09-28-2019, 10:58 PM | #1 |
Member#: 395793
Tri-State
Vehicle:2005 92x Aero Beige |
Open source software
I just moved to SLC and am having some fuel cut issues. I have all the software downloaded and installed but haven't been able to figure out how to log properly so I can try to figure out what's going on and talk to my tuner. Just wondering if someone would be willing to sit down with me for a little while and show me how to properly log and save the data? I'm located in the Sugarhouse area but am willing to drive to you to make things easier.
09-29-2019, 09:59 AM | #2 | |
Member#: 370021
RMIC
Vehicle:2008 WRX Hatchback WRB |
10-10-2019, 08:58 PM | #3 |
Member#: 395793
Tri-State
10-11-2019, 11:05 AM | #4 |
Member#: 31193
NWIC
Vehicle:2003 WRX Wagon Blue |
Are you using Tactrix for hardware or something else?
10-12-2019, 12:42 PM | #5 |
Member#: 395793
Tri-State
10-14-2019, 12:13 PM | #6 | |
Member#: 31193
NWIC
Romraider is useful but I found it more annoying to try to drive around with a laptop for a while. I'm assuming you have the latest Tactrix with an sdcard slot. If not, you'll have to do the computer. |
10-15-2019, 09:16 AM | #7 |
Member#: 395793
Tri-State
I know how to select parameters of what I want to to log. The problem is I can't get it to show as a spread sheet per 100rpm. When I pull it up after saving it only shows what I've saved like a screen shot of the live view.
And yes driving around with a laptop is a pain. I have a PC based tablet I'm using which runs the programs fine but I usually ask a friend to come along to start and stop it so I'm not. I did buy the tactrix used but I'll see if it has an sd slot. |
11-10-2019, 04:20 AM | #8 | |
Member#: 495564
Complete software is split into small modules and sub-features. An overall analysis of the complete solution is designed and discussed in the team. After that, the bare minimum features, which are required to release the first version is decided. It probably will be a good suggestion to have an option for it. In this case visit this software development company site https://vilmate.com Last edited by K2marer; 11-14-2019 at 05:26 AM. |
11-16-2019, 04:18 PM | #9 | |
Member#: 81106
RMIC
Vehicle:2011 STI Hatch Lightning Red |
Pro-tip if you're doing the logging by yourself, set your parameters for logging, save it to a profile, easy loading. Then, turn the defogger switch setting on, that way you only have to hit the defogger button to start and stop and not look over at a screen. |
11-26-2020, 12:54 PM | #10 |
Member#: 495564
Hotel management system but essential to providing the best customer experience. Often the hotel equipped itself with very complex tools that, in the end, will not be used by the staff. When choosing a hotel management system to consider first what you need. Check https://www.otelms.com/
