03-31-2009, 02:31 AM | #26 |
Member#: 30798
Vehicle:2001 RS-T Hybrid 2.5>2.2T>257>2.35S |
It can be done, but isn't suggested. Run a seperate relay to the bosch and call it good.
03-31-2009, 02:35 AM | #27 |
Member#: 141952
Vehicle:2023 M340i |
it sounds like things are getting confused a bit here. he can run some heavy gauge wires from the battery to the relay and trigger the relay with the fuel pump controller relay. unless i looked at it wrong, my sti's fuel pump controller is powered by a relay that goes on with the ignition switch.
03-31-2009, 08:05 AM | #28 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
I mentioned the relay, just wanted to know how to trigger it? Just from the stock controller or by the ignition?
03-31-2009, 02:21 PM | #29 |
Member#: 141952
the ignition triggers a relay for the stock controller and its already back there. check a diagram and use the current relay trigger for the new one.
03-31-2009, 02:28 PM | #30 |
Member#: 129631
Vehicle:06 Obp Sti back to slow lolz |
I have some heavy gauge wire from the battery running dirrectly to the + on the pump, and a relay on the ground side connected to the stock controller.
I know there was a diagram floating around on the boards somewhere. |
03-31-2009, 10:52 PM | #31 |
Member#: 163648
Vehicle:2002 WRX V9 6mt R180 Brembos |
What is the best way to run the bosch intank wiring?
07-08-2010, 11:09 AM | #32 |
Member#: 150986
Vehicle:06 #001 LSB STi |
bump this from the dead, i need to get an 044 intank in the next few weeks. or ill be running dual walbro's
11-04-2010, 07:44 PM | #33 |
Member#: 170370
South East
Vehicle:2006 STi Precision 6262 Powered... |
Bump for more options!
11-04-2010, 10:48 PM | #34 |
Member#: 23553
Vehicle:2005 STI - Insanity! 2014 WRX - Daily |
Element Tuning makes a complete kit for exactly what you want to do. It comes with the wiring, instructions, etc.
11-05-2010, 02:53 AM | #35 |
Member#: 127745
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
I assume this is something we have to call Element about.
11-13-2010, 01:21 AM | #36 |
Member#: 220500
Vehicle:05 STi 30R CGM |
Im in the same boat, I wanna do the 044 inline. I don't wanna run dual fuel pumps.
But in case you decide too, I found this. http://www.fullblownmotorsports.net/...roducts_id/119 We've designed a dual pump hanger for the Subaru WRX. This kit will include everything you need to mount (2) walbro 255hp pumps inside the tank. We have tested this setup up to 900+hp in many other vehicles. No more sumping the tank or modifying the tank to make power. This is the last fuel system that you will need. ** we offer complete kits that include lines to the front of the vehicle and back as well. Please contact us for more details. |
11-13-2010, 09:16 AM | #37 | |
Member#: 109424
South East
Vehicle:06 AW STI Twin Scroll HTA gt3076r |
11-29-2010, 10:33 PM | #38 |
Member#: 183480
South East
just in case anyone was even thinking about using that link a couple posts up for that dual walbro setup that costs like $600 with the pumps...
here is the bushur setup...you send in your stock fuel pump assembly and they send back a dual pump setup with everything you need for $400 https://secure.buschurracing.com/cat...a5bacdecb15d42 OR...a guy john 1badsti over in the e85 thread knows how to aquire all the parts to build basically the same setup as the bushur one for a little cheaper... ...just some fyi for anyone using the search button in the future... |
11-29-2010, 10:53 PM | #39 |
Member#: 141952
the 044 works great intank. my sti got wrecked but i yanked out the intank setup i had in it.
http://forums.nasioc.com/forums/show...&highlight=044 |
11-30-2010, 12:29 AM | #40 | |
Member#: 170747
BAIC
Vehicle:2004 WRX Wagon PSM |
11-30-2010, 02:16 AM | #41 |
Member#: 170439
Vehicle:I <3 Lamp |
I don't see the big issue here.... Cut off the big c shaped piece holding the walbro/stock in-tank pump on the bottom, buy a 2.25 fuel pump bracket, or make one.
http://compare.ebay.com/like/3102740...=263602_304662 ^ Fuel pump bracket Mount pump, trace wires with ohmmeter that go to the stock pump, cut those wires from the outside leaving enough room for soldering new wires on, attach said wires to a relay to turn on when ignition is on, on the inside of the tank cut the electrical connector that originally attached to the in tank pump and connect those wires to the 044, put on the sock mentioned previously and done! not ****ing hard |
11-30-2010, 11:17 AM | #42 |
Member#: 141952
12-21-2017, 09:05 PM | #43 | |
Member#: 106190
12-21-2017, 11:33 PM | #44 |
Member#: 344246
I used an 044 in my 2007 sti tank. It worked well, but that sucker was loud once the fuel started dipping below a quarter tank.
Fine Line Imports made a kit to do just this. There site seems to be down right now for a redesign. |
12-21-2017, 11:40 PM | #45 |
Member#: 245787
W. Canada
Vehicle:GD Race Car |
I also used a 044 in tank without issues, MSI made a kit that fine line imports was selling.
10-26-2019, 09:36 PM | #46 |
Member#: 468393
Vehicle:2017 STI |
Will the 044 fit in tank in a 15+ sti without any additional parts or is the msi kit needed on the newer cars too? The product info says only good for 07 and older so I'm wondering how this gets installed on a 15+.
10-26-2019, 10:39 PM | #47 |
Member#: 114730
SWIC
Highly unlikely. The housing on the 15+ is completely different and the factory pump is smaller than the 04-07. The 044 is pretty outdated and there are a lot of 300+ lph drop in pumps that perform pretty well if you use a hardwire kit.
10-27-2019, 11:37 PM | #48 |
Member#: 468393
Vehicle:2017 STI |
Thanks for that info.
Similar Threads | ||||
wiring up walbro 255/bosch 044 to run 100% ? | Rod702 | Built Motor Discussion | 56 | 08-03-2011 09:48 AM |
WTB: BOSCH 040 Intank Fuel Pump | bjohnson_55 | Private 'Wanted' Classifieds | 0 | 04-15-2010 06:54 PM |
Bosch 044 pumps, Magnafuel Fuel Pressure Regulator, Tial 1 bar wastegate springs | jigga | Engine/Power/Exhaust | 14 | 06-05-2008 08:19 PM |
FS: new Bosch 044 fuel pump | garagedefeat | Engine/Power/Exhaust | 7 | 04-08-2008 10:18 PM |
FS: Bosch 044 pump, magnafuel external pump, 044 pump holders, weldon pump controller | jigga | Engine/Power/Exhaust | 8 | 10-19-2007 11:31 AM |
