Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 03-31-2009, 02:31 AM   #26
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Originally Posted by 06rexwagon View Post
Ok that thread confused me even more. I read in multiple places that people are running the 044 off a relay triggered by the stock fuel pump controller. That thread says it can't be done that way. I'm running a stock ECU.
It can be done, but isn't suggested. Run a seperate relay to the bosch and call it good.
speed_freak27 is offline   Reply With Quote
Old 03-31-2009, 02:35 AM   #27
n2oiroc
Member#: 141952
2023 M340i
it sounds like things are getting confused a bit here. he can run some heavy gauge wires from the battery to the relay and trigger the relay with the fuel pump controller relay. unless i looked at it wrong, my sti's fuel pump controller is powered by a relay that goes on with the ignition switch.
n2oiroc is offline   Reply With Quote
Old 03-31-2009, 08:05 AM   #28
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
I mentioned the relay, just wanted to know how to trigger it? Just from the stock controller or by the ignition?
06rexwagon is offline   Reply With Quote
Old 03-31-2009, 02:21 PM   #29
n2oiroc
Member#: 141952
2023 M340i
the ignition triggers a relay for the stock controller and its already back there. check a diagram and use the current relay trigger for the new one.
Old 03-31-2009, 02:28 PM   #30
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
I have some heavy gauge wire from the battery running dirrectly to the + on the pump, and a relay on the ground side connected to the stock controller.
I know there was a diagram floating around on the boards somewhere.
ec2k1gt is offline   Reply With Quote
Old 03-31-2009, 10:52 PM   #31
TDagen
Member#: 163648
V9 6mt R180 Brembos
What is the best way to run the bosch intank wiring?
TDagen is offline   Reply With Quote
Old 07-08-2010, 11:09 AM   #32
06njsti
Member#: 150986
06 #001 LSB STi
bump this from the dead, i need to get an 044 intank in the next few weeks. or ill be running dual walbro's
06njsti is offline   Reply With Quote
Old 11-04-2010, 07:44 PM   #33
JeankySti
Member#: 170370
2006 STi
Precision 6262 Powered...
Bump for more options!
JeankySti is offline   Reply With Quote
Old 11-04-2010, 10:48 PM   #34
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Element Tuning makes a complete kit for exactly what you want to do. It comes with the wiring, instructions, etc.
dexterous is offline   Reply With Quote
Old 11-05-2010, 02:53 AM   #35
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I assume this is something we have to call Element about.
aboothman is offline   Reply With Quote
Old 11-13-2010, 01:21 AM   #36
SickScoob
Member#: 220500
05 STi 30R
CGM
Im in the same boat, I wanna do the 044 inline. I don't wanna run dual fuel pumps.
But in case you decide too, I found this.
http://www.fullblownmotorsports.net/...roducts_id/119
We've designed a dual pump hanger for the Subaru WRX. This kit will include everything you need to mount (2) walbro 255hp pumps inside the tank. We have tested this setup up to 900+hp in many other vehicles. No more sumping the tank or modifying the tank to make power. This is the last fuel system that you will need. ** we offer complete kits that include lines to the front of the vehicle and back as well. Please contact us for more details.
SickScoob is offline   Reply With Quote
Old 11-13-2010, 09:16 AM   #37
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Originally Posted by cubuff View Post
I am trying to avoid running 2 walbro's in tank feeding my swirl pot. I am thinking about running a 044 in tank has anybody done this before? Is the 044 even made for in tank placement?
The Bosch 044 is an inline pump. I am running the Bosch 040 in-tank pump. It replaced my Walbro. I'm also using T1 Racing Developments top feed conversion kit with ID1000's that setup is enough to get me436/426 @ 24psi 93oct. 499/468 @ 28psi on MS109. I don't know what the IDC's are though. I haven't been told or been able to see a log. I'm curious to know how much headroom I have to be able to run E85 but wont care for it for at least a couple years.
armyssoldierboy is offline   Reply With Quote
Old 11-29-2010, 10:33 PM   #38
amalgrover
Member#: 183480
just in case anyone was even thinking about using that link a couple posts up for that dual walbro setup that costs like $600 with the pumps...
here is the bushur setup...you send in your stock fuel pump assembly and they send back a dual pump setup with everything you need for $400
https://secure.buschurracing.com/cat...a5bacdecb15d42
OR...a guy john 1badsti over in the e85 thread knows how to aquire all the parts to build basically the same setup as the bushur one for a little cheaper...
