Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 11-05-2002, 01:51 PM   #1
andrewmva
Member#: 24731
MVA MOTORSPORTS
201-488-5111
Default Will the EJ20 heads BOLT-ON to a EJ25 block??
if not what mods are needed????
andrewmva is offline   Reply With Quote
Old 11-05-2002, 02:52 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yes they will. i am assuming you destroyed the bottom end of the EJ20 if you are now bolting them onto an EJ25.
Good Luck
jeremy
p.s.: use the head gaskets for an EJ25
HndaTch627 is offline   Reply With Quote
Old 11-05-2002, 04:03 PM   #3
rhdude
Member#: 6637
2005 Subaru Outback
FYI- you are going to choke that motor to death.....
rhdude is offline   Reply With Quote
Old 11-05-2002, 07:42 PM   #4
tcs007
Member#: 4103
2016 Mazda6
Red
How you figure? I was under the impression the WRX heads flow more air than the 2.5 heads.
tcs007 is offline   Reply With Quote
Old 11-05-2002, 08:18 PM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
You know...people keep saying the WRX heads don't flow as well as the EJ25 heads, but I have yet to see proof.
Impreza Rider is offline   Reply With Quote
Old 11-06-2002, 02:14 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
well boys FWIW the WRX heads flow worse on the bottom then the EJ25 heads, but on the top they outflow them tremendously. I'd be worried about the cam's not having nearly enough lift to power an EJ25.
Jeremy
Old 11-06-2002, 02:42 AM   #7
STiTuner
Member#: 5778
09 135i
Jet Black
Jeremy
would custom ground cams be enough to fix the issuse of lowend lack?
also I can understand flow being of importance but what about the fact that you have a bit more mechanical timing control witht eh WRX heads seeing as how they are DOHC. would it be worth it if you could find cams?
Brad
STiTuner is offline   Reply With Quote
Old 11-06-2002, 03:39 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Brad
yes very much worth it, but only for a Turbo Application, it'd be a waste of time and money on an NA setup. with a set of custom ground cams w/ enough lift to feed and EJ25 you'd be set. you'd have an incredbile package.
Jeremy
Old 11-06-2002, 04:20 PM   #9
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Well, here's a comparison to the EJ22 Heads:
http://www.cobbtuning.com/tech/sohc/page2.html
-Nathan
crash is offline   Reply With Quote
Old 11-08-2002, 10:56 AM   #10
omahasubaru
Member#: 1594
1999 2.5 RS
2002 Legacy
You could look into MY98 EJ25 DOHC cams... those might work with your WRX heads.
Jon
omahasubaru is offline   Reply With Quote
Old 11-08-2002, 04:12 PM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
-Nathan
ej22 heads dont compare to ej25 or ej20 heads lolz
akcel is offline   Reply With Quote
Old 05-09-2021, 12:32 AM   #12
justrunnin
Member#: 524185
Good Luck
jeremy
Just wondering, if it was the other way around (ej25 dohc heads on a ej20 dohc) would you run the ej20 head gasket?
justrunnin is offline   Reply With Quote
Will the Invidia header bolt on to my 05 LGT? wukindada Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-07-2007 10:29 PM
Who says ej20 heads won't fit an ej25 block? reddevil Built Motor Discussion 1 03-18-2007 12:17 PM
JDM wrx block and head bolt on to US wrx intake exhaust? SoBaLo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-18-2005 09:02 PM
Will my EJ25 flywheel bolt on to the EJ20? subyguy2 Transmission (AT/MT) & Driveline 9 07-13-2002 12:39 PM
will JDM Sti muffler bolt on to wrx? no_rex_yet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-08-2002 03:18 PM
