Tire & Wheel Forum sponsored by The Tire Rack |
04-07-2020, 03:55 PM | #1 |
Member#: 379794
W. Canada
Vehicle:09 impreza pearl white |
09 impreza sedan LIFT
hey guys and gals im currently lifting my 09 Subaru impreza sedan 2.5i 1" all the way around. I was wondering if anyone else has done so and what's the biggest tire I can fit???
I'm starting off with a 1" spacer lift and was thinking of running a 215/65/16 with a BfGoodrich KO2
04-07-2020, 03:57 PM | #2 |
Member#: 513182
I’m in process of lifting my 2013 WRX. I can fit 215/70/15 safely. Check out this website. https://www.rallitek.com/blog/lifted...re-size-chart/
04-07-2020, 04:20 PM | #3 | |
Member#: 379794
W. Canada
04-07-2020, 04:23 PM | #4 |
Member#: 513182
For lifting you may want these websites to help with figment.
https://www.willtheyfit.com https://tiresize.com/calculator/ And General rules of thumb for lifting; For every 2” up, 2inches of subframe drop will he need. (So you don’t kill your axles, bushings, and alignment.) |
04-07-2020, 04:32 PM | #5 | |
Member#: 379794
W. Canada
06-09-2020, 12:10 PM | #6 |
Member#: 514985
Were you looking at just the strut spacer? I'm looking at doing a 2" lift on my Impreza with a RalliTEK kit that includes both the strut spacers and the subframe spacers. Not sure if a 1" lift is a small enough change to allow the alignment adjustment to be able to compensate.
09-20-2020, 09:09 PM | #7 | |
Member#: 512559
10-23-2020, 03:50 AM | #8 |
Member#: 480947
Has anyone done the lift with Forester struts like the older models?
10-27-2020, 11:47 AM | #9 | |
Member#: 398645
Vehicle:2014 Impreza Wagon White |
Other note: I also replaced my spare with a 155/90R16 to match the 27" tire height. It barely fits in the spare well. I slightly trimmed the plastic at the rear. The cargo floor sits maybe 1/2" high, held up by the spare tire. I have the cargo tray on top of that, so it's really not noticeable. |
11-22-2020, 08:05 PM | #10 |
Member#: 158152
SCIC
Vehicle:2006 WRX Wagon Aspen White |
2008 LIFTED Impreza Sedan Dirt Car
Hey all, I am picking up an 08 Impreza sedan tomorrow... Anderson Design lift going on, 15" steelies and General AT tires, cutting front bumper, Roof rack with LED light bar on the front of the rack, trim and cut wheel wells and install wheel well covers... Then I spray the car in www.monstaliner.com
I've done 3 old Crown Vic Police Interceptors with the above treatment, this will be the first Subie.... Stay tuned! |
01-01-2022, 07:49 PM | #11 |
Member#: 528143
Vehicle:09 Hatchback Charcoal Grey |
09 lifted Hatch
I am currently lifting my 09 hatchback and wanting to know if the forester struts will do the trick. Im looking to add 2-3 inches and the forestry struts seem to do that but after researching it seems I need subframe spacers as well?
Any other pieces I would need in order to make sure its done right? |
01-20-2022, 02:31 AM | #12 | ||
Member#: 528298
Vehicle:2011 Impreza 2.5i WRB |
I only looked at the most recent comment's timestamp, apologies for necro
If you haven't already found resources yes it is possible and yes it is done. Most people will recommend that you use subframe spacers due to gen3 Foz struts pushing the envelope of CV angle on our Imprezas. I myself and many others run Foz struts just fine without spacers, so ymmv You will need 09-13 Forester struts, either adjustable trailing arms or the rear subframe spacers to center your rear wheel, and adjustable rear lower control arms make the install easier but are not necessary if you're willing to muscle the lower strut bolt into place. You will need front camber bolts to correct the positive lean. |
