Member#: 362382
Vehicle:2008 LGT OBP
North NJ: 08 LGT Semi-Return-to-Stock Sale - Tons of Aftermarket and OEM Parts
Well, it's been an awesome run -- however, I've dove head-first into overlanding, so the LGT is being parted out and sold to fund the rig.
All parts are used, coming off an 08 LGT (non-VDC). Some components have more cosmetic/aesthetic wear than others, but all are in excellent functional condition.
I believe I've priced everything fairly, but am open to reasonable offers.
Pick-up is preferred, especially for the larger items; Shipping will be at the buyer's expense. Cash is preferred, or PayPal + 3%.
Aftermarket Parts- Grimmspeed CAI - Some wear/tear + surface blemishes on cone filter, otherwise works 100%: $200
https://imgur.com/a/cSlq4jh
- Grimmspeed turbo heat shield- Great condition, minimal wear/tear, once mounted was never moved: $60
https://imgur.com/a/VoOzECt
- Grimmspeed Lightweight Crank Pulley (BLUE) - Plans changed, so I never installed; Excellent condition. $80
https://imgur.com/a/cWWDrOn
- Forge Motorsports FMWRX3 BPV - 100% recirc, black, excellent condition, had switched to the GFB; comes with all original accessories (shims, adjustment springs) and box: $130
https://imgur.com/a/6eECZl8
- Anarchy Motive 6-speed Mammoth Shift Knob - Black, probably the best shift knob I've ever used, with solid heft and feel to it, perfect for larger hands; excellent condition: $40
https://imgur.com/a/Mzn5AvS
- WC Lathewerks Shifter Extender (5-speed) - Paired with the Mammoth shift knob, raised everything to a perfect height and throw; excellent condition: $50
- Subimod Hella Horn Bracket - Used for Hella Horns, in great condition with some paint scuffing around where bolts were. $20
- Rommel's RBS v2 Trunk Lip Spoiler - Professionally color-matched OBP, excellent condition, will need new adhesive. Pairs nicely with the SpoilerKing rear windshield spoiler: $120
https://imgur.com/a/fjMspki
- Lloyd Mats Luxe Floor Mat (Trunk, Black) - Pretty awesome trunk mat with substantive pile, in excellent condition, not much else to say about it: $100
https://imgur.com/a/FUb0brL
- Yakima Roof rack + 2 bike carriers - Full set, comes with wind fairing, full matching set of locks and keys for Q-towers and bike trays. Crossbars have been cut to fit more flush with the car, with end-caps. $180
https://imgur.com/a/7lK0g1m
- BlendMount for Beltronics/Escort Radar Detector (BBE-2001R) - Great for a stealth radar detector install to the rearview mirror, but never used -- went with a different hardwire installation route. Comes with allen wrench/necessary hardware. $65
- The Retrofit Source Angel Eyes/Halo (90mm size) - BNIB, never got to installing them after retrofitting my headlights. $20
- Grimmspeed License Plate Relocation Kit - Used, but in good condition. Comes with all hardware and spacers, an additional mounting U-bracket (brand new, never used), and an OEM front bumper cover (black) with a pre-drilled hole. $60
- Primitive Racing Front Skidplate (05-09 LGT) - 3/16" "Rally Tough" thickness, no holes. Used, but in excellent condition. Pick-up only. $180
OEM Parts -- https://imgur.com/a/51ayAHC. - VF46 turbo - Had swapped out at ~90k miles for a JmP VF52 (by EFI). Zero shaft play. $200
- F/R Sway bars + Endlinks - Went with Perrin swaps and WL endlinks super early on (~40k miles): $60
- OEM Exhaust hangers - Swapped out for KBs. $10
- OEM Springs - Upgraded to H&Rs; ~60k miles on these. $60
- OEM Top hats - Upgraded to WL Com-Cs; ~60k miles on these. $40
- OEM LCAs - Upgraded to aluminums; ~60k on these. $60
- OEM engine cover - Removed after upgrading to the GS TMIC. $60
- OEM Crank Pulley - Removed after upgrading to a LWCP; Used but in excellent condition. $20
- OEM Catted DP - Removed for a Cobb catted DP, ~60k miles on it. $60
- OEM Denso MAF sensor - PN 22680AA31A. Bought as a spare, but never had to use. $20
https://imgur.com/a/X5RFk0p
SOLD- Front/Rear Weathertech Floor Liner Set (Black) - Used, but in great condition. Weather tech sticker on DS mat came off: SOLD TO JOEY SR
- GFB Respons Hybrid BOV/BPV (T9001) - Excellent condition, comes with original box, gasket, allen wrench etc - SOLD TO SCRAPENFRAME
- Grimmspeed TMIC - No coating, some bent fins from normal use but nothing egregious, original box, all pieces pictured, including splitter: SOLD, OFF-FORUMS
https://imgur.com/a/ffj9MRx.
- Sony XAV-AX1000 with Apple CarPlay - BNIB, never opened; Never got around to installing it. SOLD, OFF-FORUMS
- OEM UP - Professionally swapped out for Tomei UP + ELH by EFI. SOLD TO DWMCCAULEY01
- BaysonR V-Limited PU Front Lip - BNIB, never opened. Bought as a replacement for my current BaysonR (held together by zip-ties after meeting an ice chunk on the road), but just never got to it. SOLD, OFF-FORUMS
- SpoilerKing Rear Windshield Spoiler - Professionally color-matched OBP, used but in great condition, will also need new adhesive. Pairs nicely with the RBSv2 trunk spoiler:SOLD TO KRM
- Rally Armor Flaps (Black with Grey lettering) - comes with washers and spacers, used but in great condition. SOLD TO TIG_BONY
- Subtle Solutions alternator cover - Comes with all hardware; Originally black, 100% functional condition, but can clearly use a respray. SOLD TO TIG_BONY
- Grimmspeed Master Cylinder Brace - Non-VDC, a bit dirty, but functionally 100% - made a big difference in brake feel. SOLD to Chocoholic005
- K&N Panel Filter (33-2304)- Used briefly, then went CAI - SOLD to Chocoholic005
- DIAMOND/WORKS Black Anodized SI-Drive Cover - Billet aluminum, excellent 10/10 condition, really adds a nice touch to the interior. SOLD to CODE
- O.Z. Ultraleggera (17x8, +48, 5x100, Black) Winter set, No TPMS - Wrapped in 225/45R17 Blizzak LM60's with 9/32" all around. Haven't used them as much as I originally intended - stored indoors. Overall, 8.5/10. SOLD, OFF-FORUM
- Rota Grids (18x8.5, +44, 5x100, Matte Black), No TPMS - Wrapped in 235/40/18 Conti DWS, but S's are almost gone + some camber wear. Overall, wheels are 8.5/10. SOLD, OFF-FORUM
- Stock Injectors and Fuel Pump - Upgraded to ID1000s + DW65c when upgrading to VF52; has not been flow-tested, but were 100% when swapped out by EFI: SOLD to Chocoholic005
- OEM Front Grill with Subaru Badge - Upgraded to RRev mesh front grill SOLD to Chocoholic005
Trying to keep this post streamlined, so if you want more pictures or have any questions, feel free to reach out.
Thanks,
S
