11-23-2017, 01:04 AM | #30026 |
Member#: 421858
Vehicle:2012 Impreza |
I've kind of wanted to get king standard height springs since they're a little stiffer, I carry really heavy tools in the back pretty often and I'm sure it makes the springs drop significantly, which doesn't help considering I'm usually driving off road on farms when I'm carrying tools.
11-23-2017, 08:35 PM | #30027 |
Member#: 295513
Vehicle:2012 Imp Prem Hatch Camellia Red Pearl |
Sounds like a Subaru is just right for a farrier. I used to have to hold my horse while he was being shod because he couldn't stand being tied. I admire you for sticking with that job. It's hard work. There's a lot more to know about equine foot care than most people realize. Thanks for what you do!
11-23-2017, 09:27 PM | #30028 | |
Member#: 421858
11-24-2017, 08:39 PM | #30029 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
would switching to my e85 tune and running some e85 through help my possible sticking rings issues?
11-25-2017, 10:23 AM | #30030 |
Member#: 306129
Anyone having an issue with the sun visors? My wife has done "something" to the passenger side one that anytime she turns it to the side, it falls out. It's clipped in for looking forward, but rotate it 90 degrees to block the sun from the side, and bam, it's sitting in your lap. I looked up the hole and all the clips are in the socket, no damage to the plug on the visor, it clips in firmly, etc.
I almost never use mine since I carry sunglasses with me whenever I leave the house, so I don't know if it's just due to how frequently she uses her side or something, but even then, she rides in my car at most once or twice a week, not a daily thing. |
11-25-2017, 12:10 PM | #30031 |
Member#: 421858
11-25-2017, 12:22 PM | #30032 |
Member#: 348055
Vehicle:2013 Impreza 5MT ISM |
Passenger sideskirt took a hit when during my road trip last month. Finally got around to it.
The mounts for the pop-it clips attached the sideskirt are terribly designed. I should have take a picture. Theyre thin "fins" that attach the mount to the sideskirt itself rather than the complete edge. If this makes sense... [| when they should be || . Anyhow, just threw some globs of epoxy on the couple broken mounts, filling in the space between the "fins" as well for more security. Havent been driving much lately and it seems I had a visitor in my engine bay making a nice home right next to the FB20 stamp. Fortunately it was more interested in the wire looming for my foglights than anything important. |
11-25-2017, 07:38 PM | #30033 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
Just pulled the front seat and carpet a few days after a diet Coke spill.
The carpet backing is impermeable and traps liquid in the foam padding regardless of how well you vacuum or ventilate. Fortunately I don't take milk or sugar in anything, or the car would've been totaled. |
11-27-2017, 08:24 PM | #30034 |
Member#: 421858
If any of you are ever poking around in your engine bay and have a multimeter near by, if your car has been off for at least a few hours you should check the voltage and see what it's at. I'm interested in what other peoples' are at depending on the age and battery CCA and all that.
11-27-2017, 08:29 PM | #30035 | |
Member#: 348055
11-27-2017, 08:37 PM | #30036 |
Member#: 421858
Just wondering, my battery that's just over a year from manufacture settles around 12.4-12.5v which is a little low but not bad.
11-27-2017, 11:44 PM | #30037 |
Member#: 319157
It's not low. Unless you're having trouble starting, forget about it.
Voltage isn't a direct indicator of battery health. High voltage is actually detrimental to longevity. You're spending way too much time worrying about something that costs $100 and carries a 3+ year warranty. |
11-28-2017, 09:35 AM | #30038 | |
Member#: 348055
Hell, I look for excuses to use my multimeter out of curiosity. |
11-28-2017, 01:20 PM | #30039 | |
Member#: 319157
11-28-2017, 01:23 PM | #30040 |
Member#: 421858
I'm not worrying. I'm wondering.
I also suspect these cars come with 390CCA battery because lower CCA batteries usually handle heat better and our engine bays get retardedly hot even on cold days. Maybe not a ton hotter than other cars but I'm sure they didn't waste money on figuring out how to cool the engine bay of a ****box NA. |
11-28-2017, 01:23 PM | #30041 |
Member#: 348055
11-28-2017, 01:31 PM | #30042 |
Member#: 314216
I don't think the engine bay gets any hotter than any other vehicle i have driven, I also have a manual which puts out nowhere near the heat of a CVT
11-28-2017, 02:44 PM | #30043 |
Member#: 421858
When my CVT was getting to 1337º it didn't seem to make the engine bay any hotter than short drives where it only gets to 180º.
11-28-2017, 04:14 PM | #30044 |
Member#: 348055
12.53vdc.
11-28-2017, 04:24 PM | #30045 |
Member#: 319157
There's nothing unusually hot about our engines or engine bays.
The oil runs cooler than the coolant, there's no turbo and the exhaust manifolds face the ground. Subaru has a lot of experience packing twice the power into similar platforms, so I highly doubt cooling the GP/GJ was a challenge. |
11-28-2017, 05:18 PM | #30046 |
Member#: 306129
11-28-2017, 05:59 PM | #30047 | |
Member#: 421858
When you're driving across the country and don't have extra time to do it, you can't worry about the CVT being 10-50f over what it should be. Just change the fluid when you get back and it should be fine.
I gave the dealer every opportunity to make loads of money off me by telling them to change it but they didn't so I had to replace it on my own. Quite frankly I'm not sure the monkeys that worked there would have known what they were doing anyway. ***55357;***56397; Quote:
11-28-2017, 07:23 PM | #30048 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
I want my car to run hot, the faster it warms up the better it gets cold as hell here.
It's a Subaru made for cold weather. |
11-28-2017, 09:37 PM | #30049 |
Member#: 421858
Take off your intake snorkel and use a piece of dryer exhaust tubing to make it suck air from a semi-enclosed space near the engine.
11-29-2017, 08:09 AM | #30050 |
Member#: 314216
2012 Impreza thread
Car been sitting since Sunday afternoon. 30F amd 4+ year old battery (installed 7/24/13) was 12.3v this morning
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
