Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 02-15-2014, 07:52 PM   #1
Samiam1017
Member#: 334068
Default Torque plate cad drawings
Looking for some CAD drawing for a ej25. Torque plate. I see guys advertise the plate for sale but want some drawings instead. Don't know if this is in the right spot either. Thx
Samiam1017 is offline   Reply With Quote
Old 02-18-2014, 09:06 AM   #2
scootarida1
Member#: 154534
2017 Forester 2.0XT
You might be better off buying a head gasket and taking some dimensions. Not sure if anyonee would give out this information.
scootarida1 is offline   Reply With Quote
Old 02-18-2014, 01:25 PM   #3
Samiam1017
Member#: 334068
Good idea thx. I have some head gaskets.
Old 02-19-2014, 10:19 PM   #4
Purpose_Built
Member#: 222879
2015 STI
ISM
If you send me the dimensions i can model one in Creo or Solidworks
Purpose_Built is offline   Reply With Quote
Old 02-21-2014, 01:17 AM   #5
Mister Tanker
Member#: 237759
2003 WRX Wagon
Built ej205 478whp 417wtq
Pm me your email address. I have Mastercam x6 .mcx6 file with Verisurf data, a solid model, and toolpaths for an ej205 torque plate I made.
Mister Tanker is offline   Reply With Quote
Old 03-04-2014, 07:25 AM   #6
Samiam1017
Member#: 334068
Purpose I can send you a old head gasket if you want make up a file.
Tanker I PMed ya Thx
Old 03-05-2014, 06:45 PM   #7
Purpose_Built
Member#: 222879
2015 STI
ISM
That will work. Reach me at [email protected]
Old 04-20-2014, 09:53 PM   #8
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
I'm interested also.I have a 3''6061 12x8 piece alum here to cut.
EROCS04SBRUSTI is offline   Reply With Quote
Old 04-22-2015, 02:06 PM   #9
philosophical
Member#: 418342
I am looking for some cad for a torque plate if anybody has it can you pm me and i'll send you my email address. its for an ej25 though, so im not sure if the hole locations are the same but it will give me a starting point.
thanks
philosophical is offline   Reply With Quote
Old 04-23-2015, 07:49 AM   #10
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Outer holes will be the same, inner diameters will be different but the same center - center dimension.
Layvon is offline   Reply With Quote
Old 04-23-2015, 02:10 PM   #11
philosophical
Member#: 418342
thats what I thought. Nobody seems to be around with these drawings, i might end up having to measure them out from my head gasket. once i get my hands on one i'll see about posting it up somewhere so everybody can access it.
Old 04-23-2015, 03:10 PM   #12
Purpose_Built
Member#: 222879
2015 STI
ISM
So many people have bs'd me when i asked them for measurements. Its a very easy thing to design.
Old 06-13-2015, 03:06 PM   #13
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Are you guys making the bore slightly larger or smaller then the ID of the head gasket? I measured the stock sti gasket and got 101.27mm. Im assuming slightly smaller as I cant really see the gasket in "most" pics of them installed on a block. From what Ive seen folk make them from 101-103mm. I think slightly smaller would be the way to go...
rexworx is offline   Reply With Quote
Old 10-15-2015, 12:11 AM   #14
philosophical
Member#: 418342
I got my hands on a .dxf for a torque plate. if you want a copy or better yet if you can host a copy for anyone to download just pm me with your email address and i will send it. I made it out of some 1.25 aluminum and made up some bolt spacers from mild steel with a washer under them. worked out fine with my ej251 block. with the 1.25 plate the spacers ended up being 2.6" long minus whatever thickness steel washer you use, if you use one.
Old 10-15-2015, 07:33 PM   #15
philosophical
Member#: 418342
Just emailed the file to someone on here that should be able to host it for everyone :-)
Old 12-28-2019, 01:01 PM   #16
Evil_Iguana
Member#: 497403
Knowing that the topic is 4 years old, does anyone has those cad files
I will have to make them myself as the import and delivery cost as much as the plate itself.
Evil_Iguana is offline   Reply With Quote
Old 04-01-2020, 01:13 PM   #17
brent_jj
Member#: 513066
Following.
brent_jj is offline   Reply With Quote
