12-13-2010, 01:20 AM | #1 |
Member#: 225624
MAIC
Vehicle:1996 Legacy L Audi TT Nimbus Grey |
Anybody installed an MSD 8239 Ignition coil on their Subie?
96 Legacy with a 2.2. I'd like to know which wires go where. Its a 3 wire input plug. Msd says the center is +12 and the outer are -12 triggers. Other than that I would just be guessing. Thanks for any input.
http://www.amazon.com/gp/product/B00068OKZ2/ref=oss_product |
12-16-2010, 05:21 PM | #2 |
Member#: 203099
MWSOC
Vehicle:2005 Legacy GT Ltd Brilliant Silver Metallic |
Yeah you're right.
subie connector, read right to left 1, 2, 3. pin 1 is for cyl numbers 1 and 2 pin 2 is "12v signal in" pin 3 is for cyl numbers 3 and 4 The MSD connector reads left to right tho, opposite to the subie one. I think the wires colors are the same as mine. Here's a pic over on sl-i.net I thought I got it right the first time, but first start up on my car it backfired! So try the wiring thats in the pic. If it's not right switch around the 2 outer wires, then it should work. The center wire on the subie connector always goes the center wire on the msd connector. |
03-31-2016, 11:14 AM | #3 | |
Member#: 328383
one connector and its wires needs to be flipped. Here is a picture |
12-16-2010, 05:30 PM | #4 |
Member#: 225624
MAIC
Thanks! How did you mount yours, did you just use 2 of the mounting holes? Did you need to use different coil boots or did the factory ones work. Last question, how was the pizza?
03-04-2011, 10:06 PM | #5 | |
Member#: 203099
MWSOC
Anyways, you need some extended bolts, they are M6 x 2" bolts. You'll only need 2, because the msd coil is taller and a little longer than the subaru coil so only 2 bolts line up. Here's the thread from sl-i.net I used to make sure I had everything I needed: http://sl-i.net/FORUM/viewtopic.php?f=39&t=11704 |
03-03-2011, 09:46 PM | #6 |
Member#: 262067
Where did you get that black plug that goes to the msd box
03-26-2011, 04:59 PM | #7 |
Member#: 184412
TXIC
Vehicle:1989 Jeep Wrangler Cherry Red |
I just did the conversion and clipped off my old harness and tied directly into the stock harness wires. When doing it with the 8239 the wires are as follows:
Subaru > MSD Harness Yellow - Green Black - Black Red - Blue And that keeps the plug on the same side but the MSD logo will be on the back side. The bolt size you need is M6 x 45mm or 50mm and you only need 2. Since mine is a DOHC I went with the wires for a 98 Legacy and you don't need to mod them. |
01-24-2014, 11:36 PM | #8 |
Member#: 13910
NESIC
Vehicle:2005 Legacy GT blue |
Where do you get that black plug for the MSD?
01-25-2014, 12:24 AM | #9 |
Member#: 184412
TXIC
Its the flat pin connector from a 96-00 Dodge Neon. You can find one at a junk yard or from Napa.
02-13-2014, 10:13 PM | #10 |
Member#: 161832
Tri-State
Vehicle:2000 Outback Limited Black |
Any performance/results/power input?
02-14-2014, 01:37 AM | #11 |
Member#: 184412
TXIC
Yes there was a noticeable smoothness in the idle and I got a little better gas mileage. I'm sure on a dyno it would show the gain and probably show a smoother graph. Its a higher voltage which means stronger spark which equates to better fuel burn. Its like going from a regular distributor with separate coil to HEI ignition.
02-24-2014, 02:19 PM | #12 |
Member#: 328383
yeah this doesn't seem to work on an ej20k
07-18-2014, 12:06 AM | #13 |
Member#: 358689
02-25-2014, 12:18 AM | #14 |
Member#: 161832
Tri-State
I have a voltage regulator/grounding kit on my car already. I think I felt that type of gain after installing the grounding kit. Felt like there was a "wall" from 4500-redline before the install. Then it felt like there wasn't I e after the install. I also saw a small mpg increase.
Would the MSD add to what I've already felt? |
02-25-2014, 07:34 AM | #15 | |
Member#: 184412
TXIC
03-17-2014, 08:42 PM | #16 |
Member#: 229054
South East
Vehicle:1996 Impreza L Aspen White |
Plugs?
So I have a ej22e single port with 8239 msd. i've tried swapping the outer wires for the splice, i've used phase II plug wires with stock ngks plugs (bk9re or w/e). It misfires either way. Did you regap or replace your plugs?
03-22-2014, 01:48 PM | #17 |
Member#: 13910
NESIC
Will this be ok for plat plugs?
04-03-2014, 08:01 PM | #18 |
Member#: 385526
Vehicle:1999 Outback Sport White |
I tried retrofitting the Accel Neon coil to my Phase II EJ22. It burned my ignition coil fuse under the dash so I ended up keeping the stock coil. I ordered plugs and wires from hhttp://www.weaponxperformance.com/
The car is louder and smoother as confirmed by my peers. Here's a pic of the wires. |
12-13-2014, 07:28 PM | #19 |
Member#: 402305
I just picked up a neon coil and connector from a junkyard. Made sure to get a flat pin connector, coil looked fairly new. Installation was easy on my 98 obs ej22e. Plug wires already matched coil fine.
Soldered wires Sub yellow - neon black Sub blue - neon blue Sub red - neon green I only have 1 bolt holding it on the manifold, 22e intake mounts must be diff than some others. Fired right up. Idle is slightly smoother, biggest difference I noticed is it eliminated the stumble/hesitation from a start accelerating. Will keep an eye on the gas mileage next couple weeks. Will be getting an MSD coil in the future, but for $25 it works good. |
10-07-2019, 01:27 PM | #21 |
Member#: 437670
Vehicle:2005 2.5 SC OB |
Is this MSD ignition mod worth trying? I have a supercharged ej253 which is misfiring only under high boost and high rpm. NGK 48650 is plug and play and may be worth a try. Also 8.5mm wires are available...
10-07-2019, 09:56 PM | #22 |
Member#: 225624
MAIC
I noticed no difference. The factory Diamond coil might actually be better. Spend it on NGK plugs and have fresh wires.
10-09-2019, 06:44 AM | #23 | |
Member#: 437670
I’ve tried plugs. Iridium and copper with very tight gap, which of course is detrimental to HP if it’s not required for avoiding misfires. Going to try 8.5mm wires when I can locate the right ones. (Magnecor). I have 2 stock coils and they both misfire at high rpm and high load only on cyl 1 which seems very odd. I’m not entirely convinced it’s a spark issue. No idea about the Ngk coil pack but generally ngk products are good. |
Similar Threads | ||||
Anybody recently replace their clutch and/or flywheel on their Subie lately? | Newera09 | New England Impreza Club Forum -- NESIC | 6 | 11-01-2009 10:58 PM |
anybody have a pic with eibach springs on their suby | ineedparts | Interior & Exterior Modification | 12 | 02-18-2007 12:38 PM |
Anyone ever install an MSD ignition? | Blugin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 04-23-2003 11:45 AM |
('93-'01) Anyone have a problem with their ignition coil on MY99 | IMPREZIV | Impreza Forum | 2 | 04-18-2001 01:37 PM |
Has anybody installed an STI shifter? | Patrick Olsen | Legacy Forum | 0 | 05-13-2000 02:51 PM |
