Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 04-02-2020, 03:01 PM   #1
fullah
Member#: 233053
Default Carbon fiber skinning
I'm looking at making a few accent pieces and found a lot of videos on YouTube on skinning. These pieces would be cosmetic only and would probably be made using an abs plastic as a base. My understanding is you put down a gel coat then wait for that to get tacky then first layer of carbon and then resin. I know I'm oversimplying.
Ideally I would rather build the part from abs plastic as it's easy to mold with heat and then skin with carbon. Is that even possible or does abs react with the resin?
Also where are you guys buying carbon fiber from? Prices really fluctuate especially with shipping.
fullah is offline   Reply With Quote
Old 04-03-2020, 12:55 PM   #2
Wayne Suhrbier
Member#: 144044
2006 STI
You want it shipped rolled and not folded. Research the resins and find one that meets your need. They can get expensive too for the good ones. West systems are a good place to start. Also make sure you have UV protection in your gloss coat. Fibergast is where I've been tending to purchase supplies from. Check out Composite Envisions for some fun stuff.
Wayne Suhrbier is offline   Reply With Quote
Old 04-20-2020, 09:01 AM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
Gel coat is the first coat when making parts from a mold because it's what you'll actually be seeing when it's installed. When skinning an existing piece you only use resin and polish the s*** out of it when it's dry. Experiment on several trial pieces to get a process that works for you. Make sure you do some with tight inside corners and curves as well since those are the most difficult to lay flat and keep the weave direction straight. Don't cheap out on the resin. You really do get what you pay for. As mentioned before, West Systems makes good products. It's what I trust as well.
snow_bound26 is offline   Reply With Quote
