03-08-2011, 03:22 PM | #26 |
Member#: 255208
Vehicle:2009 Chevy Cobalt SS Burgandy |
Subaru Valve Body Installation Video
Figured this may be an appropriate update to this thread...
03-10-2011, 10:12 PM | #27 |
Member#: 142972
^ good stuff, thankfully the 4EAT auto is solid
01-07-2012, 10:01 PM | #28 |
Member#: 171288
RMIC
Vehicle:1998 Outback Sport Black |
YESSSSSS!!!! I have been needing a diagram showing the solenoids inside the trans! This thread deserves some brownies.
01-09-2012, 07:18 PM | #29 |
Member#: 53451
Vehicle:2000 JDM Impreza SRX w/ AVCS Silver |
Transmission is the 4EAT that uses clutches to engage the rear.
I have a question. My car is just over 150,000kms and I always use Motul Dexron III and a Transmission Cooler. I find my tranny do not behave like before and sometimes labour and do not want to shift lively. Its always quick to leave first gear and love higher gears. Sometimes when the car shifts, it feels like the clutch slips a bit like I don't have enough line pressure. I want to change to a 6MT, but financially not capable at this point in time. Can any one advice me whats going on? Is the Solenoids going? Are the clutches going? Please advice. Thank you. |
01-13-2012, 01:34 AM | #30 |
Member#: 230509
TXIC
Vehicle:06 vf39 wrx ugm |
how much does a VB mod cost if the removal is done at home and the sent off?
01-16-2012, 08:03 PM | #31 | |
Member#: 123362
Vehicle:'97 E36 M3 351W FTW |
01-17-2012, 02:58 AM | #32 | |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Subaru started doing this from the factory LONG ago. There is a pin on the older ECU that you can trigger at any time to temporarily reduce engine power. I always imagined using it as a poor mans valet mode. |
01-31-2012, 08:13 AM | #33 |
Member#: 308077
Vehicle:02 WRX wagon blue |
anyone know where you can get a shift kit for a 4eat? like im trying to rebuild my valve body myself without spending all the $$ that these trans places are charging. like forreal how much could acouple of valves and springs really cost them that they have to charge $500+. ive rebuilt valve bodys before but only to replace with OE valves springs and check balls. if you have any info plese help
01-31-2012, 05:02 PM | #34 |
Member#: 170973
Vehicle:2004 WRX 4EAT PSM |
Quick question for the guru's
Is there a way to fool the transmission into thinking the pedal is pressed all the way down? Some resistor mod maybe? I feel like with a stage 2+E85 setup, the torque generated at 5% throttle stock is WAY less than 5% throttle now. I'm just thinking this could be good for transmission longevity. Thanks |
01-31-2012, 07:07 PM | #35 | |
Member#: 156712
AKIC
Vehicle:1991 Legacy SS Pearl White |
Link to the kit. http://transgoonline.com/products.ph...&parent_id=145 Do a google search and you'll come up with places to buy it. Also, do a search on LegacyCentral and you will come up with the install manual for it. |
02-08-2012, 05:14 PM | #36 |
Member#: 122690
02-29-2012, 08:37 AM | #37 |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
I can't find them on here...do you have a link for IPT?
03-01-2012, 02:35 PM | #38 |
Member#: 156712
AKIC
07-17-2013, 05:16 PM | #39 |
Member#: 200436
Vehicle:2004 Forester XT Black |
I'm looking at the Level 10 valve body upgrade kit for $198. Has anyone done a valve body job? How difficult is this?
Level 10 Subaru PTS Valvebody Kit 4EAT Level 10 PTS Subaru Bulletproof Rebuilding Kit 4EAT,5EAT,R4AXEL There is also a "Bulletproof" transmission rebuild kit for $598. Is this something a normal person can do, or does it require special training? I happen to have a spare 4EAT transmission with low miles I'd like to beef up to handle the power I'm putting down. Info here: http://www.levelten.com/SearchResults.asp?Cat=47 |
07-17-2013, 06:46 PM | #40 |
Member#: 222703
E. Canada
Vehicle:2006 Impreza 2.5i Crystal Grey |
Uhh... If you've never done a valve-body, or have someone local, I personally wouldn't touch a valvebody kit, unless you have VERY good understanding of how they work. If you Fu$% it up, your tranny is toast (or just won't shift properly, if at all...).
The rebuild kit, requires you to completely dismantle your auto to install it. From what I understand, it's not an easy thing to do, mainly because of all the oddities and/or special tools (I can't remember if that's one main issue) that are involved in putting it back together. If your really interested, I'd save a little more coin, and buy the IPT modified valve body and the IPT High Stall Torque Converter. The only reason for IPT, is that they are an extremely well known performance tranmissions builder. I'm not saying L2 isn't, but I've never heard of them, and I've been looking for a little while now (this is a plan of mine next year, so I can sympathize for these desired upgrades). Btw, if you plan on swapping your transmission after getting this done, seriously do yourself the favor and get the HS torque converter... you can launch at higher rev's without worrying about cooking your transmission. Also, if your really planning on upping your HP, get a tranmission cooler, it's easily worth the $150 in parts. |
07-24-2013, 10:18 PM | #41 | |
Member#: 200436
Thanks for your feedback! |
08-27-2020, 10:32 AM | #42 |
Member#: 517448
Nice write up.
WTB: 4EAT Valve Body. 2002+ WRX Auto Transmission Valve Body | STEALTH-WRX | Private 'Wanted' Classifieds | 2 | 08-02-2007 06:58 AM |
WTB: 02 wrx 4EAT valve body | pogomonkey | Private 'Wanted' Classifieds | 0 | 04-12-2007 09:30 PM |
Stock '02 wrx 4eat valve body | WRX1 | Private 'For Sale' Classifieds | 7 | 11-30-2004 03:30 PM |
4EAT Valve Body $300 Shipped | WagonRX | Private 'For Sale' Classifieds | 2 | 08-01-2004 10:34 AM |
WTB: 4EAT valve body | svxr8dr | Private 'Wanted' Classifieds | 0 | 10-23-2003 11:46 AM |
