Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 10-19-2019, 04:48 PM   #1
michelle_lynn
Member#: 484798
2015 WRX
Default Shifter making noise while in neutral going side to side and getting stuck** HELP**
2015 Wrx
Stock clutch, stock transmission
Still shifts into all gears no grinding just having this issue going back to neutral it gets stuck and makes this noise.
michelle_lynn is offline   Reply With Quote
Old 10-22-2019, 03:48 AM   #2
breathless2410
Member#: 507629
Have you checked your car fluid level? It may cause noises. Just read this article which might be helpful for you https://www.obdadvisor.com/how-to-fi...sion-problems/. Let's check it if there's any useful information
breathless2410 is offline   Reply With Quote
Old 10-24-2019, 06:46 AM   #3
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Start with the simply stuff
1. check oil, however i doubt this is the issue.
2. remove boot and check shifter in cabin
3. check shifter linkages under car.
4. check lockout barrel
runner19 is offline   Reply With Quote
Old 11-07-2019, 06:19 PM   #4
michelle_lynn
Member#: 484798
2015 WRX
Had the transmission looked at it’s something internal. Might be more worth it to just buy a used tranny?
