Brakes & Suspension Forum sponsored by The Tire Rack |
04-19-2021, 08:28 PM | #1 |
Member#: 522452
South East
Vehicle:2016 WRX Prem Blue |
Hard pedal.. feels like no brake booster...??
So I just did a couple mods over weekend.. Installed Grimm Speed EBCS..full EGR deletes and IBRC full TGV deletes..and new j-pipe.. flashed new new to support new mods and car started up and idles well went through bleeding procedures for coolant and followed tuners directions.. well went to drive it and my brakes aren’t quite up to speed.. like it feels like a have to power brakes.. no lights or codes or anything was able to drive but definitely no power brakes ***129335;***8205;***9794;***65039; Please advise and thanks for any help
04-21-2021, 05:11 PM | #2 |
Member#: 518830
RMIC
Vehicle:2009 WRX dark grey metallic |
make sure you didn't inadvertently disconnect your vacuum line that runs to the brake booster. It's also possible it cracked when you were moving stuff around.
04-21-2021, 05:36 PM | #3 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
+1 on the disconnected/cracked line, would be obvious vacuum leak in the engine bay...also random thought would be hard but if you accidentally plugged that hole would also cause issue
04-21-2021, 09:18 PM | #4 |
Member#: 124146
Vehicle:'17 Outback 2.5i Premium Tungsten |
It could also be the in-line anti-backflow valve installed backwards.
04-23-2021, 10:22 AM | #5 |
Member#: 522452
South East
I got it.. failed to tighten EGR block off plate caused vacuum leak at manifold
