05-12-2017, 10:13 AM | #1326 |
Member#: 420404
Vehicle:2015 WRX Limited 6MT Dark Gray Metallic |
Thanks a lot. The only difference I see in the manual is that it says to first push the pedal down and hold it, open bleeder, close bleeder. Pretty much like you said. But then it says to push the pedal down AND up several times while the bleeder is still closed. Then open the bleeder again. Close bleeder and repeat that same process. I guess it could work either way. I'm guess once no more air comes out, I close the bleeder, bring the pedal up and it should stay up?
05-12-2017, 12:52 PM | #1327 |
Member#: 407127
Vehicle:2013 WRX Limited WR Blue |
Broken pitch stop firewall mount...
What was the fix for this mounting point issue? Did they weld it back on?
More so, does anyone have any evidence of this being a pre-2015 issue? I've looked all over the interwebs, haven't seen anything yet. Last edited by OrphenCB; 05-12-2017 at 02:59 PM. |
05-12-2017, 05:42 PM | #1328 | |
Member#: 420404
05-12-2017, 05:44 PM | #1329 | |
Member#: 393629
W. Canada
05-12-2017, 05:48 PM | #1330 |
Member#: 420404
Hmmm. OK, so maybe mine just didn't have much air, if any, in it from the factory. I still have to install the rest of the brace. I just wanted to get the clutch part out of the way. So when I have time to get back in there for that, maybe I'll do a couple more cycles of bleeding to be sure I have all the air out. But as far as I can tell my clutch pedal seems to be grabbing at the correct point during shifting and it's popping right back up.
05-12-2017, 05:54 PM | #1331 | |
Member#: 420404
http://www.subispeed.com/instruction...ching-stop.pdf I think most people, myself included, are opting to install the perrin brace as a preventative measure rather than chance having the factory mounting point break and rely on Subaru techs to gut the entire engine bay to install their updated mounting bracket. The car probably won't be the same after that. As for this also being a problem spot on older model WRX's before 2015, I have no idea. Last edited by nickn929; 05-12-2017 at 06:02 PM. |
05-15-2017, 01:55 AM | #1332 |
Member#: 463335
Vehicle:2015 WRX DGM |
I posted in this thread a bit ago about suffering from this issue.
I took my car to the dealership to see what they could do about it. I'm full bolt ons and on E85, and the dealership didn't bother arguing with me about it being covered under warrant (luckily.) The dealership had to send it off to a body shop in order for the bracket to be welded in. It took about a week and a half to get my car back due to them apparently having to remove the motor to weld in the bracket. The thickness of the bracket is noticeably thicker, so hopefully no more pitch stop problems for me later down the road. |
05-15-2017, 05:58 PM | #1333 |
Member#: 445435
Vehicle:2016 WRX Base MT E85 21Ascent,19XV,17Impreza |
Same thing happened to me. But I was worried that the "creaking" was as a result of me introducing air in to the line even though I bled it to death.
05-16-2017, 12:15 AM | #1334 |
Member#: 219892
RMIC
Vehicle:AP1 S2K Life Now 17' PRD WRX CVT (Sold) |
for cvt's just in case someone would need this...
https://forums.nasioc.com/forums/sho....php?t=2831539 |
05-24-2017, 07:21 PM | #1335 |
Member#: 462457
Vehicle:2016 WRX Limited WR Blue |
Jeezzz I didn't even know this was an issue. I am going to pull my TMIC off and take a quick look. Mine is a 2016 WRX Limited vin starts with a J.
Do the Perrin parts help? |
05-26-2017, 01:57 AM | #1336 |
Member#: 409888
Guys with the Perrin transmission mount installed, what did you do with this thing?
05-26-2017, 10:14 AM | #1337 |
Member#: 445435
I assume you are asking about the spacer? It is used on the Pre MY15 WRX's 5-speeds as the the transmission housings were smaller than the STI 6-speed housing. There has been considerable discussion about whether the 2016 WRX 6-speed needs it, since its transmission is based on the old 5-speed, but with an extra gear. The consensus-even from Perrin-is that you don't need it.
05-26-2017, 10:55 AM | #1338 |
Member#: 423601
NWIC
Vehicle:2016 WRX LBP |
05-26-2017, 01:17 PM | #1339 | |
Member#: 409888
Got it! |
05-29-2017, 10:23 AM | #1340 | |
Member#: 297268
Vehicle:2016 WRX IS |
06-06-2017, 01:00 AM | #1341 |
Member#: 456813
Vehicle:2016 WRX MT LIMITED Dark Grey |
How much would it cost to get all the mounts installed professionally? Roughly...
06-06-2017, 04:51 PM | #1342 |
Member#: 449597
NWIC
Vehicle:2016 WRX Pure Red |
I ordered the Perrin pitch stop mount reinforcement bracket as soon as I get the TSB letter in the mail from Subaru. A local shop charged me one hour in labor to install it ($80) even though it took them more like 1.5. I gave them the instructions, a bottle of Subaru brake fluid, and it was no big deal. It's a difficult job to screw up.
I also had them replace the pitch stop mount with a Group N part while they were in there cause why not. Slight increase in cabin noise (already had Group N tranny mount in) but nice improvement to driveline lash esp. in first gear with the stiffer pitch stop mount. *EDIT* I would have done the job myself but shied away due to having to bleed the clutch line. |
06-22-2017, 09:41 AM | #1343 |
Member#: 469053
I just ordered a 2018 WRX Limited - which SOA said will arrive in September this year.
My question is this: Has this issue been fixed by now for 2018's or Is the perrin pitch stop brace still recommended for new models? Thank you |
06-22-2017, 09:55 AM | #1344 | |
Member#: 337626
TXIC
Vehicle:2015 WRX Crystal White Pearl |
i have not purchased this bracket, and i'm considering doing it now because despite having bled my brakes and done a bunch of other mods this mod seemed like a gigantic hassle. no more. |
06-22-2017, 12:07 PM | #1345 |
Member#: 463349
Vehicle:2017 WRX Sport World Rally Blue |
This was apparently fixed on MY17 but I haven't seen many people with 2017's chime in. I've been in a holding pattern until I see more instances of 2017's and upgraded pitch stops.
06-22-2017, 01:14 PM | #1346 |
Member#: 325693
Vehicle:2015 WRX SOLD |
You can look up the tsb and will tell you how to see if you have the thicker version. I believe in 17 they are fixed
06-22-2017, 01:15 PM | #1347 |
Member#: 325693
Take a peek at the drivers side of the pitch stop mount if there is a 7/16 hole it's the new version and will be 2mm instead of 1mm
07-20-2017, 01:46 PM | #1348 |
Member#: 447566
Vehicle:2017 86 Black |
There is a post somewhere that lists the VIN where the changeover occurred. From what I remember it was about mid way through the MY17 production run.
Edit: Here's the link to the TSB: http://www.subispeed.com/instruction...ching-stop.pdf Last edited by Chuckable; 07-20-2017 at 01:53 PM. |
07-20-2017, 01:57 PM | #1349 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
07-20-2017, 10:39 PM | #1350 |
Member#: 219892
RMIC
