05-16-2012, 12:48 PM | #76 |
Member#: 62856
Vehicle:MBP SQC#197 Stockpiling parts... |
$1100? Yikes!
I still havent had mine fixed for almost 4 years now...I'm afraid of prices like that. Just gotta find someone who can sneak me into their shop and pick up an expansion valve...
05-19-2012, 06:01 PM | #77 |
Member#: 320650
Vehicle:2004 Subaru WRX STi |
busted condenser
First of all thanks to txl146 for making this thread, lots of good need-to-know info here that I did not know. Second, thanks to stikboy9 for the tip about borrowing a vacuum for autozone. Third, thanks to HellaWRX for the tip about rockauto.com, way easier to deal with than classic radiators on Ebay.
I haven't had A/C for at least a couple years now. Hard to say exactly because I just got my license back. I was told last week by the shop that a vacuum test proved I have a leak in the system, and that it is bone-dry. Today my neighbor (big car guy) tried putting freon/die into the system to try to spot the leak. Didn't put a can in before realizing that it was just spraying back out from somewhere in front of the radiator, but the compressor IS working at least. I didn't have a UV light on hand but it was fairly easy to trace the source of the loud hissing sound. Looking closer at the condenser I noticed the mounts at the bottom are both broken and hanging in the air, and the condenser is bent in toward the radiator so badly I can't even pull it forward enough to line up the mounts with the holes. Never noticed that before, but time to get a new condenser. So basically this is my plan, using methods prescribed in this thread, after I just doublecheck with a UV light to confirm it isn't possibly a bad O-ring: 1. Order condenser/removable dryer from rockauto 2. Replace the condenser/dryer, and any O-rings I see, without removing the radiator 3. Get ahold of a vacuum and get any moisture out of the system, while leak testing (or have someone do it for me) 4. Fill it back up with oil/freon mixture BTW, I considered using a can with leak-stop for all of about 5 seconds, as I don't want complications down the road from plugged lines. |
01-11-2013, 04:31 AM | #78 |
Member#: 343251
Very very informatic post..I like this one. gotta bookmark this one.
08-15-2015, 06:41 PM | #79 |
Member#: 392212
First off, thanks for all the information in this thread! I'm about to replace most of the AC parts on my 02 wrx: condensor, compressor, expansion valve. When I bought the car the previous owner said the compressor locked up on him and he never got it replaced.
I had a question on flushing the system to eliminate any metal particles that are in the lines after the compressor failure. Do I need to flush the system before I install the new parts or can I install everything and have a shop just flush the high and low pressure lines independently? I'm planning on calling a shop on Monday to ask them this question, but I had some free time and wouldn't mind getting started on the job this weekend if possible. Has anyone had any experience with this? Thanks! |
02-08-2016, 08:13 AM | #80 |
Member#: 341826
International
Vehicle:2005 WRX MY06 Light Bluish Silver |
Hey guys, sorry to rebirth a dead thread, but has anybody ever replaced their dryer WITHOUT replacing the condenser? I've just swapped my compressor out and now I'm looking at the thing like: "it's one bolt, surely I don't have to take my rad out???"
07-18-2016, 04:24 PM | #81 |
Member#: 450954
Vehicle:2007 Impreza 2.5i Blue |
About the drier replacement, I've done it before. It can be done while condenser is on the car and fairly easy except installing new o-ring can be a bit of pain.
07-18-2016, 04:26 PM | #82 |
Member#: 450954
To the original poster, or others with experiences, how is the aftermarket expansion valve from Autozone working out? My main concern is the fitment.
07-06-2017, 10:28 AM | #83 |
Member#: 220040
South East
Vehicle:2008 Impreza WRX |
Reviving a fantastic dead thread.
My compressor clutch wheel sticks. I can drive for anywhere from 5-30 minutes in Florida heat before the compressor clutch sticks and I no longer have AC. If I rev my engine to ~5.5 - 6k RPM, it'll sometimes kick back on. If it is off and I take a wrench to the clutch wheel and just quickly jab it, it unsticks and kicks back on. I am assuming I need to replace my compressor only. Good assumption? |
07-06-2017, 07:05 PM | #84 | |
Member#: 33868
Vehicle:2003 wrx srp |
07-06-2017, 08:11 PM | #85 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
Put an AC clutch relay in it.
Betcha cold beer that's the fix. I'm partial to a good unfilter wheat beer or a grapefruit radler that ain't too hoppy... |
02-13-2018, 12:14 AM | #86 |
Member#: 111692
ac repair
I am inspired by this thread to attempt diy ac repair. Couple of questions to clarify:
- for leak detection better use dye or sniffer? - on 04 wrx receiver dryer can be replaced w/o replacing condenser, right? - what is a better way to add oil in the system, ie from a pressurized can or using mechanical device attached to low pressure port? pressure can may not be precise? - can I just add oil gravimetrically directly in the new part b4 it gets installed - when you vacuum system you only remove refrigerant and not the oil so that you calculate oil needed strictly based on parts being replaced? |
08-16-2019, 11:49 AM | #87 |
Member#: 505344
More info
Any chance you can point me to the torque specs for the a/c compressor? Having trouble locating them and starting this job this afternoon. Mine is an O4 impreza 2.5l
09-09-2019, 10:16 AM | #88 |
Member#: 506169
Thank you for this write up!
11-10-2019, 05:05 PM | #89 |
Member#: 506272
Vehicle:2002 WRX Sedan Silver |
Great thread!
Unfortunately the photos seem to be the victim of Photobucket...they're blurry and watermarked. |
Similar Threads | ||||
Auto AC Repair...Fix teh hole or replace the line? | volume311 | Off-Topic | 17 | 08-03-2013 10:57 AM |
DIY AC Air filter clean | Liberty1996 | Legacy Forum | 3 | 07-11-2006 10:50 PM |
AC repair question - Is the repair suggested reasonable? | Malik | Service & Maintenance | 4 | 06-17-2005 12:47 PM |
HELP: home furnace/ac repair | subie2b | Mid Atlantic Impreza Club -- MAIC | 0 | 08-20-2004 05:20 PM |
Home AC Repair suggestions... | kschmohl | Mid Atlantic Impreza Club -- MAIC | 8 | 07-01-2004 02:54 PM |
