09-25-2021, 06:05 PM | #26 |
Member#: 514856
Vehicle:2007 Subaru STi ltd urban grey metalic |
Installed some new shoes, these wheels are 18x9 +35 Kansei KNPs in textured bronze. Tire specs are 245 with a 45 side wall. They ended up looking pretty beefy in photos but in person they’re pretty flush and there’s not a ton of poke.
10-06-2021, 06:58 AM | #27 |
Member#: 526854
International
Vehicle:2016 WRX S4 Red |
Hot subie)
11-28-2021, 03:05 PM | #28 |
Member#: 514856
Some pictures from the local C&C
11-28-2021, 04:49 PM | #29 |
Member#: 145105
Vehicle:2015 Honda Accord |
Looks good!
12-26-2021, 11:26 PM | #30 |
Member#: 514856
Installed some alcantara shift and parking brake boots.
01-11-2022, 01:40 AM | #31 |
Member#: 180155
NWIC
Vehicle:05 Jdm Sti 2.0 PSM |
Amazing progress on build. Gotta know where did you get the cup holder inserts? Such a good idea in the gd models
02-01-2022, 10:19 AM | #32 | |
Member#: 514856
Thanks! They came with the car so I’m not sure where you can get them. I’ll check online and see if there are any that match mine and I’ll attach them here! |
02-01-2022, 10:30 AM | #33 |
Member#: 514856
Installed a set of discontinued front and rear GTSPEC strut tower bars. They have some beautiful color shift and metallic flake paint on the tower brackets.
02-01-2022, 10:52 AM | #34 |
Member#: 514856
02-03-2022, 10:37 AM | #35 |
Member#: 180155
NWIC
all good bro thanks a lot will be getting some too for my car.
04-28-2022, 02:01 PM | #36 |
Member#: 514856
added some much needed cooling mods to the car, with plans to track it I've replaced the stock water pump elbow with a Killer Bee high flow cast aluminum one, installed the Getadomtune 4th cyl cooling mod, used koyorad that was a little dusty but in solid shape, new OEM coolant, new OEM water temp sensor, thermostat gasket, and grimspeed upper and lower radiator hose.
04-28-2022, 02:14 PM | #37 |
Member#: 514856
since ill be installing hood louvers right over the radiator to further the cooling ability I decided to get a ION hood scoop delete and get it paint matched. I have to say ION makes a really solid kit for scoop accessories. my only complaint is the delete plate may have been a little too solid haha, it's very thick and it doesn't contour to the hood as much as id like it to but they don't normally make solid aluminum deletes so it was a custom order, other than that I'm extremely happy with the product. here are some shots of it painted and installed.
