05-21-2020, 10:25 PM | #1 |
Member#: 352704
VIC
Vehicle:1965 Vw panel bus with an EJ20 Turbo Swap |
Advantages to adding an adjustable FPR ?
I was wondering what some of the advantages to adding/upgrading to an adjustable fuel pressure regulator was. If it was adjusted back to the baseline of 43.xx PSI then why upgrade etc. Or for that matter what advantages are there to upping the PSI to 45 + psi etc ?
05-21-2020, 10:44 PM | #2 |
Member#: 298403
W. Canada
Vehicle:2008 WRX Premium Spark Silver |
Higher fuel pressure means higher flow rates through the injectors. When shopping for injectors, you'll see a flow rate @ 'x' psi. You can effectively increase/decrease that flow rate with with a higher/lower pressure.
Keep in mind that you'll need some fuelling adjustments in the map done if you stray from stock pressure. And you're not entirely wrong on your conclusion. Why upgrade if it's staying stock? You could be future proofing your build. Say you selected a 1000cc injector and discovered on the dyno you need just a smidge more to reach your goal and the injectors are already maxed (IDC's are getting close to 100%). Turning up the fuel pressure will not only help you get that extra 10 hp you're looking for, but will also reduce IDC's. Keep in mind, if you decide to get an AFPR, an uprated fuel pump will be necessary because the pressure is also pushing back on the fuel pump. The stocker likely won't handle it depending how much the pressure is increased. |
05-24-2020, 11:30 PM | #3 |
Member#: 352704
VIC
Good explanation , thank you.
