06-12-2018, 02:14 AM | #1376 |
Member#: 457525
Vehicle:2017 WRX Limited DGM |
I'm hoping to avoid additional NVH by using the STI trans mount instead of the Group N. I've also heard that rear diff mount inserts can help.
Engine mounts are tough. All the aftermarket ones are way too ****ing stiff and the Group N's from the BRZ are pretty expensive. I got the Perrin pitch stop brace as soon as I saw that my 2017 didn't have the revised mount. It's pretty solid on the driver side, but I'm slightly concerned about the perrin pitch stop brace on the passenger side of the mount. It's only help to the chassis/firewall via two aluminum rivet nuts which are, frankly, weaker than I'm comfortable with. Unfortunately I just couldn't find stainless steel rivet nuts that would fit
06-12-2018, 09:13 AM | #1377 | |
Member#: 415503
Vehicle:2016 WRX limited black silica |
jokes aside. I plan to get the Perrin pitch stop, engine and trans mounts when I have $1k to spend on it haha. |
06-12-2018, 10:15 AM | #1378 | |
Member#: 415503
road noise is already loud, so now we have the engine and trans noise to worry about! how about vibrations? it would seem that all this stiffening would cause more vibrations inside the car. |
06-12-2018, 10:16 AM | #1379 | |
Member#: 423601
NWIC
Vehicle:2016 WRX LBP |
The aluminum ones are plenty strong, the force that is applied to the nuts is not enough to cause an issue. Additionally if they strip out or do not crush properly while installing them you will not be able to get the SS ones out easily compared to the aluminum ones, as well as if you ever have to remove them the aluminum ones can just be pulled out with some needle nose pliers. |
06-12-2018, 10:18 AM | #1380 |
Member#: 423601
NWIC
Sorry not sure what you mean? but the PERRIN Pitch stop brace is NOT made to fix a crack or broken bracket, it is a preventive maintenance part.
06-12-2018, 11:08 AM | #1381 | |
Member#: 415503
quoted from the site: "The PERRIN Pitch Stop Brace does exactly what its name implies, it reinforces the brackets that connect the pitch stop to the car. The factory brackets on the firewall that hold the pitch stop in place will bend and snap off, even with the flimsy and soft factory pitch stop bushings. The PERRIN Pitch Stop Brace will act as both a means of preventing your pitch stop brackets from tearing as well as reattaching the pitch stop to the firewall if your brackets have already failed.[1] " Either way I was trolling a bit to get discussion started....as I wouldnt use this to reattach if it broke.... I might also mention that I plan on getting one for my car...since I really like your all's stuff even if my personal opinion is that they are a bit too pricey for me...Speaking of which...do you all have discounts for Nasioc members? Last edited by vtwinjunkie; 06-12-2018 at 03:43 PM. |
06-28-2018, 07:53 PM | #1382 |
Member#: 392524
NWIC
Vehicle:2015 WRX WRB |
I installed a pitch stop brace (Perrin) on my 2015 WRX - fairly easy install - also added solid pitch stop while I had TMIC off
07-07-2018, 02:20 PM | #1383 |
Member#: 409569
Vehicle:2018 WRX Silver |
I'm looking to install the group N pitch stop in my 2018 WRX. Is this safe to do so without Perrin's brace on vehicles with the revised mount, or is it still too early to tell?
07-27-2018, 11:11 PM | #1384 |
Member#: 462306
Vehicle:2016 WRX Lapis Blue |
Will the Group N engine mounts from STi for the BRS (FA 20) motor work on a WRX?
08-03-2018, 04:54 PM | #1385 | |
Member#: 445435
Vehicle:2016 WRX Base MT E85 21Ascent,19XV,17Impreza |
08-19-2018, 03:15 PM | #1386 |
Member#: 490386
Vehicle:2004 WRX WRB |
Pitch stop mount bracket cracked
I have the same issue with my 04 wrx where the bracket on the fire wall is cracked and its causing a metal tinging sound when I shift gears. I know theres a reinforcement for the 15+ but I cant find one for the bobble eye. Is there a aftermarket bracket for the 02+? If not, how well with it hold up if I weld it. I was told by a couple members from central ohio subarus to weld it up but I dont know if it will hold up very well. The car is about 98% stock with no tune
08-19-2018, 08:28 PM | #1387 | |
Member#: 141952
Vehicle:2023 M340i |
https://forums.nasioc.com/forums/sho...&postcount=384 |
10-15-2018, 01:07 PM | #1388 |
Member#: 472308
Vehicle:2015 WRX Red |
Okay, same problem. Not covered. Going to attach new bracket with blind rivets or blind bolts.
01-23-2019, 01:43 PM | #1389 |
Member#: 458661
I just purchased a 2017 wrx and noticed this issue, cracked pitch stop bracket, the next day. I've read all these posts. What's seems to be the repair for this? How is it holding up for those who have had it happen in the past years? Looking at the technical service bulletin on subispeeds website, does the motor snd trans have to come out? I assume the dealer will not cover with EGR,TGV deletes, intake, accessport, and an exhaust!
Any follow up information would be appreciated. Last edited by lude9285; 01-23-2019 at 03:29 PM. |
01-23-2019, 02:22 PM | #1390 | |
Member#: 421831
01-23-2019, 03:18 PM | #1391 |
Member#: 458661
Sorry. The pitch stop failure issue.
01-23-2019, 03:27 PM | #1392 |
Member#: 421831
01-23-2019, 03:31 PM | #1393 |
Member#: 458661
01-23-2019, 04:23 PM | #1394 | |
Member#: 393629
W. Canada
The place you purchased the car from, assuming it's a dealership, should fix it under warranty. If you bought it privately, warranties still carry over. |
01-23-2019, 04:24 PM | #1395 |
Member#: 421831
no it wasn't cracked but i prevented from happening by replacing the stock pitch mount. with less movement, less likely that bracket would snap. but isn't yours still covered under warranty?
01-23-2019, 04:49 PM | #1396 |
Member#: 458661
It is but I assume they will immediately deny the claim due to the modifications.
01-23-2019, 05:34 PM | #1397 |
Member#: 421831
not really. it's a common issue and there is a service bulletin on it. they should cover it under warranty. and yeah....it's unfortunate and they may have to take the engine out to replace the bracket.
01-23-2019, 07:16 PM | #1398 |
Member#: 458661
Has anyone else got this covered under warranty with similar modifications? I know the starter of this thread stated his dealership was going to pay for half.
01-23-2019, 07:49 PM | #1399 | |
Member#: 332408
Installing the group N engine and trans mounts should help by stiffening the overall engine/trans. |
01-23-2019, 07:52 PM | #1400 |
Member#: 332408
The warranty will most likely be reviewed on a case by case basis. If they see you've modified the vehicle (e.g., tuned and increased hp), I wouldn't be surprised if they denied your broken pitch stop bracket.