...just some fyi for anyone using the search button in the future...
amalgrover is offline   Reply With Quote
Old 11-29-2010, 10:53 PM   #39
n2oiroc
Member#: 141952
2023 M340i
the 044 works great intank. my sti got wrecked but i yanked out the intank setup i had in it.
http://forums.nasioc.com/forums/show...&highlight=044
Old 11-30-2010, 12:29 AM   #40
wheatpaste
Member#: 170747
2004 WRX Wagon
Did you just hose clamp it to the stock hanger?
wheatpaste is offline   Reply With Quote
Old 11-30-2010, 02:16 AM   #41
sorrowfulkiller
Member#: 170439
I <3 Lamp
I don't see the big issue here.... Cut off the big c shaped piece holding the walbro/stock in-tank pump on the bottom, buy a 2.25 fuel pump bracket, or make one.
http://compare.ebay.com/like/3102740...=263602_304662
^ Fuel pump bracket
Mount pump, trace wires with ohmmeter that go to the stock pump, cut those wires from the outside leaving enough room for soldering new wires on, attach said wires to a relay to turn on when ignition is on, on the inside of the tank cut the electrical connector that originally attached to the in tank pump and connect those wires to the 044, put on the sock mentioned previously and done!
not ****ing hard
sorrowfulkiller is offline   Reply With Quote
Old 11-30-2010, 11:17 AM   #42
n2oiroc
Member#: 141952
2023 M340i
among other things, yes. there are a couple mods that need to be done like shortening the hose on the outlet side but its all easy.
Old 12-21-2017, 09:05 PM   #43
Boxer4turbo2004
Member#: 106190
Originally Posted by ScorpionT View Post
The 044 is inline only, cant go in the tank. Im in the process of building a fuel system for someone, and I have found 2 pretty good options. A dual fuel pump hanger, and the TurboXS surge tank. Both are designed for a pair of Walbros.
I really like the idea of the surge tank, because you have the option of running dual pumps.
you are incorrect sir...I have a one installed in the tank using stock hardware piece of cake
Boxer4turbo2004 is offline   Reply With Quote
Old 12-21-2017, 11:33 PM   #44
smileysti
Member#: 344246
I used an 044 in my 2007 sti tank. It worked well, but that sucker was loud once the fuel started dipping below a quarter tank.
Fine Line Imports made a kit to do just this. There site seems to be down right now for a redesign.
smileysti is offline   Reply With Quote
Old 12-21-2017, 11:40 PM   #45
funk32
Member#: 245787
GD Race Car
I also used a 044 in tank without issues, MSI made a kit that fine line imports was selling.
funk32 is offline   Reply With Quote
Old 10-26-2019, 09:36 PM   #46
PDXREALTOR
Member#: 468393
2017 STI
Will the 044 fit in tank in a 15+ sti without any additional parts or is the msi kit needed on the newer cars too? The product info says only good for 07 and older so I'm wondering how this gets installed on a 15+.
PDXREALTOR is offline   Reply With Quote
Old 10-26-2019, 10:39 PM   #47
06rexwagon
Member#: 114730
9.8@150
Highly unlikely. The housing on the 15+ is completely different and the factory pump is smaller than the 04-07. The 044 is pretty outdated and there are a lot of 300+ lph drop in pumps that perform pretty well if you use a hardwire kit.
Old 10-27-2019, 11:37 PM   #48
PDXREALTOR
Member#: 468393
2017 STI
Thanks for that info.
wiring up walbro 255/bosch 044 to run 100% ? Rod702 Built Motor Discussion 56 08-03-2011 09:48 AM
WTB: BOSCH 040 Intank Fuel Pump bjohnson_55 Private 'Wanted' Classifieds 0 04-15-2010 06:54 PM
Bosch 044 pumps, Magnafuel Fuel Pressure Regulator, Tial 1 bar wastegate springs jigga Engine/Power/Exhaust 14 06-05-2008 08:19 PM
FS: new Bosch 044 fuel pump garagedefeat Engine/Power/Exhaust 7 04-08-2008 10:18 PM
FS: Bosch 044 pump, magnafuel external pump, 044 pump holders, weldon pump controller jigga Engine/Power/Exhaust 8 10-19-2007 11:31 AM
