12-15-2009, 02:46 PM | #1 |
Member#: 221436
Vehicle:02 WRX vf39 |
Torque Plate vs Non Torque Plate Motor
Some people claim that the EJ257 will go out of round unless it is bored/honed with a torque plate. However- judging by the information i've gathered around here, many people build 100mm bore motors without issues and presumably their machine shops (random local ones) did not use a torque plate. I need my block bored/honed and I really hate to get it done and then have excessive blowby, anyone have experience with or without a 'torque-plate-bored' motor?
12-15-2009, 05:21 PM | #2 |
Member#: 14116
Measure the bores without torque plate and measure them again with torque plate fitted. After this you know there is only one RIGHT way to do a bore/hone job!!!
Mark. |
12-15-2009, 05:23 PM | #3 |
Member#: 81633
Vehicle:'98 RS-T Blue |
Factory doesn't use a torque plate.
12-15-2009, 06:05 PM | #4 |
Member#: 49222
Vehicle:2005 Legacy GT Wagon Limited 5MT 580whpQ16 |
Mine was done with a torque plate. The motor is going in tomorrow so I will let you know the outcome.
12-15-2009, 09:44 PM | #5 |
Member#: 230682
....Anywhere I can find description/definition of a torque plate ? Already on a link somewhere ?
12-15-2009, 09:52 PM | #6 |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
12-15-2009, 10:39 PM | #7 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
I have bored about 3 motors so far WITHOUT plate, just for myself. NO blowby. The motors I have had bored and sold have had NO blowby.\
However,none of these motors are seeing more than 400whp. |
12-16-2009, 12:05 PM | #8 |
Member#: 45494
Vehicle:95 impreza L awd green |
Well did they try and measure that with the block at temp? The way the sleeves are supported would allow the bore to expand where it wasnt support by more than where it is. Not to mention the factory pistons have a VERY small clearance IIRC it is .001. So going by that the factory pistons would seize correct? I mean correct me if I am wrong in my thinking.
12-16-2009, 07:52 PM | #9 | |
Member#: 85036
Vehicle:2013 PBP sti ltd 05 LGT 35r 30psi..busted |
I did this! http://forums.nasioc.com/forums/show....php?t=1659712 Since the end of this thread, I built three customer cars. Two of them opted for the torque plate. One did not. The two that got torque plated, like my motor, are SIGNIFICANTLY quieter (piston slap) both cold and hot, than ones that are not torque plate. This is the only "experimental" evidence I have using torque plates, other than when my machinists measured the bores with and without a torque plate. That info should be in my thread. DK |
12-17-2009, 05:59 AM | #10 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
Useless to do with a torqueplate when you don't know what the bores are doing when the engine is getting hot. So either bore/hone 'as is' or use a torqueplate with the block heated up to 85 degrees. Does anybody do that? I guess not...
12-17-2009, 10:58 AM | #11 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
This only applies to EJ257/EJ255 motors huh? if so.... i'm sorry for you 2.5L guys
12-17-2009, 11:48 AM | #12 |
Member#: 221436
Well it seems like torque plates are the way to go... but certainly not for any sort of *budget* build. Has anyone experimented with a slightly tighter piston-wall clearance on a non-torque plated motor?
12-17-2009, 01:03 PM | #13 |
Member#: 81633
85°C I guess you mean or 185°F in the USA
12-17-2009, 01:29 PM | #14 |
Member#: 51480
International
Eh deg C but it is an intersting discussion; so far I've never used a torque plate and on EJ20s it doesn't have a big impact, on EJ25s it could be, but still, measuring at room temperature - how does the roundness of the cylinders change when the engine gets hot?
12-18-2009, 07:16 AM | #15 |
Member#: 14116
Will check soon on a heated block! On a non heated block the bore is getting ovalised with the torque plate fitted quite a lot... Don't see that it will get better when heating...
12-18-2009, 09:13 AM | #16 | |
Member#: 38469
NESIC
Vehicle:07 LGT spec-b Crystal Grey Metallic |
12-18-2009, 11:32 AM | #17 | |
Member#: 51480
International
12-18-2009, 05:23 PM | #18 |
Member#: 14116
Of course I will heat it with toque plate! I don't have such a big oven, so I think we will use the engine washing machine from my engine shop.
12-19-2009, 12:06 PM | #19 |
Member#: 136231
South East
Vehicle:95 LX Impreza blue |
Torque plates should not matter as much on an ej engine because the head studs or bolts pull from way down in the block. Most engines the head bolts pull from the deck surface and deforms the bore at the top of the cylinder where most of the compression happens. At bottom dead center compression loss is minimized. At most shops they only hone the last few thousandths with torque plates.
12-20-2009, 01:06 AM | #20 | |
Member#: 81633
12-20-2009, 10:40 AM | #21 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
There is also this thread:
http://forums.nasioc.com/forums/show....php?t=1431376 1st post. "machining" section. |
12-20-2009, 12:50 PM | #22 |
Member#: 97561
Vehicle:2006 Widebody WRB/Carbon/Primer |
Which is why the bores are square.
Also it comes down to what type of rings are used. Some rings are able to deal with a non perfect bore. Some rings need it. Talk with your engine builder about what piston and rings your running. Then see what he thinks about boring. I myself have seen the square bores, So I would never not use a torque plate. |
12-20-2009, 12:58 PM | #23 | |
Member#: 97561
Have you ever read the cosworth outline for installing their heads? They set the shim lash when you get them. Then they have to be adjusted when they are bolted to the heads. They go off a few thousands.. |
12-20-2009, 01:02 PM | #24 | |
Member#: 97561
12-20-2009, 02:34 PM | #25 | |
Member#: 14116
If you had measured a Subaru with and without torque plate fitted, you would know that the cilinders will be compressed when the head (or torque plate) is fitted. This causes the bores to be ovalised and getting bigger especially in the middle. |
WTT: My RCE lowering camber plates for your non-lowering plates | Jard | Suspension/Brakes/Handling | 6 | 04-29-2008 11:09 PM |
WTT: RCE Lowering Camber Plates for Non-Lowering Plates | Jard | MAIC Private Classifieds | 7 | 09-27-2007 03:35 PM |
Tilton Twin Plate VS. Exedy Twin plate | majunche66 | Transmission (AT/MT) & Driveline | 6 | 03-08-2006 12:35 PM |
Pillow Balls vs Camber Plates vs STi Strut Tops vs Stock Tops | Bob O | Brakes, Steering & Suspension | 5 | 09-17-2005 11:58 PM |
Primitive Racing skid plate vs Subaru OE plate | remarcable | Interior & Exterior Modification | 8 | 04-26-2001 12:02 AM |
