Brakes & Suspension Forum sponsored by The Tire Rack |
04-25-2002, 10:44 AM | #1 |
Member#: 15559
What size line wrenches do I need to change the brake lines?
I am going to see my tool man later today and before I left home I forgot to check to see what size line wrenches I need to remove and install the brake lines on my 1997 L with stock brakes. Any help would be appreciated.
04-25-2002, 05:07 PM | #2 |
Member#: 415
SCIC
Vehicle:2018 WRX Ltd Dark Grey Metallic |
I'm not 100% positive, but I'm pretty sure 12mm and 14mm offset wrenches will do it (offset for clearance from the caliper when doing the bleed nipple, etc.)
If you want to play it safe, a simple 10,11,12,14,16,17 type set of offset 12pt wrenches can be had fairly cheap, even in American made/lifetime warranty trim. The set I bought just for doing my brakes has like 5 wrenches offset wrenches with incrementing sizes (so 10 sizes total) and was like $15-$20. |
04-25-2002, 05:18 PM | #3 |
Member#: 10821
NESIC
Vehicle:2008 WRB STi |
I donno about the 1997 L, but the WRX needs a 9mm wrench to disconnect the hard line from the rubber brakeline.
Just a FYI. |
04-25-2002, 05:20 PM | #4 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
Sounds right, 9mm or 8mm. Sometimes that thing can get stuck too, it's a real pain in the arse after the car has a few seasons on it.
Haven't stripped one beyond use yet, but the last install I did have to use vice grips. (yikes!) |
04-25-2002, 05:35 PM | #5 | |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
I'm not certain about the 9mm size, as I thought it was a 10mm on the WRX, but I could be wrong. A $25 set from Sears will give you 4 wrenches with 8 sizes from 9 to 17mm. -Ray |
04-25-2002, 07:03 PM | #6 |
Member#: 10821
NESIC
10mm wrench is a little too big, believe me...
I tried... |
How often do you need to change your brakes? | plunk10 | Off-Topic | 114 | 04-08-2010 09:30 AM |
Need to flush the brake lines on a..volvo | beaconhillkilla | Brakes, Steering & Suspension | 2 | 02-03-2010 08:12 AM |
What size tq wrench do I need for muteki lugs? | Spectre186 | Tire & Wheel | 2 | 03-28-2008 10:14 PM |
Doing an AT fluid swap in a few days...do i NEED to change the filter? | kaisersouse | Normally Aspirated Powertrain | 8 | 08-30-2005 10:14 PM |
need to change the brake for the 05 sti with 18k miles any good suggestion? | fishdotcom | Brakes, Steering & Suspension | 7 | 08-09-2005 09:55 PM |
