Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 05-25-2020, 06:05 PM   #1
Dubclutcher
Member#: 515015
Default Knocking that matches wheel speed
Hi all, 5 speed 14 wrx hatch here. Recently got a new exedy stage 1 clutch put in by a local shop. Every time I come to a slow or a stop there is a squeaky knock that decelerates as the car decelerates. I doubt it’s the clutch. Transmission fluid is low so I’ll be doing a change tomorrow. In the meantime, is this knocking a symptom of a serious tranny issue?
Edit: this is only audible during low speeds (5-10 mph)
Dubclutcher is offline   Reply With Quote
Old 05-26-2020, 04:09 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If it was not doing it before the clutch change, and now it is right after the clutch change, then . . .
Turn around and go back to local shop and tell them to fix it.
Old 05-28-2020, 12:38 AM   #3
Dubclutcher
Member#: 515015
Yeah sounds about right... it’s an elusive little noise though so hopefully they’ll do everything they need to to fix it
Old 06-02-2020, 05:38 AM   #4
Dubclutcher
Member#: 515015
Update: super simple fix. Turns out they misaligned the block putting the engine back in and my aftermarket intake was rubbing.
