Old 05-06-2021, 07:14 PM   #1
NZ.BC5
Member#: 497434
Default cel codes help? Pleeze
Fault codes on JDM sti 02 engine.
Have recently done a full engine and loom swap.
Into bc5 RS.
Almost there boys
Starts and runs, but has a lil pop and misfire .
The configuration:
Running with just down pipe, hardwired external fuel pump no FPC, the relay as trigger, the front 02 is new, it's position is at the bottom of the up pipe.
Rear 02 is in down pipe. Running a rising rate fpr.
And removed charcoal canister. Td05 with boost pill in the waste gate vacuum line.
I'm getting the following codes:
P1237 - fuel pump secondary circuit
P1239 - exhaust control valve solenoid circuit low
P0444 - evaporated circuit open
P1230 - FPC malfunction
P1235 - ?? Misfire?
P1130 - air fuel circuit open bank 1 sensor 1
P1249 - ?? No idea
P0249 - waste gate solenoid waste gate solenoid
P1247 - ??
P1199 - Differential
If anyone could take the time to check to see if my code IDs are correct and any info about how to fix my problem would be awesome.
I just want major/important codes sorted not fussed about minor ones. As I know my setup of fuel pump etc is causing some of them.
NZ.BC5 is online now Report Post
NZ.BC5 is offline   Reply With Quote
Old 05-07-2021, 08:55 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
Into bc5 RS.
Almost there boys
The configuration:
P1235 - ?? Misfire?
P1249 - ?? No idea
P1247 - ??
p1235 is a fuel pump thing, seems like you need to have someone go and turn all the fuel pump stuff of and then work to see whats left
Old 05-11-2021, 12:57 AM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Why not run a FPC? It looks like that would fix a few of the issues right there.
P0444 - evaporated circuit open- this you can just shut off since you know the issue- you got rid of the carbon canister.
