Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2024
Old 08-18-2022, 11:09 AM   #351
Voodoo Rufus
Member#: 151528
2015 STI Launch Edn.
WRB!
If you already built your AWIC loop, you could just test by measuring how much flow goes into a bucket per certain amount of time.
The Pressure vs. Flowrate curves of the pumps will tell you what they're capable of. Finding the P-Q curves for the intercooler and heat exchanger might be more difficult though. If you could find them then you could calculate a rough real world flow rate.
Voodoo Rufus is offline   Reply With Quote
Old 08-18-2022, 11:10 AM   #352
Voodoo Rufus
Member#: 151528
WRB!
Old 08-18-2022, 11:14 AM   #353
pcampbell
Member#: 437670
2005 2.5 SC OB
Just had a thought… do you think hooking up a cheap flow gauge in line would be an accurate way to test the effectiveness of one pump versus another? I’m specifically interested in the Bosch cobra versus the brushless Davies Craig.
https://www.amazon.com/CGOLDENWALL-E..._id=3206433011
pcampbell is offline   Reply With Quote
Old 08-18-2022, 01:46 PM   #354
pcampbell
Member#: 437670
2005 2.5 SC OB
i can't figure out how i'd measure it into a bucket while replenishing the suction side haha. Maybe if I had a helper re-fill my reservoir while I was measuring the pressure side...
I know I've looked at the flow charts under pressure a few times. The davies craig flows quite a bit better under higher pressure. the thing is I don't know how much pressure or head there is in the system. Basically trying to justify the cost of the new pump
Old 08-18-2022, 01:52 PM   #355
Voodoo Rufus
Member#: 151528
WRB!
The Bosch Cobra is an OEM spec'ed pump. I'm sure it's fine for most reasonable duty.
I tend to like overkill setups, so I'd probably splurge on the pump.
Old 08-18-2022, 02:31 PM   #356
pcampbell
Member#: 437670
2005 2.5 SC OB
Hi thanks, yeah I think I will just pull the trigger and try it eventually haha
I looked again and the big thing seems to be that under pressure the Davies Craig out performs it by a lot. At ~200hpa it's not a big difference - ~1500lph vs ~1800 lph. 200hpa is 2.9 psi. I have no concept of what sort of resistance is in the system though.
But at 450hpa the Bosch at 500 lph and the Davies Craig is at 1200+ lph. If we are to believe the data sheets and if I converted them correctly! That is 6.5psi.
Even if the system resistance is only 150 hpa, I think it's a ~20+% improvement in flow on paper.
I've got a Type 13, but I've got a fairly large radiator out in front with lots of 90 degree bends....
Bosch cobra
EPB40
Old 02-10-2023, 03:43 PM   #357
pcampbell
Member#: 437670
2005 2.5 SC OB
Been doing a bit more research and apparently this pump is a little more expensive but flows a lot more. Really hard to compare these flow ratings without knowing the resistance of the system, but seems like the Pierburg flows the same under PRESSURE, what these other pumps do at 0 psi free flow. These are pumps used in BMW, Audi, etc. I'm assuming for their air water intercooler.
https://tecomotive.com/store/en/wate...0-3-water-pump
Old 02-10-2023, 03:57 PM   #358
Voodoo Rufus
Member#: 151528
WRB!
1.1bar and up to 60Lpm is a strong pump. I'm sure that would do the job. Any good heat exchanger should only have a couple psi differential for the water, so that pump should do nicely.
Old 02-11-2023, 06:24 AM   #359
pcampbell
Member#: 437670
2005 2.5 SC OB
Default The air/water intercooler thead
Super curious to see how it’d affect IATs. Apparently this (on paper) blows the Bosch one out of the water. Not yet sure how you mount it….
Regarding system pressure , by the time you add in the radiator and like 6 90 degree bends, wouldn’t that add quite a bit of resistance in the system?
Old 07-18-2023, 01:37 AM   #360
witman69
Member#: 534910
2006 Forester XT
Dark Silver
Cool Bosch Pump
Originally Posted by Titter View Post
is too much flow from the pump a bad thing?
im considering the bosch cobra pump as an upgrade for reliability. the base pump offered in the frozenboost kits looks really low quality.
problem is the cobra pump flows 314 gallons per hour while i see most ppl here running 200-300 litres per hour tops.
will this be an issue?
I run the Bosch Cobra pump on my 6.0 LSA. Monte Carlo SS(That is a 700 hp supercharged LS motor for you non-Chevy fans) It flows nice and isnt very loud at all when using the rubber mounts.
witman69 is offline   Reply With Quote
Old 07-18-2023, 10:09 AM   #361
Gluis
Member#: 245584
07 Impreza WRX STI
Actually I use a Meziere pump, which flows 20 Gallons per minute
Gluis is offline   Reply With Quote
Old 07-28-2023, 01:46 PM   #362
2tough3u
Member#: 535015
Originally Posted by bwrx03 View Post
Heres a few pics.
Please forgive the crappy pics and i know my paint sucks. Thats what happens at the track.
Is this the same thing as the Joe Cell?
2tough3u is offline   Reply With Quote
Old 03-16-2024, 05:22 PM   #363
frogmonk
Member#: 74489
'04 FXT/‘05 Baja T
'71-FF1/14 WRX
Update bump!
frogmonk is offline   Reply With Quote
What the heck is this on his intake manifold? air/water intercooler?? STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-25-2003 12:27 PM
STi air-water intercooler?? kotaro Legacy Forum 22 12-19-2002 01:51 PM
Air/Water intercooler install, any suggestions? BlueDemon South East Region Forum 3 08-25-2002 09:39 PM
Air/Water intercooler? FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2002 11:45 PM
Interesting Air/Water intercooler thought Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 9 02-13-2002 11:53 PM
