03-26-2015, 11:16 PM | #51 |
Member#: 384225
Vehicle:2017 Tesla P100D Red |
Anything is possible, would just need to know the dimensions of the v band
03-26-2015, 11:19 PM | #52 |
Member#: 384225
The intake manifold is still a back burner dream right now, most likely will explore the idea further when i move to a FMIC setup.
But i will be machining a solid pitch stop in two versions, one is SOLID (NVH baby) and the other is similar but with delrin bushings and SS sleeves. Still need to make a battery tie down for +5hp lol |
04-22-2015, 02:27 AM | #53 |
Member#: 384225
04-22-2015, 09:02 AM | #54 |
Member#: 411777
Vehicle:2015 Impreza Sport CWP |
Although these parts are highly functional,
I would like to say they are Modern Art. Send me some and i will display them free of charge at my gallery |
04-22-2015, 10:02 AM | #55 |
Member#: 347474
Vehicle:0219 Bug,bug,coup,va mbp,sr,wrb |
new stuff looks top notch keep it up
04-23-2015, 02:05 PM | #56 |
Member#: 270118
04-23-2015, 11:55 PM | #57 |
Member#: 384225
04-23-2015, 11:56 PM | #58 |
Member#: 384225
04-27-2015, 06:05 AM | #59 |
Member#: 195711
Vehicle:PART OUT. PM ME 02-07 Goodies |
Wish I had the resources that you did to make this stuff. beautiful!
Levon |
04-29-2015, 09:04 PM | #60 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
I am thoroughly impressed with your work.
But what really caught my attention was the fact you considered an adjustment plate with regard to the intake manifold inner mounting bolt hole positions for earlier years versus later years. I had to port my inner mounting holes to the intake manifold from my 2006 WRX to have it mate to a set of composite TGV deletes. I eventually went to a pair of OEM units that are PnP'd (had issues with the composite units) and had to use oversized washers for these now slotted inner mounting holes. Eh, no big deal. Regardless, what else are you considering to manufacture? I too like to buy from small innovators such as your self. |
04-30-2015, 12:32 AM | #61 | |
Member#: 384225
It was a collaboration idea with Fuji K from NF Performance (the shop i use here in Minneapolis). I plan to make and sell everything pictured locally. Things that i still need to design: solid trans mount, hurst style shifter, battery tie down, SI Drive knob cover. Do you have any ideas |
04-30-2015, 08:34 AM | #62 |
Member#: 47915
Vehicle:1996 GC8 FFR818r 19 Forest Touring |
Most of my ideas are for more motorsports type applications.
Maybe a little difficult but an adapter so you can use a push style clutch and a hydraulic slave cylinder for both 5MT and 6MT. If we could have the option of using a 5.5" push double or triple disc clutch pack with a hydro slave cylinder that would improve things for all racers 1/4 milers, road races etc etc. Roger Clark and Tilton have something over seas but nothing here for us in the US that's affordable. Plus 1 for the 5MT and 6MT solid trans mount. The only other thing I'd like to see is for all the suspensions arms and linkages F/R is sperihical (aka heim, rose joint, rod end etc) metal bearing inserts. Thanks and keep up the awesome innovative work! Dave |
05-01-2015, 12:43 AM | #63 |
Member#: 352704
VIC
Vehicle:1965 Vw panel bus with an EJ20 Turbo Swap |
Just curious why you blasted the parts you anodized? Could they have been just anodized ? Does it adhere to it better ?
05-01-2015, 01:45 AM | #64 | |
Member#: 384225
Good question |
05-01-2015, 09:16 AM | #65 | |
Member#: 123843
NESIC
How about an oil-filler cap? How about an oil-filler cap for a GrimmSpeed AOS? Just throwing a few out there. What are your limits? Meaning, what are you not able to do? BTW, I would really like a pair of your TGV's, but I'm on my second set: composite, which was replaced by a PnP set from GrimmSpeed. |
05-01-2015, 11:21 AM | #66 |
Member#: 347474
some knuckles under a million dollars would be nice just throwing that idea in there
05-01-2015, 06:01 PM | #67 | |
Member#: 384225
I think the only difference between the 5mt and 6mt is the height, so i will add a shim that can be removed so many cars will work with it An oil cap is a good idea! Honestly, i think a space ship might be hard to make lol |
05-01-2015, 06:02 PM | #68 |
Member#: 384225
05-01-2015, 08:30 PM | #69 |
Member#: 123843
NESIC
Knuckles as in what the hub and bearing are pressed into (a/k/a: uprights).
If you make an oil cap, what about designing it to look like a gear? A one-piece front strut-tower brace? A subframe and/or other chassis bracing? A multi-piece rear strut-tower brace that boxes in the towers? I still want a pair of the TGV deletes. Mmmmmm. |
05-01-2015, 08:58 PM | #70 | |
Member#: 384225
I'll start with the trans mount and then move on to the next thing |
05-02-2015, 01:08 AM | #71 |
Member#: 347474
lol yea what he said
05-05-2015, 04:19 PM | #72 |
Member#: 347756
VIC
Vehicle:2005 Outback XT Silver |
Ahhh, I would love to snag that solid from you and make myself a TGV delete. And that shifter is bad ass. Let me know haha. Shame I don't use gibbs, but Mastercam.
05-06-2015, 01:19 AM | #73 | |
Member#: 384225
Not too long ago I was contacted by a company (they never said who they worked for) to lisencse and sell my design. No thanks! I learned MasterCam in tech school but as soon as I got my current job (8 years ago) it was gibbs. They are both great programs to use. |
05-06-2015, 01:20 AM | #74 |
Member#: 347756
VIC
Haha fair enough! When I make something worth trading I'll PM you .
05-06-2015, 01:21 AM | #75 |
Member#: 384225
Got my hands on 5mt and 6mt trans mounts. That should be easy to model up and make.
