06-03-2020, 11:28 AM | #1 |
Member#: 223964
Vehicle:2004 WRX FPGreen EWG Black |
Questions during hybrid rebuild
Hey guys I am hoping you all can give me some advice on some last items I am running into on my rebuild. I recently did a hybrid build and I am missing some hoses that would go from the crankscase vents on each side of the engine and then I think one would go into the inlet. It looks like I would need one hose from each vent and then a T to connect those two to the inlet. I have an inlet with 3 holes in the top, not nipples, but holes that almost look as though the nipples were cut off. Would I connect that T to one of those holes in the inlet? It seems maybe the vacuum of the inlet pulls oil out of those vents when needed?
There is also one closer to the turbo that does not have a hole to go into. Is this one necessary? I would also appreciate any advice on silicone hoses to use for this. Most I see say not to use for oil or gas. Thanks in advance for any advice
