Welcome to the North American Subaru Impreza Owners Club Monday May 10, 2021
Go Back   NASIOC > NASIOC Subaru Models > Crosstrek Forum
Old 04-09-2021, 09:25 PM   #1
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Default Lowering the Crosstrek
In my random cruising around the net, I've found that no, an impreza suspension is not the same as a crosstrek, so swapping over will lead to failure. I came across RS-R springs from a post that appears to be the poster car for the company, but it looked like exactly what I wanted. Not garbage coilovers, not slammed, not wrong setup for a different car. So I ordered a set and the UPS guy dropped them off today.
According to RS-R (who calls them "good handling springs), it drops front and rear 1.2". The rear springs are progressive. I took the car for a ride on twisty back roads to try them out and I'm quite happy with it. Not slammed like some 16 year old's car and not a bouncy, Honda-esque chinese coilover garbage.
Old 04-10-2021, 01:15 PM   #2
iLaw
Member#: 275836
2020 Crosstrek
Sunshine Orange
May I ask why you decided to lower the vehicle? Does your car have EyeSight? If so, did you have it recalibrated? Did you consider buying an Impreza instead? If you did, what was the factors that led you to the Crosstrek?
I'm genuinely curious, not trying to be an ass.
iLaw is offline   Reply With Quote
Old 04-10-2021, 03:27 PM   #3
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
I've had the Crosstrek 6MT for a couple years. Being a manual, it doesn't have eyesight. I like the 6 speed, the bigger sway bars, the completely different front suspension (it's not the same as an Impreza), the stiffer chassis, the flares the wider track and the bigger tires that all come on a Crosstrek, none of which is easily available on an Impreza. This is my 2nd Crosstrek, the first being a 13 limited that one of my son's is driving right now with 130k miles on it.
But to me, the Crosstrek is just a bit too high. I have seen slammed ones on coilovers. I'm not 16, so slammed doesn't interest me. I was also impressed that these springs actually state the rates. So many garbage springs don't, so when you test them, you aren't surprised that they don't match the target spec.
I understand the question. In my research, this is almost always the response to someone asking about lowering a Crosstrek. Lots of kits available to raise a crosstrek, which especially on a first gen Crosstrek, I really don't get. My other car is a Wrangler, raised 2.5" on 34" Dick Cepeks and properly protected with skids. I offroad that and know for sure that a Crosstrek has no business offroading where my Wrangler goes.
So there's my thoughts on it.
Old 04-10-2021, 05:11 PM   #4
iLaw
Member#: 275836
2020 Crosstrek
Sunshine Orange
That's cool, man. I have nothing against people making their car their own; especially if its functional. Its irrelevant whether or not its "on trend", they car is yours and you have every right to take pleasure in making it so.
I learned something today. I didn't know the sway bars on the Crosstrek were thicker, so thanks for that knowledge.
The drop looks good back to your car, the drop looks good. I bet the cornering and overall handling has improved a lot with the lower centre of gravity.
Cheers
Old 04-12-2021, 02:31 PM   #5
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
The handling is transformed. I did not expect this. I'm driving the long way through narrow twisty roads just to experience this.
Old 04-15-2021, 01:41 PM   #6
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Old 04-18-2021, 11:45 PM   #7
Maldedo
Member#: 523779
2014 Subaru
Thank you for sharing pictures,
I want to do the exact same mod on mine and could only ever find the one picture from their website.
Now I know for sure that's what I want!
I think most people wouldn't even notice that this crosstrek has been dropped, it keeps the natural look of the car.
Maldedo is offline   Reply With Quote
