04-23-2014, 09:29 PM | #51 | |
Member#: 378214
The base/premium use a regular set of bulbs. H11 - low beam 9005 - high beam 194/168 - C position light 7440 - turn signal H16 - fogs The limited has a LED array that's used to shine light into low-beam and C position lights. As far as I know, the high-beam, turn signal and fogs are exactly the same as base/premium - regular halogen bulbs... hence the fugly DRL look of the high-beam running @ 1/2 voltage, which on the limited is more pronounced (contrast with the LED) than on the base/premium (at least they are all crappy halogens). One clear 'benefit' of the base/limited housings, bulb/socket setup is it should be much much easier to re-wire things to force the C position light to work as the DRLs. With a strong enough LED bulb in there, maybe some acrylic rods, etc. this should look great and shine brighter than the limited C shape. On the limited it might prove tricky rewiring or replacing anything that uses the LED array... not that you need to. Just drop some nice LED high-beams, fogs and turn signals and you're set. In all trims, this car is begging for a full LED or bi-xenon conversion.
04-24-2014, 01:38 AM | #52 | |
Member#: 373546
Vehicle:2015 wrx limited crystal black |
04-24-2014, 11:22 AM | #53 | |
Member#: 150452
AKIC
Vehicle:2016 Subaru WRX STi Ice Silver Metallic |
Thank you!
04-24-2014, 12:19 PM | #54 |
Member#: 378138
Vehicle:2022 WRX Silver |
04-24-2014, 10:05 PM | #55 |
Member#: 119745
will that orange side reflector come out???
04-24-2014, 10:23 PM | #56 |
Member#: 72195
Vehicle:2016 Golf R DSG Oryx White Pearl |
04-24-2014, 10:52 PM | #57 |
Member#: 156723
Vehicle:17 2.5i foz dgm rip wrx/rs/2.5i/foz1 |
Isn't the led option just a different bulb? On the xv crosstrek there are two.
04-29-2014, 01:33 PM | #58 |
Member#: 150452
AKIC
Yessir. I just like the look of black and orange together, I think they're striking colours and offset each other well, so, I didn't want to remove mine personally.
Negative. The LED "C" on the higher models has additional pins in the headlamp plug, plus, the LEDs are within the C, as opposed to the halogen bulb in the corner of it. I've been looking into a kit for seating a acrylic tube to run within the C and an LED that will illuminate it. |
04-29-2014, 05:05 PM | #59 |
Member#: 15763
Vehicle:2015 WRX WRB |
Those look great. I want to black out my Base headlights but I would like to replace the orange reflectors also so I guess I will wait to see what the aftermarket comes up with first. Also really want to put in LEDs on the C so I guess I will see what everyone does to see what fits and works best. Keep the mods coming they are great.
05-02-2014, 01:43 PM | #60 |
Member#: 389693
South East
Vehicle:2015 WRX Ice Silver |
Leakage?
Any signs or worries with leakage?
When reassembling did you simply reheat and squeeze back together, or did you add some extra sealant? This is my only worry haha, do not want any fogging. |
05-02-2014, 01:57 PM | #61 |
Member#: 72195
Reheat the lights, squeeze together and use the pressure clamps around the light to make sure they're together. No sealant is necessary. If you do decide to use sealant, get butyl online, don't use silicone.
05-02-2014, 02:11 PM | #62 | |
Member#: 211232
Vehicle:2003 Legacy Super Awesome White |
Secondly, I'm planning on doing this exact thing with acrylic tubing in the C lights this weekend. I'll most my results. These yellow lights are just killin' me. |
05-02-2014, 10:06 PM | #63 | |
Member#: 349476
International
Vehicle:2015 WRX Premium AU WRB |
http://www.lightbulbs4cars.com/product/NOK9718 I might buy these and report back Last edited by cpalada; 05-04-2014 at 08:57 AM. |
05-04-2014, 05:52 PM | #64 | |
Member#: 150452
AKIC
No issues with condensations or anything. Since the car is still very new, the rubber sealant used was still extremely fresh and able to be remolded back into the headlamp housing. This may be more of a concern for vehicles with a few years under it's belt. After the painting was completed, I just re-heated the assembly for 5 minutes, then pushed them back together ensuring the sealant was evenly distributed. No problems to date (= |
05-22-2014, 05:36 PM | #65 |
Member#: 389409
TXIC
Vehicle:2017 STI WRB, '15 DGM WRX RIP. |
No condensation at all so far?
Did the chrome rings on the projector housing separate from the rest of the chrome piece, or is it a single piece? I'd like to keep the ring around the projector chrome, and if it comes off, it should be super easy, otherwise i'll try taping it off. |
06-11-2014, 07:05 PM | #66 | |
Member#: 389693
South East
06-11-2014, 07:39 PM | #67 | |
Member#: 390165
Vehicle:2015 WRX Premium Crystal White Pearl |
06-11-2014, 08:40 PM | #68 |
Member#: 389693
South East
06-11-2014, 10:08 PM | #69 |
Member#: 202074
Im assuming this will work on the headlight for the 2015 STi?
06-11-2014, 11:41 PM | #70 | |
Member#: 388247
Vehicle:2015 WRX Premium WRB |
06-12-2014, 09:04 AM | #71 |
Member#: 393027
NESIC
Vehicle:2014 WRX Hatch Gray |
Wondering if anyone in the Central, TX area knows of a shop I can go and have my headlights fixed/ customized ? Just don't feel like sending em' back North East to my home town to have em' done. Any help would be great! I've searched but, only found steps to "DIY".
Thanks, a lot! |
06-12-2014, 09:29 PM | #72 | |
Member#: 389693
South East
06-12-2014, 09:36 PM | #73 |
Member#: 388247
06-14-2014, 04:20 PM | #74 | |
Member#: 389693
South East
06-14-2014, 04:53 PM | #75 |
Member#: 357654
http://forums.nasioc.com/forums/show....php?t=2639338
Check out my thread here if anyone in interested in a set of acrylic c's. Copied from thread ::: I have been waiting for a broken headlight to go on eBay so that I could make molds for the acrylic c's. I have extra rods around and figured I would make a proof of concept while I was waiting. These are too big of diameter but they will work to see how it will disperse light. It came out pretty well. Used a template from the outside of the headlight. Should be pretty close to scale. Now I just need a mold to form a template and they should be ready to make. Last edited by Mrlaigle; 06-14-2014 at 06:49 PM. |
