Old 02-23-2006, 02:23 AM   #1
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Default Maximum HP on JDM EJ207
What is the maximum HP on a JDM STI EJ207 (version 10) with stock internals?
Also, at what point should you upgrade the 565cc injectors?
STI8U is offline   Reply With Quote
Old 02-23-2006, 03:09 AM   #2
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
I dont think anyone knows the limits of the stock internals on the JDM EJ207 all to well. As far as injectors go....the stock JDM 565cc's arent gonna do much more than simple bolt ons.
SSFWRX is offline   Reply With Quote
Old 02-23-2006, 08:42 AM   #3
jtanoyo1
Member#: 102050
2004 JDM WRX STi
Diamond White
Haha, I think I will find out what that "limit" will be with my car sometime this year, before I switch to a 2.5L shortblock.... Keep u guys posted.
jtanoyo1 is offline   Reply With Quote
Old 02-23-2006, 08:56 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i've seen a couple of 500whp ej207s floating around, fwiw.
Old 02-23-2006, 11:14 AM   #5
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
yeah, there's that guy running the ultimate performance GT35R kit who I think made 500 whp.
Capt Crunch is offline   Reply With Quote
Old 02-23-2006, 11:41 AM   #6
Blackboxracing
Member#: 90106
is that with a completely stock engine? heads, internals, etc
Blackboxracing is offline   Reply With Quote
Old 02-23-2006, 11:49 AM   #7
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Thread:
http://forums.nasioc.com/forums/showthread.php?t=842346
I made 504 WHP on a dynapak running 32psi through a stock JDM STi v7 motor. I've daily driven the car since then and the motor leak down tested perfect as of 2 weeks ago. Keep in mind on pump gas everyday i don't beat on it very much. I mostly run 18-19psi and not the 23psi i was tuned for on pump gas. I have run about 30-35 gallons of C-16 through it though since the tune, as well as a couple drag passes.
This was stock heads/cams. Some headwork and cams would really help out.
I did not expect the motor to last me many miles. I know it can go anyday, but i do feel it's a somewhat reliable setup if you give it some good high octane fuel and don't beat it on pump gas.
Hope this helps,
Louis
Soon2Bgreat is offline   Reply With Quote
Old 02-23-2006, 01:43 PM   #8
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
I overboosted my ej207 accidentally to over 30psi and blew a headgasket.... The internals just laughed at me and asked for more
Javier is offline   Reply With Quote
Old 02-23-2006, 01:48 PM   #9
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Originally Posted by Soon2Bgreat
Thread:
Louis
504HHP?(Hub Horse Power)
Kingpin is offline   Reply With Quote
Old 02-23-2006, 02:28 PM   #10
justboosted02
Member#: 78285
2006 EVO GG
2019 WRX LB
thats still at least 470 whp on most other dynos
justboosted02 is offline   Reply With Quote
Old 02-23-2006, 02:33 PM   #11
cronic
Member#: 9749
I know but i like busting his balls..lol
cronic is offline   Reply With Quote
Old 02-24-2006, 04:09 AM   #12
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Hmmm, a local tuner here that does Motecs for a lot of rally cars in Australia reckons the stock internals on STI Spec Cs are only good for 400lbft torque (flywheel). Says the pistons since v8 have gone down a grade and they have problems with the spacing between the rings or something...
Old 02-24-2006, 12:03 PM   #13
Javier
Member#: 19346
2003 MBP WRX
The V8 pistons are made the same as the usdm sti pistons so that's not surprising. Most would agree that the V7 STI pistons are more hearty and can take more abuse...
Old 02-15-2021, 12:40 PM   #14
Jaws4God
Member#: 521646
2003 Impreza WRX 207
02C, 42C World Rally Blue
so mine have 315 hp should be no issues on an EJ207?
Jaws4God is offline   Reply With Quote
Old 02-15-2021, 06:14 PM   #15
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Look at the date before you bump a thread
snow_bound26 is offline   Reply With Quote
Old 02-24-2021, 03:31 PM   #16
flavioice
Member#: 513220
2005 2005 WRX
Yehaa, the tread just reborn! By the way, mine (v8) is about 350whp with a efr7163 and 19psi. I run 17psi normally with the map1.
flavioice is offline   Reply With Quote
Old 03-07-2021, 07:08 PM   #17
yliu14
Member#: 522835
1998 Impreza WRX STI
Yes, 315hp on crank is in safe area for JDM EJ207. But you will need a good tune for long term
yliu14 is offline   Reply With Quote
Old 03-07-2021, 10:08 PM   #18
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Question
I saw nothing about tires.
Vancouver98STi is offline   Reply With Quote
Old 04-01-2021, 10:51 AM   #19
khosein
Member#: 506952
07 WRX STI
black
Making 325awhp and 335awtq (Dynojet) on a stock v7 jdm 207, VF30 (20psi)
khosein is offline   Reply With Quote
Old 05-13-2021, 11:48 PM   #20
moisescouch122
Member#: 524290
2003 WRX
ive seen some videos and some people push up to 500hp
moisescouch122 is offline   Reply With Quote
Old 05-14-2021, 08:04 AM   #21
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Why is everyone reviving these old threads? This has been dead since 2006 until a month ago.
Old 05-14-2021, 08:42 AM   #22
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
The guy who bumped it has 4 posts total lol. he just needed to comment on some posts in order to make an original post.
K3rm1tth3fr0g is offline   Reply With Quote
Old 05-18-2021, 06:14 PM   #23
Kestrel416
Member#: 514608
Wow how the hell did you do that? My tuner told me that expected with an 18G, headers and 1000 cc injectors. I getting 275 whp and 245 wtq with a VF30, pinks and a DP.
I'm also trying to get 4 replies so I can make an original post.
Kestrel416 is offline   Reply With Quote
Old 05-18-2021, 07:16 PM   #24
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Probably e85 or close to it.
Old 05-18-2021, 11:52 PM   #25
Kestrel416
Member#: 514608
I was making the same boost as well (19.8 psi).
Diagnosis on jdm ej207 heads pls? rip_sti_ra Built Motor Discussion 15 08-13-2008 02:38 PM
EJ5-40T on a JDM EJ207 Kreeger Proven Power Bragging 49 10-02-2005 10:43 AM
Maximum HP from STi engines? Stevo88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-06-2004 10:51 PM
what is the maximum hp the STi 6speed can handle? trinydex Transmission (AT/MT) & Driveline 7 02-11-2004 06:48 PM
Maximum HP on stock RS fuel system with walbro fuel pump Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-17-2002 03:42 PM
