping the clutch. If they are left in the Exedy( others probably) you will slip the clutch and most likely burn it up in no time.
Tom |
#18 | |
Member#: 117749
![]() Quote:
#19 |
Member#: 101691
Vehicle:97 Supra TT SOLD - 35r bug/hawkeye |
![]() how do you remove the valve in the slave cylinder?
#20 |
Member#: 120461
BAIC
Vehicle:2004 WRX STi JBP |
![]() is the valve removal necessary for street clutches such as exedy stage 1 or act street?
#21 |
Member#: 117749
#22 |
Member#: 67
SCIC
![]() i dont really know about the ACT's i had one in my RST and wasnt a fan of the high pressure plate. but thats just my opinion. for the stage 1 exedy you should be fine. the valve is in there so you want hammer the clutch and shock the tranny. i believe subaru started to put these in late 02 since everyone was killing the trannys. pretty much all you need to do is unscrew the two halves of the slave cyl and pull the guts out.
Tom |
My Car Is A Piece Of Crap | StangGrl | Off-Topic | 58 | 11-09-2005 02:15 PM |
What is the biggest pro/con of more caster? How much is too much on a WRX suspension? | rex n effect | Motorsports | 6 | 06-20-2004 11:05 AM |
Just found out my car is a piece of crap! | Corn-Picker | Off-Topic | 44 | 06-16-2004 10:34 PM |
why yes... it is | front | Mid West Subaru Owners Club Forum -- MWSOC | 6 | 01-22-2003 03:34 PM |
Why are DVD drives such pieces of crap? | StankFootZ | Off-Topic | 18 | 11-03-2002 12:42 PM |
