Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 10-07-2000, 01:22 AM   #1
HillbillyRS
Member#: 2501
Question Gear Ratios
What gear ratio is in a MY00? What other ratios are available? Thanks for any help.
HillbillyRS is offline
Old 10-07-2000, 04:23 AM   #2
HillbillyRS
Member#: 2501
Lightbulb
Forgot to tell yall that it's an rs. Sorry.
Old 10-07-2000, 05:00 AM   #3
JGard
Member#: 1904
2017 Impreza Sport
E36 M3/4/5
Post
hey, i don't know them offhand... but it is in the owners manual, and if you don't own one, either you could do a search here, or find someone's personal web-page, and lots of people have it listed there.
JGard is offline
Old 10-08-2000, 11:42 PM   #4
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Post
Only the forward gears:
3.545, 2.111, 1.448, 1.088, 0.780
Final = 4.11
kgb is offline
Old 10-09-2000, 02:24 PM   #5
WhiteCoupe
Member#: 1510
Post
If it's an automatic..the final is 4.44
WhiteCoupe is offline
Old 10-12-2000, 05:24 PM   #6
HillbillyRS
Member#: 2501
Wink
Thanks, but are there any other final drive ratios available? Right now my car just has an intake and exhaust and I can almost wind 5th gear completely out(5900 rpm). If I put on a turbo(50+ hp) I will definitely run out of gear.
Old 10-12-2000, 10:11 PM   #7
HillbillyRS
Member#: 2501
Wink
bump
Old 10-13-2000, 08:54 AM   #8
XT6Wagon
Member#: 524
04 STi
Post
Yes there is other trannies that fit, depending on how cute you want to get with it.
The most likely one you would want is the legacy double overdrive unit.
If you want to play with 1/2 shafts and possibly driveshafts you can select from a Huge array of trannies including the 85+ 4wd 5spds. I would stick to the 99+ trannies though as it should not require any modification.
XT6Wagon is offline
Old 10-13-2000, 05:24 PM   #9
HillbillyRS
Member#: 2501
Post
Is there no way to actually change the gear on the diffs?
Final Drive ratio & 6th gear ratio? scuzzy Transmission (AT/MT) & Driveline 1 11-09-2013 10:54 AM
what gear ratio is 2004 FXT? and what other 4Eat ratios are available? WRXINTX Transmission (AT/MT) & Driveline 4 08-26-2008 02:44 PM
Learning Gear Ratio and Final Drive Ratio madwrxing Transmission (AT/MT) & Driveline 0 04-16-2006 10:02 PM
97L gear ratios vs. RS ratios? (MT) Murray Transmission (AT/MT) & Driveline 7 08-12-2003 11:26 AM
Gear ratios and differential ratio for 95 legacy and 95 imprezza ciper Transmission (AT/MT) & Driveline 0 06-14-2002 06:58 PM
