06-06-2019, 10:07 AM | #51 |
Member#: 86205
International
Vehicle:1997 obs ,T? Greyish ,greenish |
Sure ,
With enough boost (30psi?) and fuel ! and the right cam and turbo(s) I don't think a stock block and crank ,etc would take it for too long !
06-06-2019, 02:01 PM | #52 |
Member#: 437670
Vehicle:2005 2.5 SC OB |
Subaru Cylinder Head Flow Database
Well I meant the heads not the block. I think I found someone who did nearly that much.
https://forums.nasioc.com/forums/sho...highlight=sohc Last edited by pcampbell; 06-07-2019 at 12:40 AM. |
10-31-2019, 11:10 AM | #53 |
Member#: 437670
What is the cost to have a head or intake flow tested?
03-25-2020, 09:09 AM | #54 |
Member#: 488540
Vehicle:2003 Wrx Silver |
You guys here are pretty knowledgable, can yall help??
https://forums.nasioc.com/forums/showthread.php?t=2918706 Link to my 03 build thread. Have a jdm longblock and whatever is in the wrx atm jdm or usdm idk but have two sets of heads. Idk which to use, maybe yall can help with the phasing stuff too, not sure what phase engines I have |
03-25-2020, 10:08 AM | #55 | |
Member#: 108051
AKIC
Vehicle:2005 WRX STi WRB |
03-25-2020, 10:19 AM | #56 | |
Member#: 108051
AKIC
If you look you'll see that GSC s2 cams are basically a equal grind to a jdm big port cam. |
01-16-2021, 08:54 AM | #57 |
Member#: 349916
Vehicle:2008 WRX Sti Spec R WRC blue |
IAG stage 5 heads vs Crest cast heads
Hi. Thanks for the useful thread with flow rates. Does anyone know what a dual avcs 257 head flows with plus 1 valves and 272 Kelford cams vs IAG stage 5 vs the Crest CNC cast heads? Thanks
02-22-2021, 08:55 PM | #58 | |
Member#: 260314
NESIC
Vehicle:2007 STI silver gray metallic |
Flow average of 284/219 @ .445" lift Kelford 220-C cams (272/268 for DAVCS). My engine made 470 HP on 24.0 PSI, running Premium gas with Torco additive. |
Similar Threads | ||||
Subaru Cylinder Head Info+ Specs | cribbie | Built Motor Discussion | 7 | 11-21-2018 11:53 PM |
EJ205 heads flow? | leighton1245 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-06-2010 09:34 AM |
subaru cylinder heads | TimBeeno | Private 'Wanted' Classifieds | 2 | 09-27-2007 11:45 PM |
Cylinder Head Flow Bench | nkeehn | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 03-18-2003 05:34 AM |
Air flow data - Cylinder Heads | Trey | Technical Forum Archive | 16 | 08-10-2000 11:38 AM |
