Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 01-04-2020, 09:45 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Default Intake idea, need suggestions for OEM style boxes
What I am trying to do, is relocate the filter into the fender - I can't use cone shaped because they are too big, and I figured I could use a panel one since it provides good area
stock GD air box doesn't fit, too big, and the outlet is pointed to a wrong direction
need suggestions for OEM boxes that would do the trick
ibputitinthefender....
1. there is a huge oil cooler sitting behind the fog light, so I can't fit anything there
2. I am running side vents open (GC8) so I don't want to expose it to rain
3. Trying to isolate it from engine heat
4. I don't care that it will get dirty fast, I only drive car in hot summer days
Hyper is offline   Reply With Quote
Old 01-08-2020, 09:28 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Make your own box and use two filters. One facing down and one facing the fender. ALL the filter area.
Old 01-09-2020, 03:51 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
I am lazy
plus I want to keep all intake out of plastic, no more aluminum heat magnets!
oh, and I can't point it down, remember?
Old 01-13-2020, 03:35 PM   #4
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
what about the airbox out of a 08-14 wrx or 08-19 STi?
for reference, here's an STi one:
https://www.ebay.com/itm/2008-2019-S...sAAOSwBw5dr7Zr
I might have my 08 wrx's air box floating around. i'll check my garage. I DO have a 08-14 AVO turbo inlet as well... could never get the bastard successfully installed on my old car. not sure how much piping you have figured out yet.
isotopesope is offline   Reply With Quote
Old 03-07-2020, 03:09 PM   #5
gu5
Member#: 82623
my06 spec-c type ra
Just seen this Hyper why dont you use an inner wing box then you can use a cone filter
gu5 is offline   Reply With Quote
