Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Vancouver Impreza Club
Old 05-16-2020, 02:42 AM   #251
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
It threaded into the knob, but was loose until it finally bottomed out. Hard to see, but I JB Welded the adapter into the knob.
After it cured, I didn’t want to give anyone the idea that it can be taken out with a wrench, so I rounded the corners down and made it round. More or less matches the knob.
clsmooth is offline   Reply With Quote
Old 05-16-2020, 02:43 AM   #252
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
I threaded it on, synched it into place, and zip tied the shift boot to the rest of the exposed thread of the shifter.
Why Subaru provided a $0.07 adapter with their $100 - $150 shift knob, I’ll never know. I might make a separate post of this cause I didn’t find anything online that anyone’s ‘repaired’ these before.
Old 05-20-2020, 10:40 PM   #253
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
I'm a little concerned, this fit the first time :P
Old 05-29-2020, 01:54 PM   #254
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Last week I cut the other side down to size and mounted their risers...
... coated the bottom ...
... and then the top.
Old 05-30-2020, 01:19 AM   #255
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
During this past week, I patched, wrapped...
... and cut reliefs in the floor's new covering.
Old 05-30-2020, 01:23 AM   #256
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
And done!
A few odds and ends to wrap up the interior is touching up the exposed rivets and some spots on the seats.
Old 05-30-2020, 01:28 AM   #257
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Also earlier in the week, I took Vicky out for her first drive this year! Man those seats are nice!!! It was also a pleasant change driving with a solid shift knob. So I took a photo-op...
Old 05-31-2020, 02:19 PM   #258
bdc64
Member#: 362821
2009 STI Hatch
Gray
Looks awesome!
bdc64 is offline   Reply With Quote
Old 07-01-2020, 03:51 AM   #259
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
With a holiday coming up tomorrow and some time for myself, got some maintenance-ish things outta the way.
The right rear caliper's seized, and since I was going to be in that corner, also ordered a new fuel filler neck.
I was advised mine needed replacing cause I can see some rust when looking down into it.
And that advice was correct.
Swapping out the caliper took 20 min, the filler pipe consumed the other 5 - 6 hours. SO MUCH rust and dirt came out from under the cover! It was a real pain getting that main hose off the end of the pipe too.
The more I handled it, the more started to disintegrate. I'm surprised my engine light never came on cause of this.
I picked up an aftermarket/jobber replacement pipe. The looping hose you see if me making a longer one then what came with it. Wouldn't reach 1 of those 2 return line things.
One of those returns lines at the bottom had a bit of surface rust on its clamp. Not sure how bad it is, but it down right impossible to get in there and change em under a jack stand - so I left them. If either start to leak, I'm taking that to my mechanic and ask him to name his price.
All shiny and new, but that was a struggle too. The bodyshop that the previous owner had the work done when the car got it either misaligned the filler neck "cup" in the 1/4 panel, bent the original fuel filler neck to fit, or both. Things were off everywhere by 3mm here and there. I had to wrestle it into position where I could bolt everything back up.
Put everything back together, and doesn't even look like I did anything.
1 of the cover's mounting bolts doesn't line up with the pipes bracket. That's aftermarket for ya. And the top mounting bolt didn't unscrew, it came off in the cover with a chunk of bracket. I melted it out and used a new bolt with a big washer.
Old 07-01-2020, 03:56 AM   #260
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Some bad news though. With everything apart, I thought it'd be a good idea to brush everything off and hit it with some leftover rubber sealant spray I had left over from my interior re-do. I ended up doing this with just a wire brush.
Picture yourself as the right, rear shock, looking out at the sidewalk. This one makes me feel bad. I don't think it's structural or anything's compromised cause if I knocked everything out with a brush, it's been on its last legs for who knows how long. Nothing I can do right now, applied as much sealant as I could. At least I'm getting to know where are the areas of concern are when I'm at Phase 4 and take her in for bodywork & paint. I'm going to bite the bullet on this one, pay the bodyshop to fix it right, and move on with life.
Old 07-23-2020, 11:40 PM   #261
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Not so much of an upgrade, more like maintenance, but still interesting.
My right front caliper was also seized. I had plans to rebuild it, but reman'd calipers are so much cheaper nowadays, I simply ordered one.
Couple of coats of blue
And a high-heat while vinyl decal
That's seized on there good! haha
The right, front caliper was 'original' in that in came with the car from the previous owner when I bought it. In the earlier 00's, he got in on a group by for a JDM 4-pot front setup. I think his "deal" at the time was $1000 or so for used 4-pots, used rotors, and even used pads. I had to replace the left front caliper a year or 2 after I took ownership cause it developed crack right in its casing? I still don't know what happened there...
I'm surprised this one lasted as long as it did. Previous owner got used himself. Who know how many km's, or even what year exactly it was from.
Back on the car
I like it
Old 08-20-2020, 01:08 AM   #262
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Now with blue Mcgard lock lugs.
Also put insurance on her for the rest of the month! Gotta enjoy her a bit after all that work...
Old 08-27-2020, 11:53 PM   #263
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
All the parts for Phase 2 this upcoming winter have come in. Am I missing anything? :P
Old 09-11-2020, 11:17 PM   #264
Mad_Max_2010
Member#: 336288
2010 sti hatch
dgm
Love the work you are putting in on this. What a special project. Enjoy, I am.
Mad_Max_2010 is offline   Reply With Quote
if you haven't registered your car in CA, BE CAREFUL!!! topguneagle1 Southern California Impreza Club Forum -- SCIC 34 06-08-2009 10:15 PM
haven't posted up pics in a while benya29 Member's Car Gallery 2 02-24-2008 02:03 PM
I haven't posted anything WTLW in a minute so here; Ballad of the Beard scaryfastskier Off-Topic 5 09-25-2007 02:03 PM
I haven't driven my car in 6 weeks... HalfBaked Off-Topic 4 07-26-2005 03:48 PM
I haven't posted a stupid ? in a while TheMadScientist Engine Management & Tuning 10 10-18-2004 08:17 PM
