Brakes & Suspension Forum sponsored by The Tire Rack |
04-17-2015, 04:05 PM | #26 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
The point of filling, re-drilling and timesert-ing the calipers would be to change the mounting location so you could use the calipers with whatever rotors you wanted (presumably STI rotors).
04-17-2015, 06:28 PM | #27 | |
Member#: 319017
Vehicle:15 Prius 2JZ miata Death Trap |
Cadillac CTS-V Brembos vs STi Brembo's
Ahh guess I never looked into it.. Either way by the time you ghettoiZe some calipers it seems like enough time would have been spent to just get a nice set of brembos or two pots, and what is brembos or these ctsv brakes going to offer over two pots or just stainless lines and nice pads? Are you tracking your outback? Idk why im against the idea just seems rather pointless to put so much effort to tell your bros you have ctsv brakes. Sent from my iPhone using NASIOC |
04-18-2015, 10:23 AM | #28 |
Member#: 281522
Vehicle:05 Outback 2.5XT Silver |
I do a lot of driving 22k+ miles. i do track my car once a year. Main reason is the fact that my obxt brakes where under powered and now the lgt brakes are just sticking and they still feel over whelmed stopping my 3600lb car.
Modulation on LGT and obxt brakes is horrible well known issue. Sti brembos are a massive upgrade even though they are 10mm larger. Problem with sti brembos is that because they are compatible will all other Subaru they are over priced used. The Evo brembo's have the issue of bleeder upside down and Nissan 4pots can't use all the lgt rotor so u heat soak them easily. their are lots of different parts available. the 6pot kit is awesome. would love to get it but it's 3x my budget right now. |
04-18-2015, 02:17 PM | #29 |
Member#: 97135
NWIC
They are an upgrade in terms of heat dispersion and a marginal upgrade in pedal feel...brembos will not help your car stop any faster.
Stock brakes aren't "underpowered", but more likely some things have been skipped over or parts are worn or not ideal in your specific setup. Have you done prides/pads/fluid yet? Tire compound is hugely important. Just saying "255's" doesn't mean much - especially when you don't mention wheel dimensions. They could be crappy nexen or wanli tires, and in that case size is irrelevant. |
04-18-2015, 03:22 PM | #30 |
Member#: 10228
Vehicle:2002 Subaru WRX |
Or any brake ducting...
04-19-2015, 12:14 AM | #31 |
Member#: 281522
I run sticky hankook 255/50R17's When i'm doing 70 on the highway. stomp on the brakes and your face should be torn off with the right setup. I run lgt calipers dba 4k slotted rotors and hawk hps 5.0+ pads and grimmpseed brace. Fluid is new i flushed it last summer. it's never been what i wanted since i swapped. yes it is great but my redline and my cavalier i built with upgraded pads and rotors would rip your face off. The last STI/wrx cruise i could feel how bad this setup compares. STI ms swap just makes your brakes an on off switch due to the differences and SS lines aren't going to improve the stopping power. Ive already upgraded the brakes to lgt spec. Subaru really didn't design the brakes for performance.
04-19-2015, 11:29 AM | #32 | |
Member#: 10228
How about brake pedal free play? How about looking into alternative master cylinders? Perhaps you need something better than Hawk pads. |
04-19-2015, 12:48 PM | #33 |
Member#: 281522
Nope swapping parts with out research is never the answer.
Pads where stoptech streets and then advanced auto ceramics before hawks. That's why i was in this thread to get info on this. to see how well they worked since they where designed to stop a heavier car. Brake pedal is mushy when i had the obxt brakes and the lgt brakes have firmed it up. a different master was researched since to replace it you need a different booster. sti master and booster bolt up but have the issue of making the brakes an on off switch. If no one has any information on this swap then i won't try it. I'm not a shop so research and development isn't in the budget. It's a daily driver so i will just save up and buy the innovative setup and get sti brembo's for the rear. Thanks for the help. |
04-19-2015, 02:01 PM | #34 |
Member#: 319017
Also 3600 pounds is not that heavy
A mustang gt weighs that much... Sent from my iPhone using NASIOC |
04-19-2015, 05:08 PM | #35 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
I would ****can those pads....they are at least part of the issue....it is possible that you have some other issue as well, but I would get some different pads--something less....something more....better and maybe even replace the master cylinder and get a master cylinder brace and what tires...SPECIFICALLY.....EXACTLY are you running??? is the ABS engaging when you stomp the pedal? |
04-19-2015, 09:24 PM | #36 |
Member#: 281522
I am still looking into pads.
