Old 04-19-2021, 08:28 PM   #1
SuBBIEBrad82
Member#: 522452
2016 WRX Prem
Default Hard pedal.. feels like no brake booster...??
So I just did a couple mods over weekend.. Installed Grimm Speed EBCS..full EGR deletes and IBRC full TGV deletes..and new j-pipe.. flashed new new to support new mods and car started up and idles well went through bleeding procedures for coolant and followed tuners directions.. well went to drive it and my brakes aren’t quite up to speed.. like it feels like a have to power brakes.. no lights or codes or anything was able to drive but definitely no power brakes ***129335;***8205;***9794;***65039; Please advise and thanks for any help
SuBBIEBrad82 is offline   Reply With Quote
Old 04-21-2021, 05:11 PM   #2
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
make sure you didn't inadvertently disconnect your vacuum line that runs to the brake booster. It's also possible it cracked when you were moving stuff around.
GeoNV is offline   Reply With Quote
Old 04-21-2021, 05:36 PM   #3
Jedi03
Member#: 491095
2009 STi Blue
+1 on the disconnected/cracked line, would be obvious vacuum leak in the engine bay...also random thought would be hard but if you accidentally plugged that hole would also cause issue
Jedi03 is offline   Reply With Quote
Old 04-21-2021, 09:18 PM   #4
ronemus
Member#: 124146
'17 Outback 2.5i
Premium Tungsten
It could also be the in-line anti-backflow valve installed backwards.
ronemus is offline   Reply With Quote
Old 04-23-2021, 10:22 AM   #5
SuBBIEBrad82
Member#: 522452
2016 WRX Prem
I got it.. failed to tighten EGR block off plate caused vacuum leak at manifold
