10-29-2019, 08:44 PM | #276 |
Member#: 496760
11-12-2019, 03:50 PM | #277 |
Member#: 508278
Lots of good info thanks!
04-20-2020, 08:31 PM | #278 |
Member#: 427887
Vehicle:2000 2.5RS w/ EJ205 White |
Really appreciated the insights! This will be great for keeping my 2000 RS running strong - 240,000 miles currently
05-10-2020, 07:29 PM | #279 |
Member#: 514629
Posting here to unlock the ability to post my own thread
I have a 2004 WRX 2.0L turbocharged four cylinder engine in my Factory Five Racing 818c kit car. Now, I need to replace my cam seals since one of them is leaking. I do not want to screw anything up and risk ruining my engine or pistons, or valves.
I have scoured this forum and have found multiple ways of removing the timing belt without damaging valves, or damaging anything else. Some folks say, just take the damn belt off and worry about lining everything up later using the factory markings on the crank pulley and cam pullies. Some folks say you HAVE TO tie everything up so that nothing moves using vise-grips and spare timing belts to lock cam pullies in place. Why have I seen so much variation, and why do some people seem to believe it is essential to lock 'em up, while others let 'em go and worry about lining stuff up aftwards? can someone help me decide what to do and what the risks are? thank you! Last edited by kerdizo; 05-10-2020 at 07:45 PM. |
05-11-2020, 12:37 PM | #280 |
Member#: 514629
last post before I can post my own thread
Hey there sub owners! looking forward to sharing ideas and knowledge In this forum, this is my last "reply" before I can post my own thread!
01-09-2022, 01:31 PM | #281 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
Company 23 cam locking tool is my friend, install the tool and remove the old timing belt without having to worry.
09-24-2022, 06:06 PM | #282 |
Member#: 531504
Need some help replacing Bank 1 VVT solenoid
Hello everyone, I have been looking through the forums but haven’t been able to find someone with the same issue as mine. I’m currently getting a small oil leak from my passenger side bank 1 exhaust VVT solenoid (10917AA060) and it’s burning on my exhaust causing a horrible smell. I have the part I need but had a question about installation. I know the exhaust manifold has to be moved in order to replace the VVT, but since this is my first time dropping the manifold I’m not sure if the O2 sensor needs to come out before removing the manifold or if I can just unbolt the manifold and lower it slightly without completely removing it to access the VVT. Any help here would be appreciated, thanks!
03-26-2023, 04:28 PM | #283 |
Member#: 533691
Newbie
Hi,
I am new and trying to understand navigation of the site/forums, etc. I'm looking to get some info on repairing/replacing the engine of a 2005 Saab 9-2x, which is just a Subaru WRX, four-door wagon, with a 2.5L Linear. Everything under the hood is Subaru. Although, I'm sure you are familiar. It recently has been diagnosed as having a blown head gasket, after initially thinking it was the water pump(water pump and timing belt replaced). It still cranks and runs, etc. The crazy part of it all is how ironically good the engine is-to it's own detriment. Now, in hindsight I realize the issue came to a head after running for over a year, with no overt symptoms/signs of not having any fluid in the system; until eventually and finally beginning to stall the engine, once hot enough, in order to save itself. However, it was too late. Any information on most affordable parts, best sources, options, ideas or best way to seek buyers for a good fixer upper, would be greatly appreciated. Thank you Last edited by iamabillionaire; 03-27-2023 at 10:28 PM. |
04-11-2023, 10:02 PM | #284 |
Member#: 533875
Vehicle:2019 WRX STI Dark Blue |
Newbie
Just replying to be able to post a thread on some issues I am having with my 2019 STI.
08-13-2023, 03:42 PM | #285 |
Member#: 90354
International
Vehicle:2018 STI WRBP |
Motul Gear 300 LS
Is anyone using this? The shop said that this is better than the 300 but from what I've been reading it's not and shouldn't be used? Car is a 2018 STI
03-04-2024, 03:20 PM | #286 | |
Member#: 536391
Small fee?
Pasted directly from the url above: 72 Hours (3 days) @ $34.95 - 30 Days @ $299.95 - 365 Days (1 year) @ $2499.95 While Haynes and Chilton manuals are sort of OK they are often inaccurate or incomplete based on my experience. Factory manuals are really the stone tablets of automotive repair. But not worth what Subaru is asking. Search eBay or just google search factory repair manuals. You’ll find links where you can down load pdf factory manuals for free. Last edited by Wyoming Bound; 03-04-2024 at 03:50 PM. |
03-11-2024, 07:37 AM | #287 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
Yikes. The price on these has gone up a lot. My old memory says it used to be like $20/year or you could buy the whole printed set for like $200.
Similar Threads | ||||
Exhaust FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 318 | 09-06-2021 04:50 PM |
Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 396 | 07-09-2020 02:25 AM |
Pulley FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 120 | 01-29-2020 09:15 AM |
Downpipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 338 | 10-25-2019 12:04 AM |