I already have the grimmspeed master cylinder brace Tires are these. http://www.discounttiredirect.com/di...0&rd=17&cs=255 ABS doesn't turn on unless it's snow or really wet out. Through out my build the brakes have been the week spot. I'll just save my cash and add a BBK setup to next step. 6spd was the best. |
04-19-2015, 09:35 PM | #37 |
Member#: 97135
NWIC
As has been said several times - its not going to simply work like that. it won't have the impact on stopping distance that you think it will. Look at the stopping distances between the wrx and sti (at least for 06-14, haven't checked the 2015 braking numbers) are within a couple of feet of each other, which can easily be explained by a few key differences - and its nothing to do with the brakes.
the rotors literally mean nothing. I agree with scotty about the pads, and I would even look at new tires as well. |
04-19-2015, 10:37 PM | #38 |
Member#: 10228
That is not a great tire at all....
04-20-2015, 01:12 AM | #39 |
Member#: 16200
OK...ua got **** pads...**** tires...and no mc brace....and likely need to re-bleed
you don't need any bbk...you NEED to un-do what you have done wrong and move ahead |
04-20-2015, 06:54 AM | #40 |
Member#: 281522
I know the pads are crap. It's my third set of pads i have tried.
the tires do grip pretty well no re003's but the 5.0's can't overwhelm them. I have a MC brace and my fluid is still clear. |
04-21-2015, 08:13 AM | #41 |
Member#: 281522
This came up because i have to replace the one caliper and have never been happy with the brake feel. So instead of just replacing the one caliper. Thank you to every one that has tried to help i did not ignore you and i will try a Either carbotech 1521 with my new caliper or portfield r4s street. Considering no one has stepped in and brought information on it I'm guessing this was an idea that never paned out past the 6piston setup.
04-21-2015, 08:36 AM | #42 |
Member#: 16200
this is NOT any issue with the number of pistons in the calipers
this is some other issue that you haven't addressed yet |
04-21-2015, 09:40 AM | #43 |
Member#: 281522
Sorry meant that it wasn't a project some else took on past the innovative setup.
I don't plan on doing this swap anymore. I may eventually buy the innovative setup which is a complete package. Thanks uncle scotty for your input. |
09-10-2015, 10:18 AM | #44 |
Member#: 281522
Old thread but i figured i would update it and explain. after more research and weighing the car. yeah 3600lbs figure i got off the forums was very incorrect. With the 6spd and everything on my car full tank of gas two car seats 4523lbs.
Fluid flush pad and rotor change didn't help. still can't overwhelm those "****y" as you claim hankook tires. But i have a plan in place since next year i have to replace tires brakes will also be upgraded. |
09-10-2015, 03:32 PM | #45 |
Member#: 120
AKIC
Where did you weigh it? When you say "everything on my car", do mean 800 pounds of extra stuff? The curb weight of a 2005 Outback XT Limited is 3500#, 3565# with the automatic; the non-Limited was 85# lighter. A 6MT adds ~75# over a 5MT, add maybe another 50# for 2 baby seats and you're still coming up waaaaay short of 4523#.
09-10-2015, 05:07 PM | #46 | |
Member#: 319017
This .... How did you add hundreds of pounds lol. Time to visit a better scale and or you have the heaviest subaru record. Sent from my iPhone using NASIOC |
09-11-2015, 08:03 AM | #47 |
Member#: 281522
Door tag is 4545lbs. 07 spec b door tag had 4325lbs. so unless Subrau is lying on the door tags they are heavier than most people believe. I added 75 on top for larger swaybars, FMIC and 6spd. Next time i go to the track i am going to throw it on their scale.
09-11-2015, 04:35 PM | #48 |
Member#: 11652
E. Canada
Vehicle:'18 Focus RS Red '70 Porsche 914/6 |
Ugh. Door tag is GVWR... Gross Vehicle Weight Rating. That is, how much the vehicle can weigh when fully loaded. Nothing to do with the weight of the vehicle. Well... I guess the weight of the car factors into that.
09-11-2015, 04:55 PM | #49 | |
Member#: 10228
09-11-2015, 11:17 PM | #50 |
Member#: 281522
Sorry so much going on i had a brain fart. I completely forgot that. still brakes feel like ****. lol
Stock STI 6mt Trany mount VS STI Group-n Trany Mount? | KiggerSTI | Transmission (AT/MT) & Driveline | 10 | 06-04-2010 02:06 PM |
BMW M3 vs. Audi RS4 vs. Cadillac CTS-V vs. Lexus IS-F vs. Mercedes C63 AMG | AVANTI R5 | Non-Subaru News & Rumors | 19 | 02-24-2009 12:10 PM |
Cadillac CTS vs. Infiniti G35 Sport (Road & Track) | NYCshopper | Non-Subaru News & Rumors | 8 | 11-11-2007 01:15 AM |
BMW 545i 6spd or Cadillac CTS-V? | xfactor834 | Off-Topic | 25 | 03-24-2004 03:49 PM |
Has Anybody Driven the Cadillac CTS? | Dewey 8d | Off-Topic | 26 | 05-01-2003 07:25 PM |
