Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 07-09-2020, 01:50 PM   #8476
tannerdc
Member#: 437133
06 WRX Limited
More weight reduction
tannerdc is offline   Reply With Quote
Old 07-09-2020, 01:51 PM   #8477
tannerdc
Member#: 437133
06 WRX Limited
Cusco trunk brace install. Not too bad
Old 07-09-2020, 01:54 PM   #8478
tannerdc
Member#: 437133
06 WRX Limited
Big three kit. Ground kit. OTL coil install. Factory air intake put back in. But the hood doesn’t like to close well with it. Anyone have experience with that?
Old 07-26-2020, 10:22 PM   #8479
rally me
Member#: 100127
02 WRX wagon
today I replaced my leaking passenger side cv axel. I purchased my new cv axel at advance discount auto. The heavy duty cv axel was the most expensive axel they sold at $140 and looks visually different from my OEM original. do you think running two different axels will be an issue? thanks
rally me is offline   Reply With Quote
Old 07-29-2020, 10:46 PM   #8480
silverton
Member#: 331131
2001 2.5RS-T
Silver..thorn Metallic
you need to use the same axle on both sides.
silverton is offline   Reply With Quote
Old 08-03-2020, 01:23 AM   #8481
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Didn't touch it. Yesterday I bought a new radiator, because the end tank blew.
CosmoTheCat is offline   Reply With Quote
Old 08-03-2020, 11:09 AM   #8482
tannerdc
Member#: 437133
06 WRX Limited
Installed rear strut tower brace. That was a pain in the ass. Lol
Old 08-03-2020, 11:10 AM   #8483
tannerdc
Member#: 437133
06 WRX Limited
More rear bracing installed.
Old 08-05-2020, 08:59 PM   #8484
jdm05
Member#: 180155
05 Jdm Sti 2.0
Shifter bushing from tic, kartboy and cusco. Selling a new front sti shifter bushing (kartboy) bought a cusco to replace.
jdm05 is offline   Reply With Quote
Old 08-31-2020, 11:29 PM   #8485
tannerdc
Member#: 437133
06 WRX Limited
This came in the mail today. Should be an interesting weekend.
Old 09-05-2020, 10:58 AM   #8486
jdm05
Member#: 180155
05 Jdm Sti 2.0
Need to do some regular maintenance on the sti and check the suspension have a new sound coming from underneath lol
Old 09-07-2020, 04:26 PM   #8487
tannerdc
Member#: 437133
06 WRX Limited
Out with the old and in with the new.
Old 09-12-2020, 02:21 PM   #8488
RedMonkey999
Member#: 191476
2005 2.5RSTi
2003/4 2.5TS
RedMonkey999 is offline   Reply With Quote
Old 09-21-2020, 08:34 PM   #8489
jdm05
Member#: 180155
05 Jdm Sti 2.0
Cleaned up Jdm fog light lights and new overlays.
Old 11-03-2020, 09:07 AM   #8490
Geerolla
Member#: 264827
2017 Toyota Tundra
I traded it in back in June..
For this...
RIP NWIC
Geerolla is offline   Reply With Quote
Old 11-24-2020, 09:21 PM   #8491
Wraith
Member#: 30364
2005 Devilish STI
Angelic white
Wraith is offline   Reply With Quote
Old 12-09-2020, 11:46 PM   #8492
jdm05
Member#: 180155
05 Jdm Sti 2.0
New to me oem sti shifter trim for the gd sti 2005
Old 12-18-2020, 11:03 PM   #8493
CosmoTheCat
Member#: 3409
98 My FMIC
Putting the 3.0 back together.
The kid was "helping" me out in the shop, working on an art project. He distracted me while putting cam caps in the thing. Everything was within spec except one. Pulled that one and the one next to it and swapped, and we're back in action.
Old 01-01-2021, 11:02 PM   #8494
CosmoTheCat
Member#: 3409
98 My FMIC
Got the 3.0 back in the car, it needs a heater core I suspect. I can smell coolant now, whereas I bought the thing with a hole in the radiator and filled it with straight water when I put the new radiator in. I noticed the first time I drove it after getting the engine in that the defrost wasn't working so well, but I couldn't smell anything (yay covid) so a week later my sniffer was working more normally and I could definitely smell the coolant (on recirc).
Anyway, I pulled the 96 in, swapped out an axle that was clicking, a galled wheel stud, and put new sway bar end links on. Now it's time to clean it and sell it.
Old 01-07-2021, 01:51 PM   #8495
RedMonkey999
Member#: 191476
2005 2.5RSTi
2003/4 2.5TS
Originally Posted by CosmoTheCat View Post
Got the 3.0 back in the car [...]
Which 3.0 are you working on, phase I or II? Is it a swap?
Old 01-07-2021, 04:06 PM   #8496
jdm05
Member#: 180155
05 Jdm Sti 2.0
Finally got one, needs to be painted black and ready for install
Old 01-31-2021, 01:29 AM   #8497
CosmoTheCat
Member#: 3409
98 My FMIC
I picked up an 05 Outback 3.0R last summer from a buddy's sister, she was the original owner. At about 127k the radiator popped, she took it to Terry's, they quoted her almost $4k for radiator and head gaskets, so she wanted to sell it. I offered to take a look and see if I could get it fixed (much) cheaper, she just was ready for a new car after 15 years.
So I bought it, threw a radiator in it, put a couple thousand miles on it, then pulled and resealed the engine, found the heater core leaking - not enough to drip, but enough that I could smell it and defrost was having a hard time. When I pulled the dash apart I found the dealership did a hack job on the air bag recall, stuff not put together right, so I fixed it the right way and got rid of all the rattles they caused, and hooked the ambient (interior) air temp sensor that wasn't working properly.
And then I ran USB cables for my dash cam and phone charger/holder.
Aaaand then I replaced the lower control arm rear bushing, hub bearing, ball joint, and sway bar end link on the driver's side. No more clunks. Still need to work on the right side.
Old 01-31-2021, 01:32 AM   #8498
CosmoTheCat
Member#: 3409
98 My FMIC
Today I went to the pick n pull and grabbed a new auto dimming mirror, hook for the trunk floor, and dash end cap that the dealer broke.
Old 02-01-2021, 02:00 PM   #8499
RedMonkey999
Member#: 191476
2005 2.5RSTi
2003/4 2.5TS
If you ever need engine rebuild parts, I have a torn down EZ30R with less than 1000 miles on it (rings went bad after the cylinders were washed with fuel). Was planning to replace the rings and reassemble, but think I'm going to move in a different direction with my project. Just about everything (aside from the rings) is minty fresh.
Old 02-01-2021, 08:33 PM   #8500
CosmoTheCat
Member#: 3409
98 My FMIC
Lol, I hope I never do.
But those things disappear quickly from the pick n pull.
What did you do to your Subie Today? Version 3 TrickNipple North West Impreza Club Forum -- NWIC 3796 09-07-2011 02:52 AM
What did you do to your Subie Today? Version 2 Smoke North West Impreza Club Forum -- NWIC 1978 05-21-2010 12:43 AM
What did you do to your Suby today? BREWPUBEAVER North West Impreza Club Forum -- NWIC 1197 11-01-2009 12:06 PM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
