08-26-2009, 11:22 PM | #1 |
Member#: 175607
Vehicle:04 WRX SILVER |
vf39, Clark Turner map...still need more
I don't know where to go from here, I have an 04' wrx,
cobb sf intake, gimmick inlet, vf39, STI intercooler, 565cc cobb spec c's, cobb up, down pipes hks high power, ap v1.0, Clark Turner map. Not power related: b&m short shifter, bilstein pss9's, cobb sways, perrin links, 18" enkei rs6 rims,falken rt 615's.
08-26-2009, 11:35 PM | #2 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
more what? state your goals, no one can help you if you don't know what you want
08-26-2009, 11:44 PM | #3 |
Member#: 175607
Sorry, more power please. My friend bought an 01' S4 and I barely get ahead of him through second and third. Before I get any comments I do understand he has a 2.7 biturbo.
08-27-2009, 01:05 AM | #4 |
Member#: 96448
Vehicle:02 WRX VF34 |
since you asked:
V7 full drivetrain swap + big turbo |
08-27-2009, 11:18 AM | #5 |
Member#: 193989
South East
Vehicle:2007 Stormy Blue Blown Roadster |
Wander over to the proven power bragging section and search for 02-05 WRX's with turbo swaps. You also have to keep in mind that as you look into bigger and better things, the durability of your 5-speed and shortblock are going to start to be in question.
The biggest question is how fast do you want to spend? If you aren't looking to swap the turbo/injectors again, look into upgrading your intercooler (either a quality aftermarket TMIC or an FMIC setup), TGV Deletes and some Ported and Polished and Coated Exhaust Manifolds. Or look into swapping an 18g/20g and some much bigger injectors, and a quality intercooler to match. |
08-27-2009, 01:38 PM | #6 | |
Member#: 56465
NWIC
Vehicle:2004 WRX - VF34 SRR |
08-27-2009, 10:46 PM | #7 |
Member#: 175607
Do you think a protune would give me significant gains?
08-27-2009, 11:51 PM | #8 |
Member#: 220701
Vehicle:2004 White STi For Sale! |
PPG's
08-28-2009, 08:06 AM | #9 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
slightly bigger turbo or much bigger.
alcohol/.water injection + tune get the cobb intake box so you are not sucking in hot air headers |
08-28-2009, 08:47 AM | #10 |
Member#: 70395
08-28-2009, 09:56 AM | #11 |
Member#: 193989
South East
Are you using the base map that Clark Turner sent you?
Did you do any logs so that he could get your car dialed in better? I found that the original map he sent me was decent, but definitely had a little headroom left. After a doing some logging, we ended up getting a better map on the fourth try. The original map he sends you is going to be much further on the safe side until he gets a log (or multiple logs) back from you to know how your car is responding to the map. You also need to keep in mind he is tuning from AZ, and although it is summer and the temps are high across the country, humidity and altitude can play a major role in how the car behaves. |
08-28-2009, 10:35 AM | #12 |
Member#: 102808
Vehicle:1995 Built EJ207 6sp 30r ***break in*** |
Wait till your friend does the k04s then you'll be kicking and screaming...
but yes... tgv deletes, TMIC/FMIC, maybe even meth. |
08-28-2009, 04:25 PM | #13 |
Member#: 115070
Vehicle:2009 DGM LGT Spec.B 08 Audi Q7 4.2 PRM |
My brother has a B6 S4 with RSK04 turbos, fuel system, intercoolers, exhausts, the whole deal. Put down 375WHP on a Mustang. The S4 has a stronger trans better brakes and way more bottom end... In order for me to keep up I'd need a 20G (minimum) with supporting mods for starters.
You should be pushing 270+WHP against his stock 225-240WHP now. S4 Stock torque reaches 200WTQ at 1,850 rpm so you barely have a chance there. The thing that savs you is that the WRX is a lighter car. If you have cash to burn you can spend enough to walk away from S4's and the like but we are talking five figures for the requisite set of parts to do it. The options are many but you are looking at turbos, transmission, and chassis upgrades to do it right. -soobaviator |
08-28-2009, 09:44 PM | #14 | |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
...Yea. As has been said, if he gets some K04s, you're sunk. I pulled a 1/2 car on a C6 Corvette in my friends K04 S4. If he is stock now you should be well ahead. If he is chipped, I could understand it being a tough fight. |
08-28-2009, 10:04 PM | #15 |
Member#: 175607
He bought the k04's but fortunately he has two kids and doesn't have time to install them and the local shop wants three grand to install them. I'm okay with what I have but I have the power bug....maybe a new platform would be the way to go. I'll definitely try to get some logs over to Clark...thanks for your suggestions.
08-28-2009, 10:22 PM | #16 | |
Member#: 166936
NESIC
Vehicle:2006 Unicorn Saabaru 9-2x |
B6 s4's arnt turbo'd. theyre the 4.2 V8. only the b5's were TT. and to touch a stage 3 s4 (k04's or bigger) you will need to be making some serious power. my buddys stage 3 s4 walks all over protuned stag 2 STi's. his car is amazing. |
08-28-2009, 10:28 PM | #17 |
Member#: 6886
i had the same friendly competition with my friend in his 02 S4 back in the day, he was chipped with his stock k03s , then chipped with k04s.
One of his turbos kept blowing up regardless of upgrades..then he gave up. It was too expensive. Keep at it, you'll eventually win in the end |
08-28-2009, 11:11 PM | #18 | |
Member#: 115070
Advice to the OP is that you may be able to match the S4 on a random street pull somewhere with some basic bolt-ons, but the potential of the car is far beyond a WRX and it will take so much money to get even. You want to beat an S4 then buy one and go from there... I would If I had the means. -soobaviator |
08-28-2009, 11:20 PM | #19 |
Member#: 163445
Vehicle:l33t ******* [email protected] |
Sorry every S4 I've rode in that was powerful was slow vs. power.
They are heavy turds with less than desired gear ratios.. Plus, most of the time they won't even make it to the track to run lol. -Jerod |
08-29-2009, 01:14 AM | #20 |
Member#: 155819
Vehicle:2004 Impreza WRX PSM |
My cousin is going to be doing a k04 turbo swap some time soon, I can't wait to see how we match up
08-29-2009, 03:08 PM | #21 |
Member#: 175607
I'm going to try data logging again...last time I couldn't get ecuexplorer to connect. I'm using vista though so it may not work with my computer.
08-29-2009, 03:40 PM | #22 |
Member#: 193989
South East
08-30-2009, 11:32 AM | #23 |
Member#: 175607
I'm running an AP v1 and I'm not good at using my new laptop or any computer for that matter. I can tint and turn a wrench. I definitely need help. I think if Clark knew what was happening with my ecu he could help me out.
08-30-2009, 02:01 PM | #24 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
2.5 liter with forged internals and a 20g or 30r should get you there.
08-31-2009, 01:45 AM | #25 |
Member#: 92585
Vehicle:2005 Saab 9-2x Aero 13.6@100 EJ205 VF48 93Oct |
ej257 with built pistons and a 35r.
Clark Turner Tuning Cobb Protune maps for your AccessPort, Gain more power! | Clark Turner | Engine/Power/Exhaust | 7856 | 10-15-2020 12:32 PM |
ICC still welcomes Clark Turner! | Import Car Center | Texas Impreza Club Forum -- TXIC | 140 | 04-15-2008 03:27 AM |
new front after wreck. still need more parts. | mekken | Member's Car Gallery | 22 | 01-30-2008 06:10 PM |
read the posts - still need more info | vtec_this | Normally Aspirated Powertrain | 0 | 03-01-2001 04:59 PM |
